#1050942 - 05/19/17 06:56 PM Need pictures of installed aftermarket shifter
Lobito Offline
Lobito  Offline
North Bergen, NJ
Hello,
Does anyone have pictures of their installed aftermarket shifter? Trying to figure a way to mount my B&M shifter without drilling new holes.
Thank you in advance.
#1050993 - 05/21/17 10:41 PM Re: Need pictures of installed aftermarket shifter [Re: Lobito]
spacemanspif Offline
Sewell, NJ
Is your car factory column or floor shift? Column shift won't have the brackets welded to the floor for mounting a floor shifter. If it's a floor shift car I'd get flat stock or a plate, bolt the plate to the floor mounts and bolt the shifter to the plate.
-Mike
Killed a few cones too
#1051008 - 05/22/17 02:33 PM Re: Need pictures of installed aftermarket shifter [Re: Lobito]
Lobito Offline
Lobito  Offline
North Bergen, NJ
it's floor.
I was trying to get a better idea on how to bolt the front two bolts to the floor, since the stock mount locations are at a angle.
#1051089 - 05/24/17 08:23 PM Re: Need pictures of installed aftermarket shifter [Re: Lobito]
focused313 Offline
focused313  Offline
Detroit, MI
I have more, but I've done my part lol
#1051097 - 05/24/17 11:44 PM Re: Need pictures of installed aftermarket shifter [Re: focused313]
Lobito Offline
Lobito  Offline
North Bergen, NJ
Thank you Focused, but I meant how they're mounted to the tunnel.
#1051111 - 05/26/17 11:00 AM Re: Need pictures of installed aftermarket shifter [Re: Lobito]
bkmonte87 Offline
bkmonte87  Offline
Baltimore, MD
Here are the pics of mine installed hopefully you can see how I mounted it. I mounted the plate to the original 2 back holes. Then made 2 metal strips about 1" wide and 3-4"long and welded them to the plate near the front. Those also screw into the orginal holes for the shifter. I used a 1" piece of square tubing as a spacer for the front of the plate while I was mocking up the plate.
87 BLACK/SADDLE ORG.OWNER 204K
#1051115 - 05/26/17 02:50 PM Re: Need pictures of installed aftermarket shifter [Re: bkmonte87]
Lobito Offline
Lobito  Offline
North Bergen, NJ
That's perfect. Thank you very much.
#1051117 - 05/26/17 03:10 PM Re: Need pictures of installed aftermarket shifter [Re: Lobito]
I myself don't have a floor shifter. But what cable would be used? Stock OEM or aftermarket? I guess you would still use the OEM rubber boot on the tunnel. Or would you use a large rubber chassis grommet with a small hole?
#1051118 - 05/26/17 04:24 PM Re: Need pictures of installed aftermarket shifter [Re: Lobito]
bkmonte87 Offline
bkmonte87  Offline
Baltimore, MD
No Problem Your Welcome.
I used the after market cable that came with the shiftier.I just used a rubber grommet couldn't use the original hole in the floor. The cable would not line up with the hole in the floor. I was trying to cut as little as possible of the console plate.
#1051164 - 05/30/17 10:20 PM Re: Need pictures of installed aftermarket shifter [Re: Lobito]
TooSlow406 Offline
TooSlow406  Offline
Dickinson, TX
if you go with the B&M, you have to use their cable. Years ago, a friend had the Hurst Quarterstick, he was able to use a factory cable.
500/thumbs/Lamp_Bulb_Data.jpg
by Ole Blue
500/thumbs/Photo0183.jpg
by 1BadMonte
500/thumbs/IMG_1234_small.jpg
by mattvintage69
by amendez86
500/thumbs/Picture_044.JPG
by SPLATT
