#1025899 - 06/18/15 07:12 AM Help with my turn signals?
bagotrixz831 Offline
watsonville, CA
having trouble notice that one of my turn signals was a little dim and I change the light bulb and I notice that the turn signal light stayed on my dash, on the side where the light was dim so them I also notice that my tailight was having bulb issues so I change the bulb and now my both turn signals are out and both lights are turn on dash, so I removed the flash relay from the fuse box and turn signals are still on does any one have a idea whats wrong
#1025902 - 06/18/15 10:19 AM Re: Help with my turn signals? [Re: bagotrixz831]
83StreetMachine Offline
Central NJ
First things first, check your grounds. The front harness has 2 both attach above the headlight cutout on the radiator support, one on each side. The rear harness has one that attaches to the trunk floor.
If those check out ok, Replace the turn signal and hazard relays. I think there is even a fuse as well. If still not fixed, its probably the switch inside the column.
Good luck. Keep us updated.
#1025906 - 06/18/15 01:46 PM Re: Help with my turn signals? [Re: bagotrixz831]
watsonville, CA
Thank you I will check that after work. also replacing the flasher today thanks
500/thumbs/front_seat1.jpg
by Rodney
1113/thumbs/BadAssFender7.jpg
by upflying
by MaverickMonte85
1125/thumbs/IMG_5004.jpg
by The PC Surgeon
