#1047309 - 01/19/17 01:50 AM Starting issues
00r1sc Offline
00r1sc  Offline
Jacksonville, NC
Hello everyone it's been a long time since I have posted on here but I frequently read stuff on the forum. Took the Monte for a ride the other night about 30-40 minutes and zero issues. Stopped at Lowes for literally 10 mins and came back out and nothing! Had the car towed home due to not being able to jump it and I have free towing through AMA. When I got the car home on Friday morning it started right up with no issues. I checked the battery with the car not running and it read 12.55 and over 14 while running. Tuesday the car started the same as before like nothing happened but today it won't start again. The battery is reading the same so I don't know what it could be? I am thinking the starter and gonna get it tested this weekend. Anyone ever have these issues and could possibly give me some advice? Thanks in advance.
"WE DO NOT ACCEPT APPLICATIONS ONLY COMMITMENTS"
"Opportunity is missed by most people, because it is dressed in overalls and looks like work" Thomas Edison
It's better to be fast on a slow bike than slow on a fast bike!!
#1047312 - 01/19/17 02:24 AM Re: Starting issues [Re: 00r1sc]
LXXXIV SS Offline
LXXXIV SS  Offline
Lower Peninsula, Michigan
The next time it does that,take the tire iron and smack the starter 4-5 good raps with it.
See if it starts after that.
#1047313 - 01/19/17 02:35 AM Re: Starting issues [Re: 00r1sc]
86ttop Online grandpa
86ttop  Online Grandpa
possible loose B+ cable at the starter, good luck!
#1047330 - 01/19/17 04:39 PM Re: Starting issues [Re: 00r1sc]
00r1sc Offline
00r1sc  Offline
Jacksonville, NC
Thanks, I am going to pull check the starter this weekend. I hope that's all it is.
#1047333 - 01/19/17 05:23 PM Re: Starting issues [Re: 00r1sc]
It may be heat soak for the starter. A common modification is to convert to a Ford style remote starter solenoid.
#1047338 - 01/19/17 09:59 PM Re: Starting issues [Re: 00r1sc]
Clean and tighten the battery terminals.
You have a Lowes in Okinawa Japan?
#1047349 - 01/20/17 11:23 AM Re: Starting issues [Re: upflying]
00r1sc Offline
00r1sc  Offline
Jacksonville, NC
I have took the battery loose and cleaned and tightened the terminals.
Good catch, no longer in Okinawa! I changed it to reflect Jacksonville, NC.
#1047387 - 01/22/17 02:18 AM Re: Starting issues [Re: 00r1sc]
00r1sc Offline
00r1sc  Offline
Jacksonville, NC
Starter changed and all seems good to go so far. It was a pain to do and had help from a co-worker, not sure how bad it would have been with stock headers but with the eldebrock TES ones it was a pain!
#1047426 - 01/23/17 01:57 AM Re: Starting issues [Re: 00r1sc]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
I was going to go with what Buick Runner said.
Mine does the same thing, I even have the newer F-Body small reduction-gear starter but 125 deg F outside temp, 11:0.1 compression and it's a given if I shut it off I will have to wait for it to cool.
I have a Ford solenoid and the battery is in the trunk, I am going to go to a high torque starter and maybe 2 batters in parallel.
by Monster
523/thumbs/DSC_0656.jpg
by Dad's SS
1164/thumbs/IMGP6649small.jpg
by Witman69
523/thumbs/DSC_0633.jpg
