#1050292 - 04/25/17 02:41 AM rear end
lonk Offline
lonk  Offline
Broken Arrow, ok
What is teh max HP that the stock rear end can handle? My rear end is all stock and in great shape. i was thinking about replacing the engine with the chevy crate engine 19210009.
https://www.summitracing.com/parts/nal-19210009/overview/make/chevrolet
Lonk
#1050300 - 04/25/17 10:33 AM Re: rear end [Re: lonk]
Razinhail Offline
Razinhail  Offline
Kansas City Area, MO
I believe I've read other people around here saying it can handle up to 300-350-ish HP. As long as you're not launching hard you should be fine, but with that motor I wouldn't take the car to the track.
Disclaimer: I have no real experience with this, that's what I've read others around here saying in other posts before. Just passing the information along.
1984 Monte Carlo SS with a stock 305 H.O. and stock TH350C
#1050304 - 04/25/17 02:02 PM Re: rear end [Re: lonk]
I still have the stock 10 bolt 7.5 open diff behind my LS3. I know its on borrowed time but I don't race, do burnouts or spin donuts. It also helps my tires are slippery Firestones. Sticky race tires would turn my rear end into spaghetti. When I go WOT, I wait until I'm past 25mph. Open diffs might be safer for street driving anyway. A Posi might send me into a wall.
#1050305 - 04/25/17 02:08 PM Re: rear end [Re: upflying]
Cheaper on tires too, just need replace one after awhile instead of two laugh
#1050307 - 04/25/17 02:59 PM Re: rear end [Re: lonk]
DiamondSnake Offline
Québec, QC
I'm still on the stock Rear-end and my current combo is on the 360-370 ish HP and 410-420lbs torque.
So far it's holding up ok. Careful on launches, but no burnouts,no racing, no Sticky Drag tires.
The best thing you can do is avoid spinning and locking tires imo, what i mean is, The worse thing you can probably do is punch the car at WOT from nill and the tires start spinning at X high rpms and then Stick hard to the pavement. (example : one wheels spins on the side of the road because of dirt and then locks up on clear pavement). That could break axles and whatever else in there.
This is the image i was given by guys at the shop. Imagine you're holding a pencil and you're pushing on the center with your 2 thumbs, the pencil bends but does not break unless you put a lot more pressure on it. if you're tires free spin and then lock hard on the pavement, it's like putting max pressure on the pencil. It will break.
I hope that makes sense?
#1050313 - 04/25/17 03:36 PM Re: rear end [Re: PB86SS/87LS]
Good point, especially since these tires are hard to find and/or not made anymore.
#1050314 - 04/25/17 03:44 PM Re: rear end [Re: lonk]
By the same token, you can probably hang 5 lbs on the middle of a pencil with both ends supported, but if you pick those 5 lbs up an inch and drop them, that pencil will soon be two pencils... In other words, shock loads break parts. Roll into the throttle and you should be ok. You might be one of the lucky ones that can absolutely beat on it without breaking anything, but don't count on it too strongly.
#1050317 - 04/25/17 04:20 PM Re: rear end [Re: lonk]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
Can you usually manage a short drive home on a blown rear or is it a tow truck job?
Justin
1986 Black SS
#1050325 - 04/25/17 08:02 PM Re: rear end [Re: Witness86SS]
Tow truck.
#1050326 - 04/25/17 08:04 PM Re: rear end [Re: Witness86SS]
Tow truck.
Its not the axles that will go its the spider gears that give up first.
When I blew up the 7.5 that was in my Monte when I bought,they looked like ground beef.
#1050328 - 04/25/17 09:02 PM Re: rear end [Re: lonk]
I would buy that engine if that is what will make you happy for the coming years, put a few bucks in making sure the 200R will handle the new power, then drive sanely and you should get good life out of the 7 1/2. It's when you dump a lot of torque on a 7 1/2 and abuse it they could give up on you. Save your money now, get that engine/trans installed, enjoy the difference another 100 hp makes.
When you change rear, costs adds up quickly, you always need a different driveshaft, complete drop in rears are expensive, then we need to throw some parts at the brakes and do some suspension improvements. Easily can amount to thousand of bucks.
#1050355 - 04/26/17 10:13 PM Re: rear end [Re: lonk]
I am also running the stock 7.5. I have only added a Auburn Posi unit and ARP wheel studs. I raced 1/4 mile every weekend running a pair of Mickey Thompson Street E. T's. My 406 with a 3200 stall making 427hp and 429trq ran 11's and 1.6 sixties coming out of the whole full throttle. I even pulled the front tires occasionally on a good track day.
I beat the snot out of it for over 10 years like that. There are a few of us that have been lucky and dodging the so called bullet with these rears. But. I guess I am a lucky one or just an anomaly lol.
#1050357 - 04/26/17 10:20 PM Re: rear end [Re: lonk]
88ss408 Offline
88ss408  Offline
miramichi, NB
I also am running a stick 7.625 rear. Do not run slicks though. No problems yet 539 tq.
1988 monte carlo ss 408 sbc
1984 monte carlo cs 400 sbc
#1050360 - 04/27/17 01:08 AM Re: rear end [Re: lonk]
My stock 3:73 limited slip never gave me an issue and worked great, even with 180k miles. 5k rpm clutch dumps at the track. If your cars an auto, the 7.5" will most likely live a long life. A lot of ls f bodys are running in the 11's on the stock rear.
560/thumbs/IMG_4430.jpg
by STREET FIGHTER
500/thumbs/DSC02417.JPG
by Rodney
1126/thumbs/1986_2.jpg
by Rich S
527/thumbs/88SS_AL_drum.jpg
1188/thumbs/FB_IMG_1476663390413.JPG
by mclellan83
