#1028132 - 08/15/15 06:59 PM Ramcharger fans are back
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
I currently have 3 of the "Ramcharger" dual electric fans, and wiring harnesses that fit the 1st through 4th. Gen. Monte Carlos very well. I have these permanently mounted to my aluminum radiator in my Aerocoupe. They keep my 625 HP engine nice & cool. $200.00each for the fans & wiring harness kit, plus actual shipping.
E-mail me at protouraero@comcast.net if interested.
Mike McKinney
1987 Monte Carlo SS Aerocoupe "Pro Touring", 436ci All Alum. SBC, 18 Aluminum Heads, 700R4, 3000stall, Ford 9 inch, 3.90 gears, 620 H.P., 590 FT LBS Torque. E.T. 11.229 @ 123.62 on motor. 10.213 @ 137.58 NOS (10/02/2010)!
www.protouraero.com
#1028168 - 08/16/15 03:32 PM Re: Ramcharger fans are back [Re: ProTourAero]
Joe87monteSS Offline
Memphis,TN
Can you tell me more about the harness? Is it just as pulled from a donor car? Thanks.
Joey
Engine/head builder/machinist
2004 Silverado
Facebook
#1028180 - 08/16/15 11:26 PM Re: Ramcharger fans are back [Re: ProTourAero]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
No it's a new universal harness with only 2 connections, hot and ground. It has 2 speeds, high and low. Weatherproof relays are built into the harness.
www.protouraero.com
#1028197 - 08/17/15 04:24 AM Re: Ramcharger fans are back [Re: ProTourAero]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
I'm curious, what radiator are you running?
#1028200 - 08/17/15 11:12 AM Re: Ramcharger fans are back [Re: ProTourAero]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
I have a BE COOL radiator that we made custom mount brackets welded to the rad tanks, but these can be mounted many ways.
www.protouraero.com
#1028201 - 08/17/15 11:32 AM Re: Ramcharger fans are back [Re: ProTourAero]
The Ramcharger fans I bought from Mike several years ago fit the stock radiator with just a little bit of trimming on one edge and some plastic push ties thru the radiator to hold it in place.
The harness they come with is operated by just a 3 position switch. I had Jabin build me a harness with two temp switches built in plus the 3 position switch as a backup to run them and it works fantastic.
#1028203 - 08/17/15 12:51 PM Re: Ramcharger fans are back [Re: ProTourAero]
Memphis,TN
I had a pair of these fans new, and I sold them along with the harness described by Lance. Now I wish I had kept them..
Will you sell the harness alone?
Joey
2004 Silverado
Facebook
#1028204 - 08/17/15 01:13 PM Re: Ramcharger fans are back [Re: ProTourAero]
I had both of my cars running these fans and was happy, tried the Mark VIII fan on the car with A/C thinking even more CFM will help but wish I would of kept the Ramcharger setup as a spare instead of selling it. Great fans and relatively quiet too, especially compared to the Mark VIII fan anyway. Glad to see they are "back", at least back in this form.
#1028212 - 08/17/15 02:07 PM Re: Ramcharger fans are back [Re: ProTourAero]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I really like how they fit. I like to go for the newer style fans with the plastic motor covers-much better looking in design IMO but same basic dimensions.
gbodyparts1234@yahoo.com
HARNESSWORX
#1028263 - 08/18/15 05:49 PM Re: Ramcharger fans are back [Re: Joe87monteSS]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
Yes Joe:
The wiring harnesses alone are $95.00, plus frt.
www.protouraero.com
#1028264 - 08/18/15 05:51 PM Re: Ramcharger fans are back [Re: ProTourAero]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
Thanks to all the previous customers who endorse the fans, and harnesses.
www.protouraero.com
#1033981 - 01/05/16 02:26 PM Re: Ramcharger fans are back [Re: ProTourAero]
Dom87SS Offline
Dom87SS  Offline
Lake Villa, IL
Ive had a ramcharger fan for a good 10+ years now (never used it) but am setting up to use it for next year. Is the wiring harness you describe the length of wire with weather pack pictured on the fan there or is it the piece that would connect to that and go into the car?
1987 Monte Carlo SS - 2006 GXP
http://drd-photos.smugmug.com/
#1033983 - 01/05/16 05:08 PM Re: Ramcharger fans are back [Re: ProTourAero]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Not sure which of us you're asking but the universal style harnesses piggyback off the main fan harness since they are wired in series for low and high speed. There's many ways to wire them but the simplest method is a 3-gang relay setup with AC override provisions. I also set them up to both run as a three speed assembly as well which is a different harness altogether. You'll need (2) ground outputs from your ecu or use temp switches.
HARNESSWORX
#1033986 - 01/05/16 05:41 PM Re: Ramcharger fans are back [Re: ProTourAero]
200kSS Offline
200kSS  Offline
Bloomsdale, MO
gmachinz: Do you have a "plug 'n play" harness for these fans? I'm looking to get the fans, and install them on an SS with the CCC system and a/c.
#1033988 - 01/05/16 08:08 PM Re: Ramcharger fans are back [Re: ProTourAero]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I do have options-including triggering high speed via the AC idle solenoid, pressure switch or clutch coil as an automatic override working in parallel with the high temp switch. I can PM ya with details on a couple options if you'd like.
HARNESSWORX
#1034847 - 02/03/16 08:31 PM Re: Ramcharger fans are back [Re: ProTourAero]
Fire0662000 Offline
Fire0662000  Offline
Pensacola, FL
Do you still offer this setup as listed above? If you do please email me @ ross68@cox.net to
#1034853 - 02/04/16 12:11 AM Re: Ramcharger fans are back [Re: ProTourAero]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
Sent you an E-mail Chad.
Yes still available.
www.protouraero.com
#1035038 - 02/12/16 04:22 PM Re: Ramcharger fans are back [Re: ProTourAero]
Lobito Offline
Lobito  Offline
North Bergen, NJ
I'm interested as well. Please email me at lobitoss@gmail.com
#1035630 - 02/28/16 06:34 PM Re: Ramcharger fans are back [Re: ProTourAero]
Manny's_aerocoupe Offline
Visalia,CA
I'm interested as well email me manuels87ssmc@gmail.com
#1036241 - 03/12/16 02:23 AM Re: Ramcharger fans are back [Re: ProTourAero]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
E-mails sent.
Still available.
www.protouraero.com
#1050623 - 05/07/17 03:46 AM Re: Ramcharger fans are back [Re: ProTourAero]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
@ProTourAero, i was wondering what is the thickness of the mounting bracket you had welded to the Radiator? I like the way you did it and want do it the same way. Thanks
87 Aerocoupe, Rapp Racing 383 with AFR aluminum heads.Leather interior,Hedman headers,Flowmaster Super 40's, k&n filter,MSD Ing, 17x8 IROC w/ 245/45/17, Wilwood front & rear disc brakes, UMI Performance Stage 2.5 suspension, Kenwood sound system..
651/thumbs/C6.JPG
by 84supersport
994/thumbs/KC1210-100906_7.jpg
by Elipopotao
500/thumbs/Lomogram_2014-08-27_12-05-28-PM.jpg
by MCSSLife
671/thumbs/start_001.jpg
by woodss
500/thumbs/At_Earnhardt_Chevrolet.jpg
by Scott_86SS
