#986320 - 10/25/13 10:14 AM 2005 monte carlo ss gage cluster
kman64 Offline
kman64  Offline
sacramento ca
I have a 2005 Monte Carlo tony stewart edition it has about 90,000 miles on it and my temp,fuel,oil gauges stopped working it also happened to my 2000 ss monte as well is there a recall that im not aware of
#986488 - 10/28/13 02:12 AM Re: 2005 monte carlo ss gage cluster [Re: kman64]
RoadWarrior Offline
RoadWarrior  Offline
Mechanicsburg, Pa
that's pretty common on GM's from about 2000 till about '08.
there was a recall on the trucks because the speedo's would fail, but i don't think the recall includes any of the "accessory" gauges such as tach/fuel/oil/temp/volts.
the common failure is the stepper motors that drive the needles, they fail/wear out over time, there are places online that you can ship the cluster to for them to fix, or you may be able to find a repair shop in your area you can take it to.
there are the rare occasions when there's a problem with the car and not the cluster, but normally when this occurs it's either one gauge or all, normally not just a couple.
a quick way to tell if its just the gauge(stepper motor) failed is during the "self" test. Most GM's will run a self test when you first turn the key on, the gauges should drop to zero and then run through their full sweep, and then return to where they should be. HTH
MadMax
88 SS, 355 owned since '03
#986873 - 11/01/13 06:59 PM Re: 2005 monte carlo ss gage cluster [Re: kman64]
kman64 Offline
kman64  Offline
sacramento ca
Thank you for the info i will take it to a speedo shop and have them look at it
#986876 - 11/01/13 08:04 PM Re: 2005 monte carlo ss gage cluster [Re: kman64]
Google "GM cluster repair", there are numerous places that repair the clusters for very reasonable. Certain years had problems with the stepper motors, replacing several on the cluster may be necesary. Also the cluster lights are a problem, they are soldered to the board, the bulbs are not readily available.
Also you can find You-tube video which shows removal of the cluster.
My 02 SS has a bulb out next to the tach, bought 30 bulbs so I had enough to do several clusters, just can't find the interest to remove the cluster out of the wife's SS for one bulb.
#987145 - 11/06/13 03:39 AM Re: 2005 monte carlo ss gage cluster [Re: kman64]
chevelle502 Offline
chevelle502  Offline
Dundalk. MD
my 01 SS cluster failed and luckily it was covered under the extended warranty i purchased...there are kits on EBAY for the DIYer if you'd like to attempt that. You can also send it out to one place, get LEDS put in, and custom gauge faces put on as well as replace the motors...
Black w/T-tops
1096/thumbs/DSC09166.JPG
by NC87AERO
500/thumbs/100_04901.JPG
by Bad85LS
500/thumbs/mcsusp2.jpg
by javi05
500/thumbs/IMG_0356.JPG
by 565bbchevy
500/thumbs/downsized_0330121649.jpg
by blkcharlotteman
