#1017868 - 01/03/15 08:40 AM Help on a 1984 Monte carlo door
bagotrixz831 Offline
watsonville, CA
Looking for a door for my 84 but all the ones I have found have power windows and my door has a handle for window my question is power window door be convert to handle manual windows if so do I need to drill or weld anything or is their a page where to covert the doors
#1017870 - 01/03/15 03:07 PM Re: Help on a 1984 Monte carlo door [Re: bagotrixz831]
mannblk Offline
mannblk  Offline
NC
The door is the same, so you will need to swap out the internals from the power, to manual. Most of the items are bolted in, a few rivited that will need to be drilled out. Just take your time and try to organize as you go, this way the install will go alot smoother. Be careful though, the edges around the areas of the door you will be using to get the internal out are razor shapre. Good luck!
#1017871 - 01/03/15 04:22 PM Re: Help on a 1984 Monte carlo door [Re: bagotrixz831]
Aeroaddict Offline
Aeroaddict  Offline
Fairfield County ,CT
You would just need the change out the actuator. You would need to drill out the rivets.
#1017887 - 01/03/15 11:08 PM Re: Help on a 1984 Monte carlo door [Re: bagotrixz831]
watsonville, CA
Any one have pictures of convertion
#1017888 - 01/03/15 11:10 PM Re: Help on a 1984 Monte carlo door [Re: bagotrixz831]
watsonville, CA
Picture of the actuator?
#1017913 - 01/04/15 11:45 PM Re: Help on a 1984 Monte carlo door [Re: bagotrixz831]
Aeroaddict Offline
Aeroaddict  Offline
Manual window actuator
#1018003 - 01/07/15 01:14 AM Re: Help on a 1984 Monte carlo door [Re: bagotrixz831]
watsonville, CA
Thanks for the pictures and all the info
500/thumbs/My_Pictures00021.jpg
by 85MONTE!!
500/thumbs/IMG_1970.jpg
by Aeroaddict
500/thumbs/DCFC0005.JPG
by madmax74
500/thumbs/Monte_Carlo_3.jpg
by 468beast
702/thumbs/monteme1.jpg
by red/white04
