#1045528 - 11/19/16 05:00 AM Axle Leak
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Guys, I got a leak coming from the differential housing. Not the rear cover but what looks like a plug weld as shown in the photo below. Looks like GM used a plug weld to secure the axle tubes to the housing. If I'm right, maybe the weld has a few pin holes. I'm thinking I could grind some of the weld out and fill with some pc7 epoxy. Any ideas on how to stop this leak?
#1045532 - 11/19/16 12:40 PM Re: Axle Leak [Re: Fred SS]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
I'd use brake clean, then lightly rough the area and clean with some light grinding and then jb weld it.
2015 GMC Sierra Denali
#1045533 - 11/19/16 01:20 PM Re: Axle Leak [Re: Fred SS]
MecGen Offline
MecGen  Offline
Montreal Canada
Thats weird, the axle tube gets pressed fit deeper past that plug, but hey who knows.
With out a doubt try appoxy, worst case get another diff, they can be found pretty cheap.
RedHotChilliPeppers.
1987 MCSS.- Sold
1984 MCSS.- Sold
1984 MCSS - came back smile
1995 Mustang 5.0
1965 Pontiac GTO
1969 Pontiac Firebird
#1045535 - 11/19/16 02:29 PM Re: Axle Leak [Re: Fred SS]
That's a common problem, most of the time it's a very minor leak. When I built the 8 1/2" rear I had the tubes welded to the center section and had the plug welds "dressed", re-welded, to avoid that problem. If you got the plug clean enough you could try epoxy, I prefer PC7 over JB weld for repairs like that.
#1045538 - 11/19/16 02:52 PM Re: Axle Leak [Re: Fred SS]
pretty common, clean with brake clean and some kind of epoxy will do the trick!
#1045540 - 11/19/16 06:29 PM Re: Axle Leak [Re: Fred SS]
IMO, that's a weep not a leak. There is so little, I wouldn't worry about it beyond wiping the area occasionally.
#1045549 - 11/20/16 01:05 AM Re: Axle Leak [Re: Fred SS]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Upflying, your probably right. It would be considered a weep not a leak since the fluid does not drip off the diff. But I'm gonna clean the area and try some epoxy. I'm in the process of replacing the fluid anyway.
Thanks guys for your suggestions.
#1045584 - 11/20/16 11:16 PM Re: Axle Leak [Re: Fred SS]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
I cleaned the area with brake cleaner and purple stuff (cleaner). Looks like it's an incomplete weld. GM missed a spot at the top. As some of you said, epoxy should fix that.
#1045592 - 11/21/16 01:30 AM Re: Axle Leak [Re: Fred SS]
Have seen many porous plug welds on rears, seepers. Think it may have something to do with the "can't see it from my house" mentality. My brother-in-law worked at the local plant that built truck frames for GM many years ago, he said it was up to the final touchup guys at the end of the line to make sure most everything was welded correctly, but. How many times have I read about a frame off resto were a lot of time was spent dressing factory welds.
So porous plug welds, there are a lot of them out there.
#1045774 - 11/26/16 08:02 AM Re: Axle Leak [Re: Fred SS]
A porous weld means a weak weld. I would fix it right by drilling the plug out and reweld it right.
500/thumbs/photo.jpg
by tunit
536/thumbs/51.jpg
by ssmnt408
622/thumbs/Apr_20071.jpg
by cj84ss
by 94ONLYSS
