#1033308 - 12/20/15 06:58 PM Look what I found............
The PC Surgeon Offline
Salisbury Mills, NY
Can you see it? I almost missed it myself. I was only able to see this from this photo. I missed it all the other times I inspected the car.
Here it is.........
#1033309 - 12/20/15 07:04 PM Re: Look what I found............ [Re: The PC Surgeon]
Motor City Monte Offline
blah,MI.
WOW I MISSED IT TOO TILL YOU SHOWED IT
#1033311 - 12/20/15 07:11 PM Re: Look what I found............ [Re: The PC Surgeon]
Good catch, what kind of motor mount is that? Might be a reason not to run solid mounts on the street.
#1033312 - 12/20/15 07:13 PM Re: Look what I found............ [Re: The PC Surgeon]
Salisbury Mills, NY
Moroso. I'l have to order new ones and weld some gussets in there to prevent this again.
#1033316 - 12/20/15 07:37 PM Re: Look what I found............ [Re: The PC Surgeon]
I saw it after I read your text, wow, good catch!!
#1033317 - 12/20/15 08:00 PM Re: Look what I found............ [Re: The PC Surgeon]
Salisbury Mills, NY
This year, I killed:
2 P/S pumps, yes 2..blew the front seal on both of them.
BeCool Radiator, leak cannot be repaired, only replaced. Bottom row into the tank.
1 Front shock, Have Bilstein replacements
1 front sway bar link, replaced both with Spohn Links
1 alternator, replaced internal with a cheap autozone unit. MechMan 140amp internals just arrived.
Forgot about one broken valve spring and replaced all Viton valve stem seals.
#1033319 - 12/20/15 08:27 PM Re: Look what I found............ [Re: The PC Surgeon]
pazzo1969 Offline
pazzo1969  Offline
Mableton, GA
Seems i had the same problem. i drilled a small hole at the front of the crack welded it up and added some gussets. never broke another one. talked to moroso about it at one time... the are stamped and bent into position cold.
#1033320 - 12/20/15 08:32 PM Re: Look what I found............ [Re: pazzo1969]
Salisbury Mills, NY
What kind of HP and Tq are you making? Do you have any pics?
#1033322 - 12/20/15 09:50 PM Re: Look what I found............ [Re: The PC Surgeon]
This thread reminded me GM recalled millions of Chevrolets with defective motor mounts.
http://www.autosafety.org/chevrolet-motor-mounts
#1033323 - 12/20/15 10:34 PM Re: Look what I found............ [Re: The PC Surgeon]
pazzo1969 Offline
pazzo1969  Offline
Mableton, GA
That was with the turbo six banger. i was setting the front frame with a small notch for the dry sump pump, i noticed it then. motor was at 750 with 650ish lb.ft. not sure when it broke. may have been when i blew the rearend apart a few weeks prior...pics are not in my photo bucket for some reason. have run solid mounts many times with no cracks or failures. frame was still mostly stock at that point, may have been to much flex. not sure
only pic when i was working on the frame at the time. can't see the brake
#1033325 - 12/20/15 11:14 PM Re: Look what I found............ [Re: The PC Surgeon]
Salisbury Mills, NY
That little six banger has a nasty punch. My Tq. is up there also, that must be the culprit. I too do not know when it happened but I can guess it was dyno day or just before. Shortly after that I found the broken valve spring. When I was sending Crusher some pictures of the mounts is when I found this crack. Only when I reviewed the photos did I catch it.
#1033331 - 12/21/15 03:11 AM Re: Look what I found............ [Re: The PC Surgeon]
Careful now, you are starting to get close to the amount of parts a race car uses up in a year! laugh
I'll be sure to give my motor mounts a close look when I pull my engine out next week. They haven't been looked at closely in probably 5 years now...
#1033365 - 12/21/15 08:02 PM Re: Look what I found............ [Re: The PC Surgeon]
Crusher Offline
Crusher  Offline
Jersey Shore
I'd just leave it. A judge will never see it.....
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
564 RWHP 574 TQ
http://SSMonteCarlo.com
1019/thumbs/DSC01569new.jpg
by 88monteSScarlo
557/thumbs/Z65_Paul-10HQ1600x1200.jpg
500/thumbs/524370_385748651449313_100000425430071_1353489_721056446_n.jpg
by xxRicochet88xx
1164/thumbs/IMGP6641small.jpg
by Witman69
500/thumbs/thmb_mikesss.jpg
by BadAssSS
