#1048367 - 02/20/17 09:32 PM Holley motor mounts and crossmember
1988SilverBulletMCSS Offline
Daytona Beach, FL
I currently installed my ls motor with Holley mounts and crossmember but I am unable to get the transmission to bolt to the crossmember... so I was wondering people that have used the Holley brand mounts and crossmember. Do you guess have the frame mounts bolt where one of the hole on the frame mounts will hang off the edge?
#1048370 - 02/21/17 05:13 AM Re: Holley motor mounts and crossmember [Re: 1988SilverBulletMCSS]
Daytona Beach, FL
Bump
#1048371 - 02/21/17 02:14 PM Re: Holley motor mounts and crossmember [Re: 1988SilverBulletMCSS]
MCSASK88 Offline
MCSASK88  Offline
Saskatchewan
What transmission are you using with your ls swap? I know I have the 4l60e and I had to order the rubber mount that goes on the transmission but that's all I needed. If your Monte is a older 80's like 80-83 I believe you may need the frame extension for your crossmember. You should be able to call Holley and give you a hand with your transmission issue if I ever figure out how to post a picture on this forum I'll post some pictures of mine soon.
1988 Monte Carlo SS LS2, Hooker Blackheart 3“ Exhaust, 4l60e transmission, 8.5' 3.42 Grand National rear end
#1048374 - 02/21/17 02:35 PM Re: Holley motor mounts and crossmember [Re: 1988SilverBulletMCSS]
How close is it to bolting up? Is it not lining up enough to start a bolt, or is it 6" away from where it should be?
#1048376 - 02/21/17 02:53 PM Re: Holley motor mounts and crossmember [Re: MCSASK88]
Daytona Beach, FL
I'm using a 4l60e and I'll get some pictures later
#1048377 - 02/21/17 02:54 PM Re: Holley motor mounts and crossmember [Re: Hunter79764]
Daytona Beach, FL
It seem like the motor and trans is prob a couple inches forward instead of back. I looked at the instructions for the Holley mounts it says you have to move the frame mounts back to a different hole from the original postion
#1048386 - 02/21/17 09:00 PM Re: Holley motor mounts and crossmember [Re: 1988SilverBulletMCSS]
MCSASK88 Offline
MCSASK88  Offline
Saskatchewan
Can your motor mounts move to a different hole further ahead on engine block? I'm sure you got it right but it doesn't hurt to double check you're mount location as there are a couple spots you can mount the motor mounts
#1048387 - 02/21/17 09:18 PM Re: Holley motor mounts and crossmember [Re: 1988SilverBulletMCSS]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
The Holley kit requires you to move the frame mounts further back from sbc location.
2015 GMC Sierra Denali
#1048388 - 02/21/17 09:52 PM Re: Holley motor mounts and crossmember [Re: 1988SilverBulletMCSS]
MCSASK88 Offline
MCSASK88  Offline
Saskatchewan
#1048390 - 02/21/17 11:35 PM Re: Holley motor mounts and crossmember [Re: 1988SilverBulletMCSS]
Pic of my 4L65E on a Holley X-member.
#1048396 - 02/22/17 01:58 PM Re: Holley motor mounts and crossmember [Re: 1988SilverBulletMCSS]
Daytona Beach, FL
Thank you all for the help and pictures I got it to mount correctly last night.
#1048441 - 02/23/17 08:25 PM Re: Holley motor mounts and crossmember [Re: upflying]
Daytona Beach, FL
Hey did you buy a new driveshaft or shorten the stock one? If so can you let me know your measurements so I can have my driveshaft shorten? Please and thank you
#1048446 - 02/23/17 10:26 PM Re: Holley motor mounts and crossmember [Re: 1988SilverBulletMCSS]
I had a shop shorten my stock driveshaft. Measurements could be slightly different so I'd suggest using a driveshaft length measuring guide. I gave these measurements to the shop and all was good. I will see if I can find the guide I used.
This is it.
http://www.dennysdriveshaft.com/app/webroot/img/File/how_to_measure_diagrams/b.html
500/thumbs/IMG_1450.jpg
by Billdo38
897/thumbs/P6070018.JPG
by Robb77
500/thumbs/Monte_003.jpg
by kpetry
500/thumbs/Tire_lift1.JPG
500/thumbs/Engineleft.jpg
by 87/88 SS's
