#1011756 - 09/05/14 07:11 PM L31 vortec 350 engine swap details?
Chevy Runs Deep Offline
Atlanta, Ga
Greetings everyone.
Just a few questions regarding swapping in an l31 long block that would be carbed. Questions about reusing v belt accessories, heater bypass, how the stock cam responds to a carb, header fitment on vortec exhaust ports, fuel system options whether in tank or inline. The motors seem to be pretty cheap and common, just small details to swap it in.
Thanks!
Bernard
1983 Chevy Monte Carlo...ss clone
...... In Progress ...... Vortec headed 350 hyd roller etc
2013 Chevy Silverado Z71....dd....TRADED
2005 Chevy Equinox....wife's dd
2015 Chevy Camaro SS....LS3 M6
#1011808 - 09/06/14 03:02 PM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
87ChooChoo Offline
87ChooChoo  Offline
las Vegas, NV
Pretty much everything will swap over, except fuel pump. Distributor may need a Roller Cam gear ( melonized). In line Electric Pump will be OK for carb'd application. Keep it to 7 PSI or less ( may need regulator). No EGR capability in the heads, so if you need EGR, you will have to track down an EGR install kit. Special bolts available for the Vortec Intake Manifold ( designed to not crush the vortec gaskets. I would swap the heater bypass for one from a '96 truck. It allows the heads to get some flow while warming up. If going into your '83, you will need a different flexplate. Need a way to block off the crank sensor on the timing cover.
#1011834 - 09/07/14 01:28 AM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
Atlanta, Ga
Thanks 87 Choo Choo. Yes going in the 83. So reuse all vbelt front end accessories. Use flexplate and starter from l31. Reuse th350. Reuse hooker longtubes. No emissions. Need vortec intake, gaskets, and bolts. Heater bypass from truck.
I would prefer an intank fuel pump for the carb rather than inline since it's a street car. Maybe someone can elaborate on their setup. I'm familiar with factory style repairs vs modifications. What's needed for an intank electric fuel system for a carb?
Am I missing anything?
Thanks.
#1011836 - 09/07/14 03:10 AM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Is it possible Bernard could use a TBI fuel pump assembly and tank along with a fuel pressure regulator? The TBI pumps have less pressure than the typical fuel injection application but more than carbs. A regulator could possibly reduce it enough for the carb without having allot of fuel being routed back to the tank. This would be a more oem looking install. Comments?
#1011892 - 09/07/14 09:49 PM Re: L31 vortec 350 engine swap details? [Re: Fred SS]
87ChooChoo Offline
87ChooChoo  Offline
las Vegas, NV
Should work fine. Locating a used one can be tricky, but new senders are available, as well as TPI pumps. Just need to regulate it down to 7psi from 15. If you keep the tanke 1/4 full or greater, no issues with starving the fuel pump. If you can find a TBI fuel tank it should have some baffles that will help with this issue, but not necessary.
#1011966 - 09/08/14 09:50 PM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
Atlanta, Ga
Would a Buick Grand National sending unit work? Seems easier to find online than a 4.3 tbi sender. I suppose a tbi pump would be easier for the fuel pair regulator to work properly. Then somehow add a return line to the carbed tank. Anyone know what fittings, line, would be required for converting to basically an efi fuel setup but still using a carb... minus the baffled tank I wouldn't need as the fuel vowels should hold enough fuel to make it through a fast corner. Please excuse my rambling
#1011967 - 09/08/14 10:26 PM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
87ChooChoo Offline
87ChooChoo  Offline
las Vegas, NV
GN Sender will work fine. Same as the monte sender. Use a TBI pump, and you are golden. I used the "Vent" line as my return line, and then added a 5/16" fuel hose for the vent to the charcoal cannister. Some Montes had the return line as stock off the stock fuel pump- I think it just depends on the year.
I would change all of the rubber fuel line on the pressure side to FI capable fuel line- it won't take much- maybe 6' of 3/8" line. Buy a box of FI Hose clamps on Ebay. I double clamped all of mine, but I run a higher pressure. at 15 PSI, single clamps will be OK. Add an inline filter ( I used Fuel Filter G6332 Autozone ( FF4506)(G3870 ?). If you use the vent line for your return, be sure to put it onto the return port of the sender. The vent port at the sender has a restriction in it.
#1011998 - 09/09/14 12:36 PM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
Atlanta, Ga
Short recap... Reuse feed line to fuel pressure regulator, return line from regulator back to sender if mounted near tank, fuel filter to feed line to carb. Or, feed line to engine compartment mounted regulator, reuse vent line back to sender. New vent line to charcoal canister. Will use fuel injecting hose to replace all old rubber fuel line.
#1012005 - 09/09/14 02:48 PM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
87ChooChoo Offline
87ChooChoo  Offline
las Vegas, NV
Sounds good. Mounting the regulator near the tank would be easy, but not convenient for adjusting pressures. Depending on your regulator, might consider a FP Gauge or a connection for one in the engine compartment, for adjujstment.
#1012015 - 09/09/14 04:43 PM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
Atlanta, Ga
Thanks for the help 87 Choo Choo! I'll update the thread in a week or so with progress after a trip down to Summit Racing.
#1012233 - 09/12/14 01:31 PM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
WaSSted Offline
WaSSted  Offline
Kennewick
Not sure what you mean I'm reguards to heater bypass so I'll reply anyway. I do know you will want a heater valve from a 97 pickup if you plan on using the heater, the original will not work. Otherwise bypass it with a hose, which I'm sure were your initial intentions.
Kirk Herres
#1012238 - 09/12/14 03:50 PM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
Atlanta, Ga
WaSSted,
I've read somewhere about vortec engines needing external bypass or overheating can occur. HVAC components are all here but I don't plan on running them with this being a fair weather cruiser. Since you're running a vortec engine could you elaborate on your setup. Another question I had was if the serpentine drive from the truck would fit in the monte without the actual compressor and using a shorter belt. What did you do for fuel? Basically looking for a bare bones swap to get her running as im anticipating a move soon. Thanks for all the help.
#1012242 - 09/12/14 04:24 PM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
87ChooChoo Offline
87ChooChoo  Offline
las Vegas, NV
This is the Heater bypass valve for the Vortec engines. Allows some flow of water through the heads/intake before the thermostat opens up.
http://www.oreillyauto.com/site/c/detail/MRY0/74781/02708.oap?year=1997&make=Chevrolet&model=C1500%2BPickup%2BRWD&vi=1031555&ck=Search_02708_1031555_-1&pt=02708&ppt=C0331
You should be able to use the truck serpentine setup, but you would have to change the water pump, get an AC delete pulley, and possibly a different length belt.
I usually run 91, but I think you should be able to run on less- the compression is not that high. I've run 89 with no issue- haven't tried '87 yet, but the ECM should compensate for it anyway.
#1012308 - 09/14/14 12:08 AM Re: L31 vortec 350 engine swap details? [Re: 87ChooChoo]
rons87mcss Offline
rons87mcss  Offline
PA
FWIW, a stock L31 engine runs just fine on 87 octane. I never ran anything else in my 1998 Z71 when I had it with the ridiculous prices of fuel today.
#1012316 - 09/14/14 02:28 AM Re: L31 vortec 350 engine swap details? [Re: rons87mcss]
jmireles Offline
jmireles  Offline
El Paso, Tx
We used to have 87 octane...86 now. I noticed pinging on loads, so I used premium two weeks ago. Wow, quite a difference! I'm breaking about even now that fuel prices have come down. I love the acceleration and response on my '97 Z71. Not to mention I'm getting slightly better mileage.
in '08. 3K
#1012548 - 09/17/14 04:52 AM Re: L31 vortec 350 engine swap details? [Re: Chevy Runs Deep]
WaSSted Offline
WaSSted  Offline
Kennewick
Coolant must always be flowing between the intake port and pump or engine will over heat. Just run a heater hose from the intake to the water pump and you will be fine. If you decide you want heat you need a two way control valve.
I'm using an edelbrock mech fuel pump.
From my research the pickup serp will hit the steering box. You need a setup from an f body or an s10.
Kirk Herres
568/thumbs/badbattz.jpg
by battz89
500/thumbs/kick1.JPG
by bad88ss
500/thumbs/mymonte2.jpg
by 85PrimeredMCSS
500/thumbs/drag_car_002b.jpg
by Wisconsin
500/thumbs/resize21.jpg
by JMonte7892
