#1041102 - 07/05/16 12:49 PM Rear defrost stuck on
steve40 Offline
steve40  Offline
Windsor, Ontario
I've noticed that the rear defrost is always on when I start the car up. Any ideas what this points to? Not really sure where to start to diagnose this one
#1041103 - 07/05/16 01:19 PM Re: Rear defrost stuck on [Re: steve40]
The PC Surgeon Offline
Salisbury Mills, NY
You may want to replace the rear defogger switch. If the switch is warm after a few moments, disconnect it all together until you can replace it. you can also check the fuse in the panel to begin the troubleshooting steps.
#1041183 - 07/06/16 10:33 PM Re: Rear defrost stuck on [Re: steve40]
There is a timer in the system, probably the problem, good luck.
500/thumbs/15.JPG
by Phifdawg
500/thumbs/IMG_4826.jpg
by T-TopGene
500/thumbs/birnamwoodshow_022.JPG
by Intmdatr3
500/thumbs/100_1610.jpg
by myfirstmontess
500/thumbs/Monte_Carlo_at_CCWD-14.jpg
by upflying
