#1034696 - 01/30/16 07:33 AM Front nose replacement?
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
Has anyone replaced the nose on their SS? Not talking about the LS to SS conversion kits but just the nose.
I have seen NOS original noses for about $500 but after almost 30 years even a new in-the-box nose is bound to be wavy as quality control was not to good on the flex parts at the time.
That leads me to think of a fiberglass replacement as they claim they are dead-straight and I do have quite a bit of experience with fiberglass.
I mentioned this to one of the other mods about a year or so ago and he mentioned not being happy with a fiberglass unit he had (If I remember he said he bought a stock one to replace it)
So does anyone have any experience with aftermarket noses be it Fiberglass or the standard urethane?
What about fit? Prices?
-Thanks
#1034700 - 01/30/16 09:18 AM Re: Front nose replacement? [Re: Phil87SS]
MikesMontes Offline
Authorized Vendor
MikesMontes  Offline
Authorized Vendor
west central ohio
The new GM noses where made in the last 2-3 years
www.mikesmontes.com
1-800-811-5851
#1034704 - 01/30/16 01:54 PM Re: Front nose replacement? [Re: Phil87SS]
howehot Offline
howehot  Offline
Lawler, IA
I did a conversion with an Honest Charley piece on our El Camino. Fit was great but it took a lot of block sanding to get it straight. It was fiberglass. My worry with it is there is zero bend to it. Any curb or tap is not going to be forgiving.
#1034769 - 02/01/16 03:28 AM Re: Front nose replacement? [Re: Phil87SS]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I've used a few NOS nose assemblies on complete paint jobs and I've never had any problems with them. I will say the gap between the nose and hood can take some tweaking to get decent looking. My biggest issue deals not with the SS nose but with the crappy aftermarket chin spoilers. I'd suggest staying with a GM nose and trying to find a GM chin spoiler if you are doing a serious build.
But back to the nose assemblies, they don't have the same level of "warp" as a nose that's spent its life in the elements and in the sun a lot. The surface smoothness on new ones is awesome-literally just scuff it, hit it with wax/grease remover and you're good to go!
gbodyparts1234@yahoo.com
HARNESSWORX
#1034770 - 02/01/16 03:42 AM Re: Front nose replacement? [Re: howehot]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I'll say if that front end flexes when cornering hard, that fiberglass nose will crack. On my 80 Monte I added GP fender braces, heavier duty 3/8" radiator support braces and GP inner fenders w/bracing. The GP stuff is much more stout since the GP front ends are typically heavier so they require more brace stiffening.
HARNESSWORX
#1034821 - 02/02/16 03:40 PM Re: Front nose replacement? [Re: gmachinz]
howehot Offline
howehot  Offline
Lawler, IA
I personally don't think the fiberglass would break under hard corner with a stock chassis. Pretty thick and reinforced with multipal attaching points. Ours has seen very hard cornering, the Monte pulled .98g on a skid pad for Super Chevy, but the Schwartz Performance chassis stiffens the the chassis by 200% so flex is pretty much nonexistent. We also added a 2" lower valance to it and filled the body line. The extensions are fiberglass but the overall fit was great. Biggest problem was the grill. Way to small for the opening so I epoxied abs plastic to it and shaped it to fit.
#1034829 - 02/02/16 06:24 PM Re: Front nose replacement? [Re: Phil87SS]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I'm not referring to chassis flex-I know you've got that covered....I'm referring to body flex. The sheet metal will try to "move" from inertia alone-however, if you have a front brace tying in the ends of the frame horns @ the bumper attachments that will certainly cut down on that!
HARNESSWORX
#1034852 - 02/03/16 11:39 PM Re: Front nose replacement? [Re: Phil87SS]
ss4ever Offline
ss4ever  Offline
Shelbina, Missouri
Most G-bodys other than the MCSS and the GP 2+2 had fiberglass header panels and didn't have trouble cracking. As long at the aftermarket MCSS fiberglass nose is built right it should be fine as well.
#1034864 - 02/04/16 02:44 PM Re: Front nose replacement? [Re: ss4ever]
howehot Offline
howehot  Offline
Lawler, IA
I agree.
#1034867 - 02/04/16 04:06 PM Re: Front nose replacement? [Re: Phil87SS]
Good point. And in either case, the fiberglass header panels or plastic bumper covers, much of the flex the car experiences would come from the frame/chassis itself. They're somewhat connected to the core support and indirectly the frame but it leaves room for some give.
#1035047 - 02/12/16 10:04 PM Re: Front nose replacement? [Re: Phil87SS]
MAP Online content
MAP  Online Content
Hi Folks,
In the nose area regarding fiberglass, the biggest problem would probably be excessive motion between the frame and the body. With the soft stock bushings, this can be as much as 3/4" p-p up/down and probably a similar amount transversely. Using solid bushings in the #1 location should eliminate this, and tighten-up the sense of steering precision considerably.
About the torsional stiffness of the frame, the stock frame overwhelmingly derives this by virtue of its compliant attachment to the body (I measured about 2,000 lb-ft/deg for a frame thus coupled to the body, without a hood.) Even in the case of the Schwartz frame, I suspect the majority of its torsional stiffness still derives via its attachment to the body, and especially since they use solid bushings to make that attachment.
500/thumbs/DSC02786.JPG
by Joe87monteSS
500/thumbs/moto_0058.jpg
by dw329
by 1NJIMID8TOR
500/thumbs/Mighty13w7.jpg
by bumpn1ohm
