#1051042 - 05/23/17 01:04 PM rear trunk light
Rich S Offline
Rich S  Offline
Hudson Massachusetts
can anyone tell me if there is a mercury switch on the rear trunk light, a where is it located thank you
#1051046 - 05/23/17 02:46 PM Re: rear trunk light [Re: Rich S]
MC87SS Offline
MC87SS  Offline
Tallahassee, Florida
The switch is built into the light housing.
I came up with a way to add lighting using the factory switch, was going to do a write up on it but never got around to it.
Let me see if i can find the pictures and post about it tonight.
#1051102 - 05/25/17 01:54 PM Re: rear trunk light [Re: Rich S]
MC87SS Offline
MC87SS  Offline
Here is what i did, short but to the point. I don't have any pictures of each step but it should be pretty easy to visualize.
The factory trunk light housing has a built in gravity switch. I took the existing bulb, covered it with a rag and broke the glass. After cleaning out the inside of the bulb i drilled a hole through the center contact point big enough for the stripped end of a wire to go through. Strip about 1/2" of insulation off the wire and slide in through where the bulb used to be and through the hole you just drilled. Solder the wire from the outside then snip off the extra wire. Try to make the soldered area close to the same size as the original contact point the bulb used to have. I mixed up some 2 part plastic putty and while holding the wire in the center filled the area where the bulb used to be and built up enough outside the metal part so you have something to hold while putting the bulb back in. The wire sticking out will be the positive to hook up to any extra lighting you want to install. Remember not to overload the existing circuit.
#1051103 - 05/25/17 02:08 PM Re: rear trunk light [Re: Rich S]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
That's awesome. I was already planning on doing something similar with some LED's this weekend and now you've given me some nice instructions. Thanks!
Justin
1986 Black SS
#1051104 - 05/25/17 02:33 PM Re: rear trunk light [Re: Rich S]
Rich S Offline
Rich S  Offline
THANK YOU . THANK YOU .THANK YOU, will do,
so it was built in to the light housing. you made my day. thanks for the pic's also a great help. GOOD LUCK GOOD CRUZIN
500/thumbs/MC_lowered.jpg
by tunit
by blkcharlotteman
by PoorBoysRacing
1084/thumbs/1318197026021.jpg
by 87SSon6s
500/thumbs/IMG_1195resize.jpg
by monte_mike
