#1030186 - 10/02/15 12:13 AM Monte Master Cylinder
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Guys, this is probably a silly question but I need clarification. I'm about to install a Line Lock on my 87 SS. Which fitting coming off the master cylinder is for the front brakes? My shop manual seems to show the rear fitting is for the front brakes. Other info I've found on the web says the front fitting is for the front brakes.
#1030191 - 10/02/15 12:57 AM Re: Monte Master Cylinder [Re: Fred SS]
malibudave78 Offline
Houston, TX
Rear port of master cylinder is for the front brakes.
Front port of master cylinder is for the rear brakes.
#1030206 - 10/02/15 04:31 AM Re: Monte Master Cylinder [Re: malibudave78]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Thanks Dave.
500/thumbs/DSC02786.JPG
by Joe87monteSS
500/thumbs/moto_0058.jpg
by dw329
by 1NJIMID8TOR
500/thumbs/Mighty13w7.jpg
by bumpn1ohm
