#1046295 - 12/12/16 10:40 PM ls swap questions
1988SilverBulletMCSS Offline
Daytona Beach, FL
does anyone know if the stock coil location bracket will work with the holley ls swap mounts?
also has anyone used dakota digital bim-1-2... does it display the gear position?
please and thank you
#1046338 - 12/15/16 03:14 AM Re: ls swap questions [Re: 1988SilverBulletMCSS]
MCSASK88 Offline
MCSASK88  Offline
Saskatchewan
It worked with mine I just had to cut the back part of the bracket a bit and had to cut the back holder stem on the valve cover by the HVAC box just to be safe
1988 Monte Carlo SS LS2, Hooker Blackheart 3“ Exhaust, 4l60e transmission, 8.5' 3.42 Grand National rear end
#1046347 - 12/15/16 11:29 AM Re: ls swap questions [Re: 1988SilverBulletMCSS]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
Just be aware for bolt in reasons clearing properly, the Holley plates are designed to fit with the Holley pan and holley accessories. Those that have mismatched those mounts with other parts have fitment issues.
2015 GMC Sierra Denali
#1046396 - 12/17/16 06:26 AM Re: ls swap questions [Re: Jameson]
Daytona Beach, FL
Ok I have the pan also
#1046397 - 12/17/16 06:27 AM Re: ls swap questions [Re: MCSASK88]
Daytona Beach, FL
Ok thanx I guess I'll see when I get it in dere
#1046633 - 12/28/16 02:31 AM Re: ls swap questions [Re: 1988SilverBulletMCSS]
Daytona Beach, FL
can someone identify these images and tell me what they are for
#1046634 - 12/28/16 03:13 AM Re: ls swap questions [Re: 1988SilverBulletMCSS]
speeddemon Offline
speeddemon  Offline
NW Iowa
Picture 1 and 5 are both part of the fusebox,
2 and 3 is wiring and controls for the cruise control
4 is the vacuum lines for the hvac system
6 is the connectors for the ECM
Jeff J
#1046635 - 12/28/16 04:09 AM Re: ls swap questions [Re: speeddemon]
Daytona Beach, FL
Thanks does anyone have the pin it for the fuse box so I can remove some of these wires to clean it up??
Also the vacuum lines for the ac goes where after ls swap?
#1046639 - 12/28/16 03:47 PM Re: ls swap questions [Re: 1988SilverBulletMCSS]
You will need this manual to perform the LS swap. I could not do mine without it.
http://www.ebay.com/itm/1988-Chevrolet-Monte-Carlo-Electrical-Diagnosis-Service-Manual-Supplement-GM-/262114883901?hash=item3d0743b93d:g:KM4AAOSwI-BWL9tQ&vxp=mtr
#1046640 - 12/28/16 04:37 PM Re: ls swap questions [Re: 1988SilverBulletMCSS]
spacemanspif Offline
Sewell, NJ
This pic always helped me when rerunning wires and removing what isn't necessary.
The main vacuum source for the HVAC will need to be connected to another vacuum source to work the vents.
-Mike
Killed a few cones too
#1046641 - 12/28/16 05:43 PM Re: ls swap questions [Re: 1988SilverBulletMCSS]
On the truck intake (if that is what you are using), some years had incomplete vacuum bosses molded in to the intake. You can trim the plastic plugging the end and tap into it. Or if you are running an earlier year with vacuum referenced fuel pressure regulator on the fuel rail, you can just Tee off of that line.
Here's a pic.
http://www.diymetalfabrication.com/wp-content/uploads/2014/12/IMG_6391.jpg
#1046695 - 12/30/16 08:22 PM Re: ls swap questions [Re: 1988SilverBulletMCSS]
Daytona Beach, FL
this comes from by the harness by the ac box i know that the red wire is for power to ac relay but what is the other two wires?
i know that the one of these is a map sensor but what is the other two sensors the one connected goes with the wires near ac and it is mounted on the pass wheel well
#1046735 - 01/01/17 06:38 PM Re: ls swap questions [Re: 1988SilverBulletMCSS]
Daytona Beach, FL
Bump
#1046793 - 01/03/17 02:34 AM Re: ls swap questions [Re: 1988SilverBulletMCSS]
Sewell, NJ
The stuff on the passenger wheel well is the barometer, WOT relay and something else for the computer. I'm pretty sure the big read wire is the power for the vent fan.
-Mike
#1046795 - 01/03/17 02:52 AM Re: ls swap questions [Re: spacemanspif]
Daytona Beach, FL
Ok thanx do you known what the green and light green wires are?
500/thumbs/monte_0061.JPG
by bootlegger
500/thumbs/1985_monte.JPG
by Hostile
536/thumbs/51.jpg
by ssmnt408
500/thumbs/SS5.JPG
by IowanSS
857/thumbs/Ram_Air_small.jpg
by 86SSmonte350
