#1014953 - 10/29/14 07:07 AM need help guys with dash cluster........
bagotrixz831 Offline
watsonville, CA
can anyone help me by putting back this cluster back together any pics would helpp..... thank you
#1014965 - 10/29/14 01:26 PM Re: need help guys with dash cluster........ [Re: bagotrixz831]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
This post is for improved dash lighting. It shows how to take dash apart and put it back together. Pics around 7, 8, 9 and 10 show the shift indicator. I think you slip it back in after the gauge panel is in place. Hope it helps.
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=491538#Post491538
#1014976 - 10/29/14 02:52 PM Re: need help guys with dash cluster........ [Re: bagotrixz831]
phx85ss Offline
phx85ss  Offline
Phoenix, AZ
That is the shifter position indicator do you have all the pieces,small spring,1 screw,and the orange pin?I will post pictures today
#1014986 - 10/29/14 05:14 PM Re: need help guys with dash cluster........ [Re: bagotrixz831]
watsonville, CA
Yes I do have all parts .....plus i have another extra one I wannna swap parts to the extra one cause the one I have in the car it has broken pieces and the bezel won't hold in place please help with pictures.... Thank you
#1014993 - 10/29/14 07:54 PM Re: need help guys with dash cluster........ [Re: bagotrixz831]
watsonville, CA
these are the only parts this unit has missing anything??? or the parts all there? thank you
#1015000 - 10/30/14 12:29 AM Re: need help guys with dash cluster........ [Re: bagotrixz831]
Aeroaddict Offline
Aeroaddict  Offline
Fairfield County ,CT
The bottom one looks good, you need the cable that runs to the steering column ring. It may still be attached to the column.
#1015022 - 10/30/14 02:16 PM Re: need help guys with dash cluster........ [Re: bagotrixz831]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I wouldn't use either shift indicator if there is a worn thru "slot" where the cable travels around-eventually this binds up the cable and can shred it prematurely. Look for a nice one and periodically grease that part of the shift indicator with a lithium grease.
gbodyparts1234@yahoo.com
HARNESSWORX
#1015023 - 10/30/14 02:52 PM Re: need help guys with dash cluster........ [Re: bagotrixz831]
Check with Mikes Montes for the shift indicator.
#1015080 - 11/01/14 01:28 AM Re: need help guys with dash cluster........ [Re: bagotrixz831]
watsonville, CA
Hey guys I put the cluster back in piece but now I been getting the check engine light on...... I turn on the car and 3-5 mins later the light turns on car just passed smog and no check engine light turned on.... Any suggestions
#1015082 - 11/01/14 02:17 AM Re: need help guys with dash cluster........ [Re: bagotrixz831]
get the code.
#1015085 - 11/01/14 05:50 AM Re: need help guys with dash cluster........ [Re: bagotrixz831]
watsonville, CA
U guys think its be cause the cluster that I just put on its from a v6 and and I have a v8?
#1015089 - 11/01/14 11:02 AM Re: need help guys with dash cluster........ [Re: bagotrixz831]
tomh115 Offline
tomh115  Offline
Russellville, AR
I could be corrected, but I think the ses is not connected to the dash cluster from asignal standpoint. Best course of action here is to read the code. AutoZone has a 30$ tool that can do it or just jumper a couple of terminals on the box under the dash on the driver side near the radio. Throw the found code up here or in Google search to find the answer. The AutoZone tool has a code book if you go that route
1987 Monte Carlo SS Aerocoupe
Objects in mirror are losing
#1015093 - 11/01/14 04:12 PM Re: need help guys with dash cluster........ [Re: bagotrixz831]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
many parts stores will read the codes for you for free - hoping to sell you stuff
#1015101 - 11/01/14 06:21 PM Re: need help guys with dash cluster........ [Re: bagotrixz831]
watsonville, CA
Thanks for the info guys I put on the old cluster back on and Guess's what? ...... Car turns on and 3-5 mins later the check engine light turns on .......so now old and new (used)cluster are having the same problem.....
#1015481 - 11/09/14 04:06 AM Re: need help guys with dash cluster........ [Re: bagotrixz831]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Do you know how to pull an OBD1 engine code? If there's several minutes before throwing a code, I'd guess a poor O2 sensor code which should be a 13 if memory serves me correct.
HARNESSWORX
#1015809 - 11/14/14 04:25 PM Re: need help guys with dash cluster........ [Re: bagotrixz831]
Ole Blue Offline
Ole Blue  Offline
Lugoff, SC
Did you have any trouble with the "Check Engine" light prior to originally removing the Instrument Panel (I/P) when you first started?
#1015927 - 11/17/14 09:46 AM Re: need help guys with dash cluster........ [Re: bagotrixz831]
watsonville, CA
No....ll just smog it passed.......after I started playing with cluster light pop up also mi choke light but I know I have it bad
#1015940 - 11/17/14 05:04 PM Re: need help guys with dash cluster........ [Re: bagotrixz831]
Ole Blue Offline
Ole Blue  Offline
Lugoff, SC
Unplug your ECM and plug it back in. This will reset all codes stored. You will be starting fresh.
I believe you can also unplug your battery cables to accomplish the same result. You can also unplug both, it won't hurt anything and will reset(wipe out) stored codes.
Try this and let us know how you make out. This would be a good first step. It is what I would do if I had the problem.
500/thumbs/front_seat1.jpg
by Rodney
1113/thumbs/BadAssFender7.jpg
by upflying
by MaverickMonte85
1125/thumbs/IMG_5004.jpg
by The PC Surgeon
