#1033768 - 01/01/16 12:10 AM Need some harnesses under the hood
JesusCPenney Offline
Fort Worth, TX
I need to redo my CCC and emissions wiring. I'm looking for a complete engine harness with connectors. It's a stock 1984, but the air conditioning, air injection, and heat riser have been deleted. If anybody has an extra harness PLEASE let me know, I've hit a dead end in my restoration.
#1033769 - 01/01/16 12:25 AM Re: Need some harnesses under the hood [Re: JesusCPenney]
speeddemon Offline
speeddemon  Offline
NW Iowa
I should have everything you need and will look tomorrow but just to clarify you need the engine harness from the fuseblock to starter and the CCC harness that goes from the engine/transmission to the ECM? The heat riser shouldn't have anything to do with either harness.
Jeff J
#1033772 - 01/01/16 12:54 AM Re: Need some harnesses under the hood [Re: JesusCPenney]
Fort Worth, TX
Yeah, I could use both of those. Let me know what you find and what you'd want for it.
#1033778 - 01/01/16 03:34 AM Re: Need some harnesses under the hood [Re: JesusCPenney]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I can supply you with a NEW engine harness if you plan to go that route. Also, if you need a NEW front lighting harness I stock those as well.
gbodyparts1234@yahoo.com
HARNESSWORX
#1033782 - 01/01/16 03:14 PM Re: Need some harnesses under the hood [Re: JesusCPenney]
I have a complete ccc setup that I pulled from my car, harness, sensors, ecm with modified prom, distributor and carb. It was all functioning great when removed this time last year. All of the plastic loom me as removed because it was falling apart.
Would you be interested in everything for $300?
#1033789 - 01/01/16 05:03 PM Re: Need some harnesses under the hood [Re: JesusCPenney]
speeddemon Offline
speeddemon  Offline
NW Iowa
I have the 84 ECM harness still in the car. The only V8 harness I have is from an earlier car, not sure if it would work or not.
Jeff J
#1033796 - 01/01/16 10:19 PM Re: Need some harnesses under the hood [Re: SSLance]
Fort Worth, TX
Actually that sounds great.
500/thumbs/IMG_1088.jpg
by Frazier85
500/thumbs/mymonte2.jpg
by 85PrimeredMCSS
500/thumbs/Photo0186.jpg
by benen
500/thumbs/Glen.jpg
by PontiCarlo468
500/thumbs/DSC01986.JPG
by msh1987
