#1034795 - 02/02/16 12:34 AM I have a 350 crate i want to make atleast 400hp
ray6914 Offline
ray6914  Offline
pittsburgh pa
84 Monte Carlo SS 3 speed transmission automatic it has a 10 bolt posi with 342 gears has 8.5:1 compression stock 4.00" Bore, 3.47" stroke recommend on cam and Intake Manifold and cfm Carburetor and cc Cylinder Head and stall converter its a street driven i have a cam 295/313 Advertised Duration, 243/257 Duration @ .050 inch, .500 inch/.486 inch Lift
#1034812 - 02/02/16 05:18 AM Re: I have a 350 crate i want to make atleast 400hp [Re: ray6914]
That low compression ratio is going to hold you back from making 400 HP, you need at least a whole point higher than that. Best way to make 400 HP fairly cheap is buy a used running L31 SBC, throw a decent performance cam in it along with a new timing chain and oil pump. GM sells a Qjet intake manifold with EGR port for Vortec heads. Only tricky thing is installing a in tank fuel pump as L31s do not have provisions for a mechanical pump. Factory Qjet is quite capable of 400 HP while still being streetable.
500/thumbs/monte_ss_002_640x480_.jpg
by luke84monte
500/thumbs/Aerocoupe-1987reduced.jpg
by jwc55
1019/thumbs/Copy_of_DSC00291.JPG
by 88monteSScarlo
500/thumbs/GCcarshow2010_130.JPG
by Monster
500/thumbs/DSC00124.jpg
by go3and8
