#1049612 - 04/05/17 12:05 AM Corrosion on battery terminals
Nadnerb42780 Offline
Rockland County, NY
My 86 SS won't start and someone mentioned cleaning the battery terminals. They have some corrosion on them.
Any suggestions? I watched some YouTube videos but figured ask here first.
#1049613 - 04/05/17 12:41 AM Re: Corrosion on battery terminals [Re: Nadnerb42780]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
Simple as remove connections and clean with a wire brush. They sell a tool at the auto parts store for like $3.
2015 GMC Sierra Denali
#1049633 - 04/05/17 02:03 PM Re: Corrosion on battery terminals [Re: Nadnerb42780]
Not recommended as a legitimate fix, but pouring Coca Cola on the terminals can often get one going in a roadside repair emergency type situation. I don't know that it has to be Coca Cola, but I think the high acidity and possibly some mechanical action from the carbonation that gets it broken up and cleaned off. I've used that on a number of vehicles with decent success. Obviously it's only a fix if you have corroded terminals and can't revive a dead battery or fix a faulty ignition switch smile
#1049642 - 04/05/17 03:45 PM Re: Corrosion on battery terminals [Re: Nadnerb42780]
Baking soda mixed with water cleans the battery terminals.
Use this to clean the terminals.
https://www.bing.com/images/search?q=Battery+Post+Brush&FORM=RESTAB
#1049643 - 04/05/17 05:09 PM Re: Corrosion on battery terminals [Re: Nadnerb42780]
AkronAero Offline
AkronAero  Offline
coat the terminal and cable surfaces with battery terminal coating to minimize corrosion in the future.
#1049652 - 04/05/17 10:09 PM Re: Corrosion on battery terminals [Re: AkronAero]
Back in the day, Vaseline was used to prevent corrosion.
#1049675 - 04/06/17 01:52 AM Re: Corrosion on battery terminals [Re: Nadnerb42780]
the side terminal batteries used in these cars tend to have cracks around where the connector enters/exits the battery case and corrosion is a big problem, the Delco batteries have been bad for this, good luck.
500/thumbs/photo.jpg
by tunit
536/thumbs/51.jpg
by ssmnt408
622/thumbs/Apr_20071.jpg
by cj84ss
by 94ONLYSS
