#988273 - 11/18/13 06:36 PM Just ordered a new hydro boost...
I've been wanting one of these for a couple of years now,so today I pulled the trigger;
http://www.abspowerbrake.com/electrichppage.html
It should be mostly bolt on,but may require some mods to the brake lines because there may be different fittings.(Metric to standard).
#988605 - 11/22/13 05:36 PM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
That website needs some help, lol. The formatting is all gacked up and there is way too much info on the same page. I didn't see a hydroboost setup on there frown
#989180 - 11/29/13 11:00 PM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
MecGen Offline
MecGen  Offline
Montreal Canada
Hi Guy
What made you decide to get one?
Your PM box is full, I had/have a question about importing parts from the states.
Regards
RedHotChilliPeppers.
1987 MCSS.- Sold
1984 MCSS.- Sold
1984 MCSS - came back smile
1995 Mustang 5.0
1965 Pontiac GTO
1969 Pontiac Firebird
#989185 - 11/29/13 11:51 PM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
Frank,I had read about this system a few years ago and was impressed with what I read.Although I cant remember where I saw the article,but it must have been one of my car mags.I decided that I had to have one,but couldnt afford it until now.It should really help to clean up my engine compartment,as well as supply more vacuum for the brakes than I get now.I emptied my PM box,feel free to ask any questions,I am more than happy to help you if I can.
#989187 - 11/30/13 12:19 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
Slackerzinc Offline
Slackerzinc  Offline
Saint John, New Brunswick
Does this unit do away with your brake booster? What is the price of these units?
SSM is right the website really needs help
#989189 - 11/30/13 12:38 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
Yes it does away with the brake booster.They are expensive,a little over $ 1400.00 Canadian shipped via USPS.
#989192 - 11/30/13 01:08 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
Slackerzinc Offline
Slackerzinc  Offline
Looking forward to see pics of install
#989194 - 11/30/13 01:35 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
I'll be at the Atlantic Nationals 2014 if you want to see it in person,up on the hill where the 'Vettes park on Saturday,just sayin'...
#989196 - 11/30/13 02:47 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
Slackerzinc Offline
Slackerzinc  Offline
I will stop in for sure, hopefully mine will be back together.
#989268 - 12/01/13 06:01 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I'll be curious as to the longevity of such a design. I'm aware of the benefits of using a tried and true hydroboost from Hydratech for example but not as much up to date on an electric pump assisted brake system. I assume there is a pressure switch to cycle up to the required 1200 psi? My question is whether the seals in the aluminum housing will handle the heat generated from the pump having to maintain high system pressures. That's one of the nice things about power steering fluid pressure as a brake assist-the line PSI is always there....providing there no leak of course.
gbodyparts1234@yahoo.com
HARNESSWORX
#989289 - 12/01/13 04:21 PM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
Well Jabin,this product has been around for several years now,so I hope that longevity will be a non-issue.The salseman I ordered it from told me that the pressure is more like 2500 psi.And in case your engine stalls,there is supposed to be up to 20 pumps of the brakes available,whereas the power steering method probably wouldnt have any.
I will know more next year when I get it installed in the spring,but I'm sure hoping it lives up to my expectations...
#989353 - 12/02/13 01:40 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Cool....I look forward to some real world driving impressions of the unit-I like how compact it is....that's a big plus. Curious, how much does the whole unit weigh?
HARNESSWORX
#989354 - 12/02/13 01:44 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
It should really clean up the engine compartment.
I'll ask the wife for a shipping weight when it arrives.
#989789 - 12/07/13 01:56 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
MecGen Offline
MecGen  Offline
Montreal Canada
I can't wait smile
popcorn popcorn popcorn
1987 MCSS.- Sold
1984 MCSS.- Sold
1995 Mustang 5.0
1965 Pontiac GTO
#989840 - 12/07/13 06:57 PM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
Retro Offline
Retro  Offline
Macon,Ga.
That's a lot of $$ for added Elec. assist.
In a stall with stock Hydroboost you get 1 stop from the reserve canistor after that it reverts back to Manual brakes, much better than in a stall with a Vac.booster. The Hydro takes some getting used to, short pedal stroke + minimal effort for unreal stopping power.
I've done a few on the cheap swaps. I had a ton of links but most have died.
http://www.cedarcrestspeedlab.com/techarticles.html?col7=open#CollapsiblePanel7
http://www.vancopbs.com/category_s/66.htm
http://www.vancopbs.com/category_s/114.htm
http://www.brakeandfrontend.com/Article/...st_systems.aspx
http://www.piratejack.net/
http://www.montecarloss.com/community/ub...;gonew=1#UNREAD
#992054 - 01/06/14 09:01 PM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
02intimidator Offline
Matawant, NJ
Easy cheap swap.... guys spend Too much cash converting to hydroboost.
Astro van booster used in junkyard $35
Hoses new from Rockauto $30 for both
Master Cylinder new from Rock $12
Just your typical N/A 9 sec Street Car.
#992182 - 01/08/14 03:51 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
Instead of hijacking my thread and trying to criticize me just because I make good money and want to spend it as I see fit,maybe you two should do a writeup and post it in the DIY section.That way,anybody could see how to add a hydroboost system to their brakes on a budget.
#1003367 - 05/28/14 10:59 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
I finally got started on my hydroboost install yesterday.I got the booster unbolted from the underdash bracket and the master cylinder unbolted from the booster.Next,I need to remove the booster pushrod from the brake pedal.Getting at the brake pedal and bracket is a PITA !!! Small hands would be nice for doing this part LOL.Hope to make more progress today.Forgot my camera yesterday,but I'll take it today.
#1003443 - 05/29/14 10:27 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
Made more progress yesterday,got the new master cylinder bolted to the firewall and the high pressure pump mounted to the inner fender.We didnt get the brake lines hooked up yet,the rear brake line is bigger than the front,1/4 in vs. 3/16.Mark wasnt sure how we were going to proceed,so we did a google search and found adapters are available for this situation.Called NAPA and I'm going to pick one up this morning.I'm hoping we get this project finished up today.
#1003446 - 05/29/14 10:41 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
I just installed the oem 1980's hydroboost on my car but it was such a larger improvement, your going to love it!
#1003447 - 05/29/14 11:03 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
The part I am really looking forward to is not having to work the gas,clutch & brake pedal at the same time because there isnt enough vacuum to work the brakes,especially coming down Gallows Hill when the light is red at the bottom and the car is still cold...
#1003457 - 05/29/14 12:59 PM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
I can lock all 4 up at 60 mph with out too much pedal effort, and I have all stock brakes on the car. Certainly a huge improvement over vacuum booster.
#1003533 - 05/29/14 11:17 PM Re: Just ordered a new hydro boost... [Re: Onebadbowtie86]
markg Offline
markg  Offline
nj
im sorry but this seems scary to me.i upgraded to 11 in drums in the rear a while back and they too locked up easier.i got used to it because the car did stop sooner than before but in a panic stop going 65 70 the rear brakes locked up and in an instant i was spinning 180 deg out of control.
needless to say i went back to the 9 in drums.
#1003549 - 05/30/14 01:28 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
This is not the case, my braking is very controlled. If it was like your saying I wouldn't have it on my car.
I'm just saying my brakes flat out work like they should. Plus they are always available , unlike my vacuum brake set up since my cam doesn't make a lot of vacuum.
#1003550 - 05/30/14 01:34 AM Re: Just ordered a new hydro boost... [Re: GuysMonteSS]
It sounds like you also needed to change your proportioning valve for the bigger rear brakes.
500/thumbs/resize12.jpg
by JMonte7892
500/thumbs/door_panel1.jpg
by Rodney
531/thumbs/blue_convert.jpg
by tonys57chevy
527/thumbs/88SS_ChopFive.jpg
500/thumbs/1983_Monte_Carlo_SS.jpg
by OneCleanMonte
