#1034850 - 02/03/16 10:41 PM Electric fan difference
I have electric fans from an early Dodge Intrepid with one big and small motor installed on my car.
Is there a difference in using later model Intrepid fans or the Ram Charger fans?
#1034854 - 02/04/16 12:14 AM Re: Electric fan difference [Re: Richie Cat]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
I have the Ramcharger fans available, and they are from a Later Model Intrepid, but the wiring harness is custom made.
1987 Monte Carlo SS Aerocoupe "Pro Touring", 436ci All Alum. SBC, 18 Aluminum Heads, 700R4, 3000stall, Ford 9 inch, 3.90 gears, 620 H.P., 590 FT LBS Torque. E.T. 11.229 @ 123.62 on motor. 10.213 @ 137.58 NOS (10/02/2010)!
www.protouraero.com
#1034859 - 02/04/16 04:42 AM Re: Electric fan difference [Re: Richie Cat]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
I'm using the ramcharger fan with my TPI swap. I also have an older style intrepid fan stored in the attic. I think the later style (ramcharger) fan flows slightly more than the earlier style. The wiring for the ramchager fan is completely different. The ramcharger fan has 4 wires, 2 ground + 2 hot. Apply 12v+ to either power wire and you get low speed. Apply 12v+ to both power wires at the same time and you get high speed. I'm using a relay setup from Gmachinz.
#1034865 - 02/04/16 03:07 PM Re: Electric fan difference [Re: Richie Cat]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
The later style fans have a nicer look to them. I also have provisions for using a single BMW dual temp switch with an adapter bushing instead of having to run (2) separate GM style temp switches. I machine my own bushings for them since the only other ones available are $22+ each which imo is a ludicrous price for a simple adapter. There's many ways to configure a harness for these fans to allow them to really perform well.
gbodyparts1234@yahoo.com
HARNESSWORX
#1034882 - 02/04/16 11:13 PM Re: Electric fan difference [Re: Richie Cat]
What year did the Intrepid fans go to two small motors? And the year Ram Charger fans started?
#1034941 - 02/08/16 04:58 AM Re: Electric fan difference [Re: Richie Cat]
meanLS86 Offline
meanLS86  Offline
republic, mo
I think my fans are from a 97 Intrepid and with a jegs electric fan relay kit with 180 degree temp switch. It works great.
https://goo.gl/photos/NuWTa3cW7JnPUJ8Y7
#1035150 - 02/16/16 02:58 AM Re: Electric fan difference [Re: Richie Cat]
RoadWarrior Offline
RoadWarrior  Offline
Mechanicsburg, Pa
The later ramcharger style fans are for the second generation Chrysler LH body 98-04. 97 was the last year for the first gen, so I'm not sure if they got the newer fan set up, but all 98-04 will have them.
MadMax
88 SS, 355 owned since '03
500/thumbs/06.JPG
by Ole Blue
500/thumbs/interior_12.jpg
by djones27
500/thumbs/yhyhy.JPG
by juangomez22
1103/thumbs/11174_10200670096943276_1970586525_n.jpg
500/thumbs/bluerim.jpg
by Mr-SShadow
