#1030265 - 10/04/15 06:03 PM Carb issues 63 corvair turbo
Anyone familiar with the YH carter carborator for the corvair? Starts and idles, everything is new from engine rebuild. Converted to igniter electronic ignition. Verified timing at factory specks 24 degrees for the turbo motor. Here is the issue, has no power will only go up to about 1000 rpm at full throttle and that is with no load on the motor. We have the YH carb book and verified everything per it. The idle screw on the base plate they say if ran all the way in and it doesn't kill the motor it's an accelerator pump? Took it all back apart and no issues there either? Verified float setting also. So nothing has changed no matter what. Crazy thing is this carb seems to work opposite of anything I've ever worked with. Thanks for any help.
#1030268 - 10/04/15 07:47 PM Re: Carb issues 63 corvair turbo [Re: cj84ss]
I've got no help for your problem, but just wanted to say I love corvairs and hope you get it going. Post some pics in the lounge sometime...
#1030269 - 10/04/15 08:35 PM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Don't have any pictures of it now but I will post them when I get a few. It will be a sweet little ride and we are so close to being done with it that this is where it's frustrating.
#1030271 - 10/04/15 08:38 PM Re: Carb issues 63 corvair turbo [Re: cj84ss]
WPV Offline
WPV  Offline
Key West, FL
try starting it, choke open, and then put your hand over the carb and rev it till it dies, that should clear it up, I read that somewhere years ago about the corvair YH carbs.
Monte's I own
Monte's Ive sold
#1030272 - 10/04/15 08:53 PM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Will add that to the list to try next time we get to work on it. Thanks
#1030382 - 10/07/15 01:38 AM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Fugued out some of the issues. The throttle not returning was the new boot for the throttle linkage at the fire wall. Hooked up a vacuum gauge and looks like we have a leak? Swapping out the turbo to intake hose because sprayed everywhere else and no increase with the wd40. And it's the number one issues as per turbo corvair guys.
#1030384 - 10/07/15 03:00 AM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Chris, Phil at www.customrebuiltcarbs.com can help, click on my link and give him a call and good luck. I was thru Jax on Monday on the way home, sorry, no time to stop in.
#1030394 - 10/07/15 08:04 AM Re: Carb issues 63 corvair turbo [Re: cj84ss]
I found a pdf that explains the circuits of the YH carb if it can help.
http://autoxer.skiblack.com/nallm/carteryh.pdf
#1030395 - 10/07/15 08:18 AM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Originally Posted By: cj84ss
Here is the issue, has no power will only go up to about 1000 rpm at full throttle and that is with no load on the motor. The idle screw on the base plate they say if ran all the way in and it doesn't kill the motor it's an accelerator pump?
First thing that comes to mind is your high speed circuit in the carb is blocked/clogged. As stated earlier open throttle while it's running and put hand over the throat of the carb or close the choke flap. The high vacuum may pull blockage out of the high speed circuit.
Turning the screw in for idle circuit and the engine doesn't stall would indicate that circuit has a problem also. It has no bearing on the accelerator pump circuit.
#1030434 - 10/07/15 11:41 PM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Leo and Richie thank you. Leo, Sorry you didn't have time to stop by, I'm sure I was at work anyway. Also have the guy from all American carb that dos the rebuild interested and will come to the car but he is out of town now. We will get this thing working. It's better but not perfect yet.
#1030435 - 10/07/15 11:55 PM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Probably, it was around 11:00 AM.
#1030451 - 10/08/15 08:26 AM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Did you also check fuel filter and fuel pump pressure?
#1030490 - 10/09/15 12:22 AM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Fuel pressure is spot on as per the manual and that was at the fuel inlet for the carb. 1.5-2 lbs.
I was about to eat lunch at work at 11!
#1030654 - 10/13/15 02:21 AM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Update, got a chance to work on it for about an hour today. Got the turbo moved over a little and helped it line up with the intake. Installed a new turbo hose. Seemed to help it out. Verified time was correct and that the advance was work in the distributor and it was. Then ran out of gas! So pushed it back in the corner of the garage until next time. Good news is it did have throttle response and got it up to about 3000 rpms and the boost comes on quick. Still can't get the idle to the right rpms and it's a little slow to come up on power still.
#1030696 - 10/14/15 02:07 AM Re: Carb issues 63 corvair turbo [Re: cj84ss]
Call my man Phil, Chris, I know he can help!!
500/thumbs/DSC02786.JPG
by Joe87monteSS
500/thumbs/moto_0058.jpg
by dw329
by 1NJIMID8TOR
500/thumbs/Mighty13w7.jpg
by bumpn1ohm
