#1013750 - 10/05/14 10:19 PM heater core repair or replace???
Keithss Offline
Keithss  Offline
Jackson,mi
The title just about says it all.
My heater core is leaking and I was trying to decide weather to have it repaired or replace it. I have it out of the car now. After looking on line I see there are a number of makers, any where for $25 to $65. I know you get what you pay for, but has anyone had any experience with a manufacture, or should I just get mine repaired locally?
Keith
#1013752 - 10/05/14 10:52 PM Re: heater core repair or replace??? [Re: Keithss]
I don't think they can be repaired,but I could be wrong.
I have replaced them before,and it is a PITA.
If you don't really need it,I would take it out and get rid of the heater/ac "suitcase".
#1013753 - 10/05/14 10:54 PM Re: heater core repair or replace??? [Re: Keithss]
Silver8M86 Offline
Silver8M86  Offline
Suffolk, VA
Ive heard a lot of forum members having problems with replacements having a short life span. Not a huge problem in this car since its an easy replacement compared to an import where you have to dissassemble the whole dash.
#1013754 - 10/05/14 11:09 PM Re: heater core repair or replace??? [Re: Silver8M86]
I've owned my Monte for half of its life,14 years now,and counting the heater core that was in it when I bought it,I'm now on # 4.And I'm quite certain the original wasn't in it when I bought it.Who knows how many were put in it previous to my buying it.
So I guess you could say they have a short life span LOL
#1013759 - 10/06/14 12:23 AM Re: heater core repair or replace??? [Re: Keithss]
replace it, I bought mine from NAPA.
#1013767 - 10/06/14 03:28 AM Re: heater core repair or replace??? [Re: GuysMonteSS]
Heater core R&R in the Monte is very easy compared to cars with core hidden behind the dash.
#1013770 - 10/06/14 04:40 AM Re: heater core repair or replace??? [Re: Keithss]
phils_super sport Offline
creedmoor,nc
replace it.i got mine from autozone about 4 yrs ago and havent had any problems with it yet.
#1013773 - 10/06/14 06:31 AM Re: heater core repair or replace??? [Re: Keithss]
Stig Offline
Stig  Offline
Midlothian VA
Heater core replacement in our cars is pretty easy, but is a bit time consuming. I did mine in a few hours, but I also work a bit slowly and take my time.
85 Monte Carlo SS(Sold)
91 GMC Syclone (Sold)
95 Subaru Impreza (Sold)
#1013775 - 10/06/14 10:55 AM Re: heater core repair or replace??? [Re: Keithss]
mainer Offline
mainer  Offline
new gloucester, ME
I can't believe it even came up for discussion , replace it. you couldn't get it fixed as cheap as a new one .
#1013796 - 10/06/14 03:26 PM Re: heater core repair or replace??? [Re: GuysMonteSS]
Silver8M86 Offline
Silver8M86  Offline
Suffolk, VA
I wonder if coolant choice is playing a hand in this? There was a thread awhile back about prefered type of coolant I think about half the people said they use peak. I usually use Advance Auto Parts 50/50 whatever is cheapest. Honda/BMW makes some Blue coolant that is supposed to be more anti-corrosive maybe you could try that? I never bought into those fancy fluids...
#1013806 - 10/06/14 06:44 PM Re: heater core repair or replace??? [Re: Keithss]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
It is hard to find an old school radiator shop that will do the job well for a good price in our area. Replacing is as cheap as repairing so everyone replaces them. Original was copper. New one is aluminum. I figure if I flush the fluid like I should it will extend the life of both the radiator and the heater core. A less corrosive fluid would be better. Not a hard job to get to the heater core in our cars.
#1013816 - 10/06/14 08:03 PM Re: heater core repair or replace??? [Re: Silver8M86]
Ole Blue Offline
Ole Blue  Offline
Lugoff, SC
I have over 250,000 miles on my '85 and never replaced the heater core.
Maybe it was from the regular flushes and keeping 50% Prestone antifreeze and 50% water.
#1013847 - 10/06/14 11:34 PM Re: heater core repair or replace??? [Re: Keithss]
RenoReno2 Offline
RenoReno2  Offline
Chicago, IL
Couldn't you just braze the hole? if you don't have access to acetylene any welding shop could do it.
88 Monte SS
#1013868 - 10/07/14 03:23 AM Re: heater core repair or replace??? [Re: Keithss]
WaSSted Offline
WaSSted  Offline
Kennewick
I don't know if an original is available but that's what Im installing next time. I'm on number 4 as well. Thought I was smart buying one with life time warranty. Ya they gave me a new one, but it's not worth the time.
Kirk Herres
#1013881 - 10/07/14 03:23 PM Re: heater core repair or replace??? [Re: RenoReno2]
Silver8M86 Offline
Silver8M86  Offline
Suffolk, VA
The problem I see with just brazing the hole, is you probably have a bunch of other internal areas where there is corrosion that just havnt worn through yet. So if you braze where it wears through you could have another faliure right away in another spot
#1013900 - 10/08/14 12:17 AM Re: heater core repair or replace??? [Re: Silver8M86]
rons87mcss Offline
rons87mcss  Offline
PA
FWIW/FYI I know there is a ~ground~ wire installed on both factory a/c and factory non-a/c SS's since I had to change the heater core in both of the monte carlo ss's I've owned due to leaks that formed. I do remember reading somewhere(?) about the ground wire being there to help prevent the heater core from corrosion problems. Just figured I'd mention it in case someone has failed to reinstall it during replacement at one time or another. The factory non-a/c one in my 87SS was replaced about 7 years ago and is still holding up fine without any problems. The factory a/c 86SS was replaced about 1&1/2 year ago but since it is now sitting totaled I won't get a chance to see how it would have held up. Both heater cores were right around $30 if I remember correctly. I didn't feel either setup was that bad of a replacement, but of course I don't have a big block in either of my cars either(Guy) smile
#1018183 - 01/10/15 09:49 PM Re: heater core repair or replace??? [Re: Keithss]
When all of you were replacing your heater cores, did you run into this?
The little bracket on the top of the factory heater core that holds it in place will not fit on the replacement heater core I picked up today.
Here is how it fits on the factory core
The top of the new core is formed differently and the bracket won't fit it.
I wracked my brain for a half hour trying to come up with a fix to hold the core tight and couldn't. Any ideas?
The new core is from O'Reilly, Murray Heat Transfer - Heater Core Part Number: 94505 and the pics online show the correct top on the core.
The box says Murray #94505 but the core inside has a Vista Pro part # on it and Vista Pro Instructions.
Should I try a Napa or Autozone or something to try to get a correct one? I really wanted to button this up this weekend.
#1018184 - 01/10/15 10:00 PM Re: heater core repair or replace??? [Re: Keithss]
Spectra 94505 pics look like this.
I called Autozone and asked for that part number, a store close to me has one in stock and they are holding it for me. Right as I'm about to hang up the guy says just so you know, the Autozone part # for that is 399088.
mad banghead
I'm not even sure if I want to drive over there now...
#1018190 - 01/10/15 10:38 PM Re: heater core repair or replace??? [Re: Keithss]
Hey Lance, I have the Spectra 94505 here in a box and it is identical to the pic above. I also installed the same one in my 85 few months ago and reused the stock bracket.
85 - ZZ383, 6-speed, 8.5"
70 - Stock, 35k miles
#1018200 - 01/10/15 11:26 PM Re: heater core repair or replace??? [Re: Keithss]
Autozone had the right one!!
#1018201 - 01/10/15 11:28 PM Re: heater core repair or replace??? [Re: Keithss]
Frank, did you use anything to seal the top lid to the bottom box around the front edge? It didn't look like there was anything along that lip as a sealer when I took it apart.
I'm going to use some sort of RTV\weatherstrip combo to seal the back edge along the firewall.
#1018204 - 01/10/15 11:41 PM Re: heater core repair or replace??? [Re: Keithss]
I used black RTV all the way around.
#1018205 - 01/10/15 11:53 PM Re: heater core repair or replace??? [Re: Keithss]
Okay, that makes sense. Thanks...
#1018206 - 01/11/15 12:11 AM Re: heater core repair or replace??? [Re: Keithss]
88ss408 Offline
88ss408  Offline
miramichi, NB
I also used the spectra one a couple months ago everything was like the stock
Piece. Fit was good reused the braket
1988 monte carlo ss 408 sbc
1984 monte carlo cs 400 sbc
#1018207 - 01/11/15 12:13 AM Re: heater core repair or replace??? [Re: Keithss]
The small ground wire goes on the screw on the holddown bracket, right? Then out to the screw on the firewall?
500/thumbs/m_a8afc26ccfb942708e1b30c63c303620.jpg
by gbodydude496ci
500/thumbs/MikePEI_s81.jpg
by MikePEI
1084/thumbs/imagejpeg_6_5.jpg
by 87SSon6s
1083/thumbs/250x250-0221111610.jpg
by PIMPC3692
500/thumbs/HPNX0045.JPG
by Intmdatr3
