#986743 - 10/31/13 03:53 AM
So I was looking into LSx Swap Costs...
Stig
Midlothian VA
So.....even though I'm pretty broke right now, I got bored and made a list of parts that the swap seems to require.... along with some prices I found online. As dumb as it may sound, I like to plan ahead, sometimes too far ahead. But I figured that as soon as I make a good amount of money I'll probably try my hand at swapping an LS engine into my car...and this may be a good thread to look back at if needed. Basically, I made a list of parts that seem to be needed, and wanted to know if any of you guys who have done the ls swap can see if this list is missing any parts (or if there's better parts to use).
 85 Monte Carlo SS(Sold) 91 GMC Syclone (Sold) 95 Subaru Impreza (Sold)
#986776 - 10/31/13 04:00 PM
Re: So I was looking into LSx Swap Costs...
[Re: Stig]
87ChooChoo
las Vegas, NV
Might consider an LS1 fan instead of the Intrepid fan. Computer and harness may already be set up to use it.
85 El Camino Choo Choo with L31 350 Crate, TPI, Serp, TES Headers, GN 200-4r, 3.73 8.5 GN Posi, Acura Buckets, '04 GP Console, Electric Mirrors, Electronic HVAC, ZQ8 wheels, Blazer front brakes, LS1 rear brakes, and more.... https://sites.google.com/site/darbyselky/home
#986779 - 10/31/13 04:10 PM
[Re: Stig]
BuzzLOL
Toledo, Ohio
. This is opposed to the cost of swapping in a used Gen.1 350" which starts at only the $100-200 or more for the engine if you do the work yourself and use all the old accessories/tranny/exhaust...
#986792 - 10/31/13 08:07 PM
[Re: BuzzLOL]
Stig
Midlothian VA
Truck headers won't fit between our frames rails. You can get a 4.8/5.3 much cheaper then 1400$. I read somewhere that the shorty headers for an s10 are a perfect fit. I'm guessing the guy who said that was wrong? What about the pacesetters for an fbody? Are they more of a pain then they are worth? And converting your harness to stand alone is not as hard to do as well as familiarize yourself with the harness and system. Plus I like the piece of mind that I did the work and can troubleshoot it, I've read so many times about people getting a bad or messed up conversion harness. Wiring is the only thing I absolutely refuse to mess with. But, then again, I have a family member that would probably be able to do it, so maybe I could ask him. Your 5k mark is about right though, but I also see nothing about fuel lines, pump and driveshaft. Any perticular part numbers that should be used? Also the upper radiator hose is specific to water pump used (truck or car) I see. Thanks. Please don't take this as me bashing your list, more along the lines of constructive criticism as I've been down this road lol. Oh, no. You have me exactly what I was looking for. Thank you. Might consider an LS1 fan instead of the Intrepid fan. Computer and harness may already be set up to use it. I'll keep that in mind. I'm guessing that getting one from an fbody would be best? . This is opposed to the cost of swapping in a used Gen.1 350" which starts at only the $100-200 or more for the engine if you do the work yourself and use all the old accessories/tranny/exhaust... Most gen1 350's don't allow one to get 25+ mpg highway.
#986794 - 10/31/13 08:23 PM
[Re: Stig]
Actually, Buzz brings up a very good point. With all the talk and enthusiasm about LS swaps, sometimes it's easy to get caught up in the excitement and forget exactly what such a swap really costs and what it really buys you.
A well-designed Gen-1 motor can probably get you about 90-99% of the performance of an equivalent LS motor, but you've got to be smart about what parts you choose to put together. This is especially for the cylinder heads. On the fuel economy front, the real difference is fuel injection. So, find an SBC-1 that came with EFI, or take the money saved by not going with an LS swap, and put that into some aftermarket system. My guess is that total cost either way may be roughly comparable.
Best, MAP
#986797 - 10/31/13 09:22 PM
[Re: Stig]
Hunter79764
You will need fuel lines from an FI G body (I reused my 4.3 TBI factory lines without much problem), and probably a Walbro 255 pump for a reasonable performance setup. If you want to have AC, you will probably end up spending some money there as well. Stock compressors tend not to fit unless you notch the crossmember, but there are AC relocation brackets that may help. Just something to look at.
As far as total cost, I went dirt cheap with an already-EFI car and had a little over $2000. $5k for a decent swap should be about right.
And as far as Gen I vs LS, to get a Gen I close to LS, it needs to be EFI like MAP said. That means either TBI (not the greatest for performance), TPI, or LT1 to stay with factory systems. These setups are getting rarer (although you can still find them), and will NEED upgraded parts to match a factory LS on power output. The computer systems are probably no less complicated, and the fuel system would be very similar. Aftermarket setups will be a few thousand by the time you get the bits and pieces you need to finish the install. That means you basically you will spend $3000 for a fuel injection setup (computer/fuel/injection/coils/throttle body etc.) one way or the other.
If that goes on a Gen I that is a cheaper base motor, you may have budget room for new heads and cam to get decent/efficient power. If you have an LS, you will use that money on headers, adapter mounts, and maybe a few odds and ends. I leave the transmission out of it, because if you are happy with your transmission now, you can keep it. If it needs to be upgraded for the power you want to run, you will have to do that either way. You will still end up with 3-400 streetable HP for about the same money, assuming the Gen I was actually cheaper. I can find 5.3's with plenty of life for $300 all day long, but finding a 300 horse 350 Gen I in decent shape means it is either a crate motor for a few thousand or a recently rebuilt motor that you hope was built right, or rebuilding your own for possibly a lot more than $300. As far as reusing stock accessories, personally I was happy to lose the 25 year old AC compressor, power steering pump, and alternator running on 4 V belts in favor of a late model serpentine setup with parts readily available (I had to go to 3 different stores to get an alternator for my old setup, but the new one can be found anywhere).
Ultimately, I thought it was well worth it, especially since I didn't have many perfectly good SBC parts already on the car, but obviously everyone's car, preference, goals, etc is different. Good job thinking things through ahead of time though.
#986803 - 10/31/13 10:31 PM
[Re: Stig]
Hi Hunter,
Thanks for shedding more light on that. I continue to get the impression that the cost is very roughly comparable, with a few thousand dollars that could go either way (!) depending on build particulars.
Best, MAP
#986827 - 11/01/13 01:46 AM
[Re: Stig]
gmachinz
Des Moines, Iowa
I went a different direction and picked up a perfectly smooth running 95 Roadmaster Wagon with an LT1 for $1200 for my Monte project. Other than a TBI 4.3 fuel tank, the drivetrain is a direct swap. With the right offset, I can also use the stock 8.5" 3.73 Auburn posi rear, and throw the b-body spindle stuff on with aftermarket upper arms. Dollar for dollar, its a pretty good setup. ill have about $2200 into the whole swap over and, that gets me auto climate control, auto headlight conversion, power antenna, ABS, etc. I would look for a complete LS donor car.
gbodyparts1234@yahoo.com
HARNESSWORX
#986883 - 11/01/13 09:52 PM
[Re: SS Ninja]
Stig
Midlothian VA
I went a different direction and picked up a perfectly smooth running 95 Roadmaster Wagon with an LT1 for $1200 for my Monte project. Other than a TBI 4.3 fuel tank, the drivetrain is a direct swap. With the right offset, I can also use the stock 8.5" 3.73 Auburn posi rear, and throw the b-body spindle stuff on with aftermarket upper arms. Dollar for dollar, its a pretty good setup. ill have about $2200 into the whole swap over and, that gets me auto climate control, auto headlight conversion, power antenna, ABS, etc. So with the LT1 setup, the engine, and trans are pretty much a direct bolt in? I'm guessing the following mods were needed: 700r4/4l60 crossmember Driveshaft length changed Gas tank/sending unit/pump for a FI car Modified or standalone harness. Anything else? Seems that roadmasters are pretty easy to get for about $1200 as well.... This is definetly another option. I would look for a complete LS donor car. Seeing as how I can sell off the other parts from a camaro/firebird pretty easily, I may do that. That way I could also rip out the seats and some of the oother fbody goodies while I'm at it. I found a few LS1 fbody cars in my area for about 4k, which is reasonable if the engine and trans are ok. Thanks for the info, and the links.
#987044 - 11/04/13 08:02 PM
[Re: MAP]
BuzzLOL
Toledo, Ohio
On the fuel economy front, the real difference is fuel injection. So, find an SBC-1 that came with EFI, or take the money saved by not going with an LS swap, and put that into some aftermarket system. -MAP .. Actually, the late 1980's Monte LS with 305" V8, 200-4R tranny, and Q-Jet carb. was factory rated at 25 MPG Hiway, so that would be a good starting point for thinking about how to get similar MPG from, say, an improved carb'd 350" Gen.1 engine... before VVT (variable valve timing) and DI (direct injection), the EFI V8 vehicles of similar size/weight were rated about the same as Q-Jet ones for MPG... most of the later improvements in MPG from the horrible early 1970's Dark Ages of Engines came from internal engine improvements such as higher compression ratio, better quench effects, smarter cam designs, better piston top designs, and better combustion chamber shapes... which can be easily added to older Gen.1 engines with carefully chosen used and/or aftermarket parts... factory stock MPG essentially doubled in late 1970's and 1980's compared to early 1970's, all still using carb.s, especially the sophisticated Q-Jet carb... improvements in MPG after that were slight, if any, even using EFI... until VVT and even more sophisticated computer software controlling the EFI came along...
#987069 - 11/05/13 03:22 AM
[Re: Stig]
Buick Runner
I agree with Buzz, you can get very good MPGs with carburetors. I think the reason most people assume carbs are poor for MPGs is due to most people being used to aftermarket racing carbs like Holley and Eddy which are not designed for MPGs like the Qjet and other factory carbs were. Also that carb tuning is a dying black art these days. Then there are crappy "reman" carbs that are nowhere near spec or cheap generic parts from the chain stores. How many times have we seen people rip out their CCC Qjets for aftermarket carbs and then complain that both their MPGs and power were worse. Heck Smokey got 51 MPGs out of an iron duke without EFI or computers.
Other factors are how well the engine was maintained and nothing is worn out or going bad. I suspect alot of G bodies are driving around with many worn out tune up parts. Also driving habits really affect your MPGs. No matter how your fuel is injected or what your engine block is made of, if you stomp the throttle all the time your MPGs are not going to be good.
#987094 - 11/05/13 07:11 PM
[Re: Stig]
Q-jets are indeed an amazing carburetor for performance and economy. And the few living experts on that carb are probably in retirement or close to contemplating it. It's a tough carburetor to tune - at least for me. And, if the OP is looking for more power than the original motors that Q-jets came with, then it's a given that custom tuning will be needed. The question of mindset strongly enters here: if one is "analog" and works well with mechanical things, then learn carburetors. If one is "digital" and is more comfortable with a keyboard, then go EFI, but go with something reasonably new.  EFI systems are much more complex than carburetors, and unlike carburetors, when something breaks, it may easily die completely, rather than go gradually out of calibration as would a carburetor.
#987096 - 11/05/13 07:40 PM
[Re: Stig]
gmachinz
Des Moines, Iowa
All correct except for the ECM...I'm using the stock Roadmaster LT1 ECM for now. I already have a complete LT4 top end for it.....as well as an Fbody Vortec centrifical supercharger for it. I have a friend who is designing an ECM interface to tune the stock ECM so I can push about 8-9 psi through the LT1. Looking for around 550 HP and at least 600 ft lbs of torque. My target weight is 3100 lbs fully loaded. Should make for a fun roadcourse Monte. We shall see.
HARNESSWORX
#987723 - 11/12/13 03:55 PM
[Re: Stig]
blubaldmontess
Clarksville, TN
You can use icemans crossmember and save yourself a few bucks http://www.maliburacing.com/iceman/The wiring harness also needs to have the computer reflashed, I used a company from ls1tech. YOu can find them cheaper than you posted, but its all about how much feedback and if they are good or not. For the Throttle cable I used the Lokar throttle cable for an LS1 from summit racing. The swap always had a few little things but the people have been there and done that so you can ask questions and recieve answers immediatly. I scoured ls1tech.com and looked under the hybrid section to get as much info as possible. If you can't get the a/c system to fit under the hood, you can always use http://www.kwikperf.com/ for different setups/brackets.
by ray396
by stevec_87SS
by Witman69
by donzss
by TriumphoverU
