NJ Monte Carlo Parts For Sale
I have a lot of parts to sell since I've sold my Monte Carlo last month.
Too many parts to keep listing individually. PM me for picture requests. All Shipping Is Priced To The Lower 48 Only
1.) Jeep Steering Shaft. 50 Shipped.
2.) Brand new PUI F910-1 - PUI Interiors Window-felt Weather Stripping Kit. This kit is for both inner and outer window felts that fits 1978-79 81-88 Monte Carlo's $85 shipped.
3.) Hi Torque Mini Starter is listed in the forum for Engine parts for sale. $85 shipped.
4.) New Complete T-Top weather stripping kit. Includes left and right t-top panel seals, main t-top frame weatherstripping, and top plate(vibration) seals. $140 shipped.
5.a) Like New 78-88 GM OEM (not reproduction visors that some vendors are selling) Maroon Monte Carlo Sun Visor Set With Brackets. $75 Shipped
5.) New Maroon Monte Carlo Bow-Tie Embossed Visors 78-88 Sun Visor Set $90 for the pair. (buy both the console lid with the bow-tie embossed matching visors together for $175 shipped) As far as I can tell these are no longer being made.
6.) New Maroon Monte Carlo Bow-Tie Embossed Console Lid 78-88 Console Door Assembly (w/ metal hinge) $100 shipped (buy both the console lid with the bow-tie embossed matching visors together for $175 shipped) Can Be Re-Painted Any Color To Match Your Interior. As far as I can tell these are no longer being made.
7.) Monte Carlo SS Front & Rear Seats $450 (Listed In The For Sale Interior Forum)
8.) Very Nice Maroon Driver Quality Upper Door Panels & Rear Sail Panel Inserts (With Minimal If Any Sun Fade On Panels And Very Minimal Imperfections) That Match The Monte Carlo SS Front & Rear Seats I Have Listed In The For Sale Interior Forum. Should Be Purchased As A Complete Package. $200 If Sold Separately. Buy The Whole Package For $600.00
9.) Monte Carlo G Body Fuel Tank With Sending Unit. Solid Gas Tank, No Leaks And With Very Minimal Exterior Surface Rust. Top Side Just Needs To Be Hit Lightly With A Wire Wheel Or Brush And It's Ready For Paint. $50.00 Local Pick-up Only
10.) 78 to 88 Monte Carlo Door Hinge/Jam Donor Metal (Listed In The For Sale Exterior Forum)
11.) Monte Carlo Clean Rocker Panels, Rust Free L&R (Listed In The For Sale Exterior Forum)
12.) Two 78' to 88' OEM Monte Carlo Floor Pans (Listed In The For Sale Exterior Forum)
13.) Hooker 2050 Emission Legal Headers (Listed In The For Sale Engine & Drive-train Forum)
14.) Very Nice Pair Of OEM 87 Rear Taillights. Lenses Have No Cracks. $165.00 For The Pair Shipped
15.) 12" Dual Diaphragm Brake Booster With Attaching Paw & Master Cylinder. Very Minor Surface Rust As Pictured $75.00 Shipped
16.) Very Clean Monte Carlo Passenger Side OEM Full Quarter Panel. 99 Percent Rust Free. $125.00 Local Pick-up Only
17.) Driver Side OEM Donor Rear Lower Quarter Patch Panel $30 Shipped
18.) Gray Glove Box Great Shape. Can Be Re-Painted/Re-Dyed Any Color To Match Your Interior $30.00 Shipped.
19.) Gray Metal Dash Speaker Grilles. Can Be Re-Painted/Re-Dyed Any Color To Match Your Interior. $20.00 Shipped For The Pair
20.) Rear Burgundy Seat Belts Very Clean No Sun Fade. Black Stuff On The One Belt Is Just Some Asphalt Trunk Liner From Being Stored In My Trunk. Will Clean Right Off. $40.00 Shipped
21.) Never Used Monte Carlo Flanged Catalytic Converter By-Pass Test Pipe. $35.00 Shipped.
22.) OEM Factory Catalytic Converter. Good Shape & Painted In High Temp Gray Paint. $70.00 Shipped.
23.) Pair Of Very Lightly Used DynoMax Super Turbo Mufflers. These Are Performance Mufflers Made By Walker As A Direct OEM Replacement Muffler For The Monte Carlo SS. Mufflers Have A Slight Cosmetic Ding In Rolled Seam Area From Removal. Dose not Affect Performance. $75.00 For The Pair Shipped
24.) Monte Carlo Rear Brake/Taillight Wiring Harness. All Sockets, Connectors And Terminals Are In Excellent Shape. $25.00 Shipped
25.) SBC 305 Monte Carlo Headers And true Dual Exhaust With Flow Master Mufflers. Has Surface Rust But All Pipes And Header Flanges Are Solid. $175 Local Pick Up Only.
26.) Two Black Shift Plates. Good Shape With No Cracks. One Is Smooth SS Style, The Other Is Textured. Can Be Re-Painted/Re-Dyed Any Color To Match Your Interior. $20 each Shipped
27.) One Gray Center Console With Coin Tray/No Console Lid. Has A Only One Small Crack (have pic of crack) That Can Easily Be Fixed. Can Be Re-Painted/Re-Dyed Any Color To Match Your Interior. $55.00 Shipped.
28.) Nice & Smooth Working Heater/Ac Switch Control Switch With No Broken Tabs. Has Good Cable Loops On Both Ends $15.00 Shipped.
29.) Brand New Mr. Gasket #6562 New 1-Piece, Rubber/Steel Core Oil Pan Gasket Set Fits 5.0/5.7L 35.00 Shipped
30.) I Have Two Complete Sets Of OEM Gray L/R Lower Door Panels. This Is A Total Of 4 Panels. All Panels Are In Fantastic Shape With Minimal If Any Sun Fade On Panels Or Carpet Areas. All Panels Have Their Respective Power Door Lock Switches And All Clip Fastener Holders Are Intact. Can Be Re-Painted/Re-Dyed Any Color To Match Your Interior. $110 Per Each Matching Pair Shipped.
31.) One Pair Of Used Gray OEM 78-88 Upper Door Panels With Pull Straps. In Good Driver Quality Shape With Very Little Sun Fade Or Stains. $75.00 Per Pair Shipped
32.) Set Of Four Monte Carlo N90 Wheels With Center Caps And Very Nice Tires. All Tires Are Balanced Just Mount And Go. $300 For The Set / With Tires. Local Pick-Up Only.
33.) Set Of Four 84-85 15-Inch SS Style Rally Wheels With Excellent Tires. Tires Are Already Balanced Just Mount And Go. $275 For The Set / With Tires. Local Pick-Up Only.
34.) 87-88 Monte Carlo OEM A/C Condenser. Worked Perfectly Before Being Pulled And Cleaned Internally Of All R12 Refrigerant And Prepped For R134 Refrigerant. $40.00 Shipped
35.) Very Nice And Complete A/C Engine Side Assembly With Dash Side Duct Work With Working Blower Motor, Heater Core, An Evaporator That Has Been Cleaned Of All R12 Refrigerant And Prepped For R134 Refrigerant. All Connectors & Vacumm Lines Are Intact. $145 Shipped.
36.) Nice Working OEM Light Switch With No Cracks. $13.00 Shipped.
37.) Pair Of Nice & Tight 78-88 Hood Hinges. $20 Shipped.
38.) Two Hood Release Latches Complete With Good Pull Handles & Cable ends. $25.00 A Piece Shipped
39.) Very Nice OEM Cruise Control Diaphragm With Bracket $22.00 Shipped.
40.) Hard To Find OEM L69 305 (may fit 5.7l) Plastic Flywheel/Torque Converter Cover. No Cracks And All Mounting Tabs Are Fine. Covers A Little Dirty But Will Clean Up Prior To Sale. $40 Shipped.
41.) Gray Upper & Lower Rear Seat Panel Side Set With Very Nice Seat Belts. $80 Shipped
42.) 78-88 OEM Monte Carlo Rust Free Rear Trunk Pan From The Spare Tire Well Over. This Is Not The Korean/Chinese Junk Sherman Sells. Has A Minor Reciprocating Saw Cut Through That Can Very Easily Be Welded Up And A Slight Corner Ding That Can Be Easily Strengthened Out. $175.00 Shipped.
43.) Two Very Nice 78-88 OEM Monte Carlo Door Sill Plates With Intact Body By Fisher Tags. I Took Some Blue Magic Metal Polish To The Center Sill Plate And It Polished Right Up Rather Nicely With Very Little Effort. Throwing In The 3rd Sill Plate Pictured For Free. $70.00 Shipped For All Three.
44.) Pair Of OEM Locking T-Tops With Genuine GM T-Top Bags. Both T-Tops Glass Have Nice Mirror Tinting & T-Top Bags Are In Excellent Shape. One T-Top Molding Has A Small Crack In The Plastic And One T-Top Molding Is Missing A Small Piece Of Plastic On The End. T-Top Bags Have A Couple Of Very, Very, Minor Nicks On Edge Of Bags. Asking $250 For Everything. Might Sell Just The Bags For $80 Shipped. (PM me to ask for pics) Local Pick-Up Only On T-Tops.
45.) Very Solid And 99% Rust Free OEM Trunk Lid. No Spoiler. $100 Local Pick-Up Only
46.) Nice 99% Rust Free OEM Driver Side Fender. $100 Local Pick-Up Only
47.) Pair Of 99% Rust Free OEM 87' Style Doors. No Bondo Anywhere On These Doors. Very Straight With Very Minor Surface Rust That Will Clean Up Easily With A Wire Wheel In Minutes. $125 Each. Local Pick-Up Only (PM me to ask for pics)
48.) Nice Set Of 4 GM OEM 15" Stainless Steel Rally Wheel 2" Trim Rings. Trim Has A Ding $45.00 Shipped For All 4 Rings.
49.) Maroon SS Instrument Cluster With 120-mph Speedometer, With All 4 Gauges, Shadow Box, Copper Ribbon Circuit Board, Clear Lens (shows some clouding but is not chipped or cracked) Nice Outer Trim Bezel. There Are Chips Missing From Back Side Of Cluster Mounting Tabs. Nothing Was Tested. Asking $60 Shipped
50.) 78-88 "B" Pillar Trim Set. Nice Condition. (roof to floor) Can Be Re-Painted/Dyed Any Color To Match Your Interior. $45 Shipped.
Again, Send Me A PM If You Need Some Pics Of Anything Listed Above.
Rob
G
G
Pm sent.
Instrument cluster with all gauges and shadow box SOLD to GNX89.
Jeep Steering Shaft & OEM light switch are $OLD.
Had a busy Saturday & Sunday.
Here's what been sold between the forum & Craigslist.
26.) Two Black Shift Plates ( just one of them is sold. Still have one more)
47.) Pair Of 99% Rust Free OEM 87' Style Doors (both doors are sold)
If there's anything I have here for sale that anybody is interested in please don't be shy and make me an offer.
Rob
Q
QS Offline
Q
pm sent
#12 Both green floor pans are $OLD.
Still have the white sectioned floor pans for sale.
And #42 the 78-88 OEM Monte Carlo Rust Free Rear Trunk Pan is sold.
I have a lot of stuff for sale that is posted on craigslist with pictures.
The link below will take you to a gallery of what is still for sale.
http://cnj.craigslist.org/search/sss?userid=94538787
Numbers 28 & 35 have been $OLD
Number 14 OEM 87 Rear Taillights Are Sold To FredSS
Here's an updated list of what I have for sale still. The link below has pictures of everything listed here.
(1.) Brand New Auburn Gear High Performance Series Differentials 542057 & A Timken DRK320 Ring and Pinion Gear Installation Kit (BEARING AND SEAL KIT.)
(2.) 4 Piece Maroon Floor Mats
(3.) Maroon Front Passenger Lower Door Panel
(4.) Monte Carlo Front Wind shield Windshield
(5.) 4 84-85 15" SS Style Rally Wheels With Good Tires
(5A.) Four Monte Carlo SS N90 Wheels With Center Caps & Good Tires
(6.) New Complete T-Top weather stripping kit. Includes left and right t-top panel seals, main t-top frame weatherstripping, and top plate(vibration) seals.
(7.) Like New Maroon Monte Carlo Sun Visors Set With Excellent Chrome Hinges
(8.) Monte Carlo SS Bow-Tie Embossed Sun Visors
(9.) Monte Carlo Gbody Bow-Tie Embossed Console Lid With Metal Hinge
(10.) Monte Carlo SS Rear Seat, Burgundy Seat Belts
(11.) New Black Chevy Monte Carlo Gbody Auto Carpet
(12.) 1985 Monte Carlo SS Front & Rear Seats
(13.) Nice 1985 Maroon Monte Carlo SS Door Panels & Rear Sail Panel Inserts
(14.) Monte Carlo SS OEM Locking T-Tops With Genuine OEM GM T-Top Bags
(15.) Monte Carlo Shift Plate
(16.) Monte Carlo OEM Gray L/R Lower Door Panels
(17.) Monte Carlo Gray OEM 78-88 Upper Door Panels With Pull Straps
(18.) Monte Carlo Gray Upper & Lower Rear Seat Panel Side Set
(19.) Monte Carlo 78-88 OEM Pair Of Door Sill Plates
(20.) Monte Carlo Gray Glove Box
(21.) 12" Monte Carlo Gbody Dual Diaphragm Brake Booster
(22.) Monte Carlo Flanged Catalytic Converter By-Pass Pipe
(23.) OEM Monte Carlo SS Catalytic Converter
(24.) Monte Carlo SS OEM Style DynoMax Super Turbo Mufflers
(25.) Monte Carlo SS Headers & Flowmaster Dual Exhaust System
(26.) Monte Carlo Rear Brake/Taillight Trunk Wiring Harness
(27.) Monte Carlo OEM A/C Condenser
(28.) Monte Carlo 78-88 Hood Hinges
(29.) Monte Carlo Hood Release Latches
(30.) Monte Carlo OEM Cruise Control Diaphragm
(31.) 78 to 88 Monte Carlo Door Hinge/Jam Donor Metal
(32.) 78' to 88' OEM Monte Carlo G Body Floor Pan
(33.) Monte Carlo Passenger Side OEM Full Quarter Panel
(34.) Monte Carlo Driver Side OEM Rear Lower Quarter Panel Patch Panel
(35.) Monte Carlo SS 99% Rust Free OEM Trunk Lid
(36.) Monte Carlo SS 99% Rust Free OEM Driver Side Front Fender
(1.) Auburn Posi & Timken Bearing/Seal set is $OLD.
Has been $OLD!
All items listed above have been $OLD
(5.) 4 84-85 15" SS Style Rally Wheels With Good Tires And Extra Set Of Polished Stainless Steel Trim Rings.
$0LD
Are all $OLD
I'm accepting any reasonable offers on any of the parts listed below.
(4.) Monte Carlo SS Bow-Tie Embossed Sun Visors
(5.) Monte Carlo SS Rear Seat, Burgundy Seat Belts
(6.) New Black Chevy Monte Carlo Gbody Auto Carpet
(7.) Monte Carlo SS OEM Locking T-Tops With Genuine OEM GM T-Top Bags
(8.) Monte Carlo OEM Gray L/R Lower Door Panels
(9.) Monte Carlo Gray OEM 78-88 Upper Door Panels With Pull Straps
(10.) Monte Carlo Gray Upper & Lower Rear Seat Panel Side Set
(11.) Monte Carlo 78-88 OEM Pair Of Door Sill Plates
(12.) Monte Carlo Gray Glove Box
(13.) 12" Monte Carlo Gbody Dual Diaphragm Brake Booster
(14.) Monte Carlo GBody Flanged Catalytic Converter By-Pass Pipe
(15.) OEM Monte Carlo SS Catalytic Converter
(16.) Monte Carlo SS OEM Style DynoMax Super Turbo Mufflers
(17.) Monte Carlo Rear Brake/Taillight Trunk Wiring Harness
(18.) Monte Carlo OEM A/C Condenser
(19.) Monte Carlo 78-88 Hood Hinges
(20.) Monte Carlo Hood Release Latches
(21.) Monte Carlo OEM Cruise Control Diaphragm
(22.) 78 to 88 Monte Carlo Door Hinge/Jam Donor Metal
(23.) Monte Carlo Passenger Side OEM Full Quarter Panel
(24.) Monte Carlo Driver Side OEM Rear Lower Quarter Panel Patch Panel
(25.) Monte Carlo SS 99% Rust Free OEM Trunk Lid
(26.) Monte Carlo SS 99% Rust Free OEM Driver Side Front Fender
B
B
do you have the 3 piece rear window trims? do you have a passenger door handle
Are you talking about the rear window exterior window trim?
If so, then I don't have that and I also don't a passenger door handle.
All the items listed above are $OLD.
Heres the new link to CL of all the parts I have for sale.
Burgundy Seat Belts Are $OLD
(25) Monte Carlo Trunk Lid
$OLD
Still available?
0 members (), 161 guests, and 10 robots.
mavbeacon, rjanders, ThatBlue84SS, Socortes, jessenb
16,025 Registered Users
