#1046934 - 01/08/17 02:25 AM Distributor Qestion...
DC87Monte Offline
DC87Monte  Offline
Chester, Va.
I am leaning towards an hei distributor, but would like more info on them in an 87 application, it worked beautifully in my old 77 elco but I have no data on how it will work on a modern 383 stroker. And a good set of under header wires would help me complete the package...
87 Monte SS,built a 383,with a 70's block.all forged.Hamburger oil pan.Patriot 190 heads.2004r trans.Hedman headers coated in Hopewell Va.
#1046939 - 01/08/17 03:10 AM Re: Distributor Qestion... [Re: DC87Monte]
What are you running now, the GM Performance HEI would be a good place to start, good luck.
#1046942 - 01/08/17 03:24 AM Re: Distributor Qestion... [Re: DC87Monte]
AkronAero Offline
AkronAero  Offline
Ran an Mallory HEI distributor; came with the crate 383 I put in my 87. Added the Mallory 6AL box. Only a few hundred miles on (some were hard) when the carbon button on rotor disintegrated. Replaced with DUI (Davis Unified Ignition) and runs much stronger; something was wrong with the Mallory Distributor from the beginning. Much more reliable and stronger now. Lots of folks here running with the 6AL also....
Running MSD Streetfighter wires down the back and under headers. Nothing exciting and have to watch for header heat and contact. I have larger Moroso Ultra 40s for when I sort out routing and some kind of loom or tie up. It does get hot under there.... LOL!
#1046968 - 01/08/17 07:55 PM Re: Distributor Qestion... [Re: DC87Monte]
DC87Monte Offline
DC87Monte  Offline
Chester, Va.
86ttop, I dont have anything in it currently just been looking at different distributors.those $50 chinese dists are all over ebay and amazon and i have heard some good things about them, but sometimes you get what you pay for. And I would rather get a good one once and be done with it.
#1046999 - 01/10/17 02:07 AM Re: Distributor Qestion... [Re: DC87Monte]
https://www.amazon.com/ACDelco-93440806-Distributor/dp/B0013G0J9W this one may be at the best price, good luck!
#1047483 - 01/24/17 06:37 AM Re: Distributor Qestion... [Re: DC87Monte]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
This is an older post but I prefer the external HEI coil to the all-in-one HEI, GM went to back to the small distributor not only for space concerns but they run a lot hotter cutting down power, I did use an ACEL all in one unit in my 4X4 but my 1987 Monte SS came with the small cap, I used a nice Mallory CD unit with an RPM limiter and it's great!
#1047516 - 01/25/17 03:30 PM Re: Distributor Qestion... [Re: DC87Monte]
Buick Runner Online content
Buick Runner  Online Content
From what I have read, there are lots of design flaws and issues caused by having the coil in the cap. Besides running hotter, the coil creates EMI that interferes with the module and pickup coil from being so close. Coil in caps also suffer voltage leakage.
#1047541 - 01/26/17 04:18 AM Re: Distributor Qestion... [Re: DC87Monte]
The PC Surgeon Offline
Salisbury Mills, NY
You also cannot phase the rotor of an HEI if needed (I've seen someone rig one together but it was crappy at best). The HEI is a good start but the weights corrode/surface rust and stick open on the Chinese models, causing you to have a high timing at idle. Running rough and stalling at idle. Get a Good HEI with good coated weights to avoid this issue. If you need to phase the rotor, HEI is not the way to go.
#1047547 - 01/26/17 08:48 AM Re: Distributor Qestion... [Re: DC87Monte]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
Buick Runner and The PC Surgeon is on target with this one.... stay away from 'in cap' HEI coils, these were built so they could save money by having a single unit to drop in and go... nothing high tech or high performance about them!
#1047551 - 01/26/17 02:35 PM Re: Distributor Qestion... [Re: AkronAero]
1owner83SS Offline
1owner83SS  Offline
Kenosha Wi.
MSD makes the 6AL box, I have run a MSD billet distributor, 6AL and MSD coil for over 20 years now without touching it, not a dd though.
1983 Monte Carlo SS our first new car.
500/thumbs/306537_10151142014953465_994827867_n.jpg
by adi
500/thumbs/CH220175compressed.JPG
by John S
500/thumbs/SS_on_22_inch.jpg
by G-bodySS
1130/thumbs/ResizedImage_1390834191345.jpg
by O.G.
500/thumbs/IMG_0552.JPG
by montesleeper83
