#1032731 - 12/03/15 11:39 PM
flat tappet cam in a roller block/electric pump
mikeasis
faimont, wv
Can i run a flat tappet cam and lifters in a block that came with roller lifters from the factory? would there be a push rod change if so? And what kind of luck have you had with running an electric fuel pump for a carbed engine? I found a crack in the block of my 86 4.3V6 after i paid a machinist to flux it, already bought the parts and cant find a replacement block. The machinist is willing to give me a later model roller block and the fuel pump boss is not drilled for the pump shaft.
#1032742 - 12/04/15 06:16 AM
Re: flat tappet cam in a roller block/electric pump
[Re: mikeasis]
Nice Sunny Hawaii
Not sure what kind of carb you're running, but for piece of mind, run Pressure regulator.
#1032744 - 12/04/15 10:54 AM
[Re: FinallySS]
mikeasis
faimont, wv
yea i have been using an old holley 450 "economaster"
i would have thought these blocks to be a dime a dozen not as one vendor stated rare. The 4.3 was the pig they experimented on i guess.
#1032749 - 12/04/15 03:01 PM
[Re: mikeasis]
Joe87monteSS
Memphis,TN
If he were a good machinist/shop, he could drill that fuel pump hole, and the oil drainback hole.
You can save some money and drill the oil hole yourself before the block is cleaned.
Joey Engine/head builder/machinist 1987 Monte Carlo SS 383/4 Speed 2004 Silverado Facebook
#1032764 - 12/04/15 08:59 PM
[Re: Joe87monteSS]
mikeasis
faimont, wv
heck if he was good he would have caught the crack in the block!
by Clutch_Grabwell
by markg
by tovann
by Witman69
by RoadWarrior
