#1041172 - 07/06/16 07:38 PM Custom Upper Radiator Hose???
Crusher Offline
Crusher  Offline
Jersey Shore
Pics of custom upper radiator hose if anyone has one please.
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
637 RWHP 587 TQ
http://SSMonteCarlo.com
#1041175 - 07/06/16 08:18 PM Re: Custom Upper Radiator Hose??? [Re: Crusher]
The PC Surgeon Offline
Salisbury Mills, NY
http://shop.hosecandy.com/rad-hose-kits/
or make a custom AN hose. Not hard to do.
#1041177 - 07/06/16 08:38 PM Re: Custom Upper Radiator Hose??? [Re: Crusher]
Crusher Offline
Crusher  Offline
Jersey Shore
Not bad but I guess you need to have extra shrink wrap couplers in case you need to remove the hose.
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
637 RWHP 587 TQ
#1041182 - 07/06/16 10:22 PM Re: Custom Upper Radiator Hose??? [Re: Crusher]
Buy one for a 1976 Trans am. That's what I always ran on many other builds. They fit great and look much cleaner withouit all those extra bends.
See Jason onebadbowtie thread with the 383, I believe he used one too after seeing mine.
#1041185 - 07/06/16 11:08 PM Re: Custom Upper Radiator Hose??? [Re: Crusher]
Salisbury Mills, NY
10-4
#1041198 - 07/07/16 11:33 AM Re: Custom Upper Radiator Hose??? [Re: 1 Slow SS]
Crusher Offline
Crusher  Offline
Jersey Shore
I use that now. Just looking to make it more custom without being to over the top. I do like the Hose candy black sleeve but not sure I want to do away with the clamps. Love the clean look of the shrink coupler but concerned that for some reason I need to remove the hose. Even if I carry extra shrink couplers not likely I'm going to have a heat gun handy on the road. I wonder if you could use a clamp if you had to in an emergency situation?
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
637 RWHP 587 TQ
#1041201 - 07/07/16 01:28 PM Re: Custom Upper Radiator Hose??? [Re: 1 Slow SS]
Any pics of one in a Monte?
#1041214 - 07/07/16 06:15 PM Re: Custom Upper Radiator Hose??? [Re: Crusher]
I'd think you could use a regular hose clamp in a roadside emergency situation, but I can't say for sure. Also, I don't know how much heat is needed to shrink the tubing, but would it be an option to install a heat shrink clamp over the hose attached to the radiator, then leave the cap loose (no pressure in the system) until the car warms up, using the heat of the coolant to shrink the tubing? I've done something similar with electrical heat shrink before, getting it in place and letting engine/component heat get it the rest of the way. Just a thought.
#1041215 - 07/07/16 06:42 PM Re: Custom Upper Radiator Hose??? [Re: PB86SS/87LS]
Crusher Offline
Crusher  Offline
Jersey Shore
Check this thread. http://www.montecarloss.com/community/ub...208#Post1038208
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
637 RWHP 587 TQ
500/thumbs/DSCN0025.jpg
by Aeroaddict
957/thumbs/P6144108.JPG
by SSLANE
527/thumbs/88SS_console2.jpg
500/thumbs/20170119_090447.jpg
by Rodney
500/thumbs/P7290021.JPG
by sslos
