#1045124 - 11/07/16 10:37 AM welded door striker
gula187 Offline
gula187  Offline
Baton rouge, LA
I been having my car for almost a year and im just paying attention to this. Do you guys this will become a problem?
#1045125 - 11/07/16 11:51 AM Re: welded door striker [Re: gula187]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
At some point it may, don't know why it was welded since it's supposed to thread in.
2015 GMC Sierra Denali
#1045128 - 11/07/16 01:33 PM Re: welded door striker [Re: gula187]
markg Offline
markg  Offline
nj
the problem with this is that you cannot adjust it anymore.usually "at least what ive seen and done"is to weld a plate behind the washer.this way tou can still move the post around.
#1045130 - 11/07/16 01:53 PM Re: welded door striker [Re: gula187]
guitars Offline
guitars  Offline
Toronto, Canada
But if it's located properly to align the door there is no need to worry about future adjustments.
90's GM trucks had a 2" dia washer next to the body instead of the 1" G body washer - wonder if the truck washer is a worthwhile addition to the car strikers increasing the support area?
#1045134 - 11/07/16 03:19 PM Re: welded door striker [Re: gula187]
The sheet metal around the door striker bolt is prone to breakage and fracture due to constant slamming of a door with bad hinges. My car had this problem.
I had the fractures welded and then I installed a reinforcing plate..from turbobuick I think. After fixing the hinges and aligning the door, I had no further problems. Since you need to move the striker bolt around, welding the striker bolt was a bad idea. You also need to remove the bolt to align the door. This is what the plate looks like although this is not my car. Op you also need a new seatbelt release lever.
#1045168 - 11/07/16 10:54 PM Re: welded door striker [Re: gula187]
gula187 Offline
gula187  Offline
Baton rouge, LA
What are my options to repair it?
#1045245 - 11/10/16 03:33 AM Re: welded door striker [Re: gula187]
MecGen Offline
MecGen  Offline
Montreal Canada
The only way is to slowly grind off the weld, remove the striker, prime and paint, then reinfoce the area like the above post.
But I would guess the striker was welded because the thredded plate in behind that panel is strpped, you need to remove the rear seat and corner trim to access the area behind the striker to repair.
Awesome idea for the reinforcement plate anyways needed or not.
Regards
RedHotChilliPeppers.
1987 MCSS.- Sold
1984 MCSS.- Sold
1984 MCSS - came back smile
1995 Mustang 5.0
1965 Pontiac GTO
1969 Pontiac Firebird
#1045247 - 11/10/16 05:06 AM Re: welded door striker [Re: gula187]
Agreed that it is likely a quick fix for a stripped plate. See quick weld repairs like this on old tractors all the time and a pita to correct. Possible that it may be a quick fix from a collision.
500/thumbs/IMG_1450.jpg
by Billdo38
897/thumbs/P6070018.JPG
by Robb77
500/thumbs/Monte_003.jpg
by kpetry
500/thumbs/Tire_lift1.JPG
500/thumbs/Engineleft.jpg
by 87/88 SS's
