#1035114 - 02/15/16 06:49 AM Tubular a-arm options
86_SS Offline
86_SS  Offline
League City, TX
Tried searching but haven't had much luck so hopefully someone here knows the answer.
I currently have tubular upper a-arms from speedwaymotors.com and want to entertain the idea of tubular lowers. Has anyone ever used a set from an A-body car. When I was googling tubular lowers for our g-bodies, it directed to speedwaymotor to a kit containing tubular upper and lowers for a A-body (see link) http://www.speedwaymotors.com/Speedway-1964-72-GM-A-Body-Chevelle-Tubular-Control-Arms,81680.html?sku=91036472&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&catargetid=530009170000092199&cadevice=t&gclid=CJCA9MGP-coCFQyEaQodh3YGig
In the pics and others I have looked up on google, they appear to be the same as the body arms. Does anyone know for sure?
#1035119 - 02/15/16 01:15 PM Re: Tubular a-arm options [Re: 86_SS]
ramey36 Offline
ramey36  Offline
Philipsburg, PA
Appearance is similar but every measurement is different. At UMI we've had customer calls of guys trying to interchange to no avail...
#1035123 - 02/15/16 03:13 PM Re: Tubular a-arm options [Re: 86_SS]
86_SS Offline
86_SS  Offline
League City, TX
I figured that would be the case. I was surprised how similar they looked. Thanks for the response
#1035124 - 02/15/16 03:17 PM Re: Tubular a-arm options [Re: 86_SS]
ramey36 Offline
ramey36  Offline
Philipsburg, PA
No prob!
Besides the fact the arms don't physically fit the mount-
The lower arm really does set the layout of the front suspension and all of the measurements are super-critical. We try to hold tolerances literally within a few thousandths concerning inner pickup points vs ball joint location as well as accuracy of spring bucket location and height.
ramey
#1035125 - 02/15/16 03:22 PM Re: Tubular a-arm options [Re: 86_SS]
86_SS Offline
86_SS  Offline
League City, TX
Yea that's why I figured something had to be different for controls from an a-body vs a g-body. A lot of a-arms look very similar to each other now that I start looking. The first set I looked at were lowers for an s10, the same we use for the spindle swap.
That's why I love this forum though. So much knowledge and always at least someone that knows or can find the answer.
Thanks again
#1035126 - 02/15/16 03:34 PM Re: Tubular a-arm options [Re: 86_SS]
MC96 Offline
MC96  Offline
St. Johns MI
The only other GM arms that fit our cars are 67-69 camaro and 68-74? Nova (theyre the same) front arms, switched side to side.
They work well on dirt modifieds, but I would imagine moving the lower ball joint 1.5" forward and 1.5" out would look a little goofy in the wheel hole.
Most of the GM stuff physically looks the same, especially the a-body stuff.
86 SS
In progress
#1035918 - 03/05/16 05:12 AM Re: Tubular a-arm options [Re: 86_SS]
JBreu Offline
JBreu  Offline
Livonia,N.Y.
What's the benefit of the tubular lower control arms over the stock ones besides bragging rights?
1984 Monte Carlo sbc bored/stroked to 388 c.i. 514 Dynoed HP.700r4 w/2000 stall,12 Bolt w/4:10
Old Chevy's Don't Die, They Just Get Faster
Best E.T. to date : 12.20 @ 110 MPH All Motor
#1035920 - 03/05/16 12:49 PM Re: Tubular a-arm options [Re: 86_SS]
spacemanspif Offline
Sewell, NJ
Lighter weight, better looks, stronger, can be made for coil overs, can be build to correct bad stock geometry.
-Mike
Killed a few cones too
#1035941 - 03/06/16 12:04 AM Re: Tubular a-arm options [Re: 86_SS]
TooSlow406 Offline
TooSlow406  Offline
Dickinson, TX
most tubular CAs arent all that light. trz has the best ones for that. stock uppers are just stamped steel. for the most part, you get them to correct the geometry.
500/thumbs/IMG_0393s.jpg
by Turbo5
500/thumbs/sswheels.jpg
by fanta
500/thumbs/M41.jpg
by devider440
500/thumbs/exhaust1.jpg
by SMITHFOG
622/thumbs/image37.jpg
by cj84ss
