#1013970 - 10/09/14 04:17 AM serpentine power steering
WaSSted Offline
WaSSted  Offline
Kennewick
It's late and everything fits but the power steering pump. So I can sleep tonight I just need conformation that I need to buy a Camero PS pump in order to complete my serpentine setup. The stock pump just wont line up with the 91 fbody brackets.
Kirk Herres
#1013983 - 10/09/14 12:41 PM Re: serpentine power steering [Re: WaSSted]
WaSSted Offline
WaSSted  Offline
Kennewick
It will not fit. Must use f-body power steering pump.
Kirk Herres
#1013998 - 10/09/14 05:32 PM Re: serpentine power steering [Re: WaSSted]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Yes, you will need to use the fbody pump. But, you also need to use the double threaded studs on the back of the pump which seal the pump body to the reservoir as well as provide the attachment point for the fbody power steering pressure hose. Also, fbody specific pressure hose feature a "T" fitting for the pressure switch which is +12V on one terminal and the other ties into the idle solenoid. The reason is to kick the idle up when hard turning while vehicle is not moving-such as parking. On a road course, using this features allows a carbed engine to not stall on aggressive cornering.
gbodyparts1234@yahoo.com
HARNESSWORX
500/thumbs/monte_0061.JPG
by bootlegger
500/thumbs/1985_monte.JPG
by Hostile
536/thumbs/51.jpg
by ssmnt408
500/thumbs/SS5.JPG
by IowanSS
857/thumbs/Ram_Air_small.jpg
by 86SSmonte350
