#984308 - 09/28/13 04:02 AM Moser Differential
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
Brought my SS to the transmission shop to find out what is causing my vibration at 65mph. You could feel the vibration through the floor board. They found that when you spin the yoke (part that connects to the drive shaft) you can feel some tension while your spinning it. So I need to rebuild the differential. It looks like I will have spend around $1300 when all done. The owner of the transmission shop asked me if I want to consider going with a Moser 8.5 inch (I believe this is also called a 12 bolt). He believes it will be around $2000 but he is going to check prices on Monday. Anyone using the Moser differential 12 bolt? I have read on this forum that the shocks won't line up. Is this a major project to correct and will it drive the cost up? Is it a worthwhile upgrade? Motor isn't making huge HP now but you never know what the future holds.
86 Monte Carlo SS W/T-Tops 'Original Owner'
355 CI, Hooker Super Comp Headers, True Dual Exhaust, Comp Cam Roller Cam (XR276HR-10), Q-Jet Carb 795CFM. 200-4R Transmission. 2" Lowered Suspension.
#984314 - 09/28/13 11:45 AM Re: Moser Differential [Re: Cos86SS]
If more HP is in your future,a stronger rearend would be a required upgrade,IMO.If its only $ 700.00 more for a complete rear over a rebuild,I would go for a new one.
You may want to make sure that you are getting a complete ready to run package for that price.Brakes may be extra,or possibly the old ones could be re-used.
#984316 - 09/28/13 12:03 PM Re: Moser Differential [Re: Cos86SS]
Joe87monteSS Offline
Memphis,TN
A few things. A 12 bolt is NOT an 8.5 rear. Those are two different things. A 12 bolt has an 8.875 inch ring gear vs. the 8.5 10 bolt. If it is an aftermarket unit, it will be specific for the G body.
Joey
Engine/head builder/machinist
2004 Silverado
Facebook
#984322 - 09/28/13 03:25 PM Re: Moser Differential [Re: Joe87monteSS]
I have one and the shocks line up perfect. Just incert a tappered shim inbetween the shock and mounting plate.
The 12 bolt rear is an upgrade. But for 2K it won't be nothing that good. What do you have under the hood?
#984354 - 09/29/13 02:01 AM Re: Moser Differential [Re: 1 Slow SS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
I'll make sure I know what I am getting for the price he quotes me. If it's well above 2K I will most likely pass.
That would explain why I could not find a 8.5" on their website. If I go for the new differential I'll make sure that no other modifications will be required or else the price will go up.
I am running a SBC 355 with double hump heads (1.94" valves, 63cc) and a Comp Cam Roller Cam (XR276HR-10). I am under 300HP but if something ever breaks, first thing I would do is upgrade the heads for more power. I am not looking for anything that can handle huge HP but just a better unit than the 7.5" if the price is right. It's good to know that it should fit if I decide to go for it.
I'll know more on Monday and will let everyone know what I decided on. Thanks for everyone's input.
#984412 - 09/30/13 12:51 AM Re: Moser Differential [Re: Cos86SS]
mikester Offline
mikester  Offline
smalltown ny
Im one of the people that had a problem with a Moser 12 bolt. Theres also a guy on turbo buick that's going through almost the same thing right now. My rear was close to $3K. The spring perches were welded in the wrong place. My springs wouldn't fit right. Moser sent me a new rear but it was only after I argued with the production manager. The new rear came with the spring perches in the crate so they could be welded on during the install. As far as the shocks, no they don't line up right and they have to be played with. Not what I expected for a direct replacement rear. From what Ive read it doesn't matter what brand rear you buy, its all the same way.
#984430 - 09/30/13 03:47 AM Re: Moser Differential [Re: Cos86SS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
For $3K one would expect a direct fit. Since I'll be having mine installed by the Transmission shop i would expect them to make sure it is a direct fit without any mods. I wonder if the 8.5" is a direct fit. It's what the transmission shop recommended. Besides I do not want to spend more than $2K.
#984563 - 10/02/13 12:21 AM Re: Moser Differential [Re: Cos86SS]
NYmonteSS Offline
NYmonteSS  Offline
Brentwood N.Y.
You can get a 8.5 out of an Olds 442, Buick GN. Stock these will handle what you have with no problems at all and a lot more.
Its a direct swap in, you can get them for $1000 and under sometimes.
This would be the cheapest and good upgrade from the 7.5.
so figure $ wise
$ 1000 for the rear, complete, drum to drum
$ ? shop install labor price
$25 fluid & gasket & RTV
You could be in a area of $1400 $1500 by the time your done!
#984571 - 10/02/13 01:28 AM Re: Moser Differential [Re: NYmonteSS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
so figure $ wise
I am already at$1300 if I need new Pinion and gears for the 7.5. I haven't heard from the transmission shop yet but I am calling them tomorrow to find out what is going on.
Thanks for the info.
#985326 - 10/11/13 01:24 AM Re: Moser Differential [Re: Cos86SS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
I called the transmission shop today and the plan is to rebuild my stock 7.5". Turns out that they could not find an 8.5" in my price range. I was told that an 8.5" would cost $3K and it's not even a direct fit. The tranny guy told me that all the places he had contacted told him that he would have to make major modifications to make it fit including welding. $3K is more than I am willing to spend. Now I just hope that the rebuilt diff. will take care of my vibration issues. Should know tomorrow if it helped. Thanks everyone for your help.
#985510 - 10/13/13 07:30 PM Re: Moser Differential [Re: Cos86SS]
FatBoyFresh Offline
FatBoyFresh  Offline
Frederick, MD
sounds like they were talking about using a leaf spring 8.5 out of a truck and welding brackets to it and cutting the tubes to make it fit for the 3K price. If they rebuild the factory unit get a good ring and pinion, not just a cheap stock replacement. Also now is the time to upgrade to a taller gear if you were planning it. Also possibly upgrading the axles to something to help hold some additional power.
#985537 - 10/14/13 03:29 AM Re: Moser Differential [Re: Cos86SS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
No Cheap stuff. I made that clear when I dropped the car off and the guy agreed with me. I am sticking with the 3.73 ratio. I sometimes go on the highway and the 3.73s are just right. Should be picking up the car tomorrow. wasn't ready on Friday. GM send him the wrong Yoke.
#985586 - 10/15/13 01:04 AM Re: Moser Differential [Re: Cos86SS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
Picked up the car today. vibration at 65mph and above is gone. I still have a vibration through the steering wheel which was there before. It seems to vibrate from low speeds upto 85mph (Had to bring it up to 85mph to make sure the differential problem was fixed). I had the steering wheel vibration before I lowered the car 2 years ago but the vibration from the differential was much worse. Now that that's taken care of where should I look for the steering wheels vibration? How can I rule out the motor? Thanks,
#985599 - 10/15/13 11:27 AM Re: Moser Differential [Re: Cos86SS]
MikesMontes Offline
Authorized Vendor
MikesMontes  Offline
Authorized Vendor
west central ohio
steering wheel vibration should in wheels and tires ---have you had them balanced lately
www.mikesmontes.com
1-800-811-5851
#985634 - 10/15/13 11:52 PM Re: Moser Differential [Re: Cos86SS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
Hi Mike,
Yes, I had them balanced 2 years ago when I first noticed the vibration through the steering wheel. The balancing did nothing. I have had this problem prior to lowering the car 2 years and it's one of the main reasons I redid the suspension (New shocks and springs) but that also did not help with the vibration. I know I have a lot of play in my steering wheel due to wear and tear (steering box), could this be the cause assuming my tires are ok?
#985637 - 10/16/13 12:15 AM Re: Moser Differential [Re: Cos86SS]
MikesMontes Offline
Authorized Vendor
MikesMontes  Offline
Authorized Vendor
west central ohio
rotate fronts to back ---still should be wheels or tires
www.mikesmontes.com
1-800-811-5851
#985642 - 10/16/13 01:18 AM Re: Moser Differential [Re: Cos86SS]
AkronAero Offline
AkronAero  Offline
Need and alignment?
On rare ocassion you can have a bad tire (say, belt separation) which won't give constant balance... are you confident of the tires? Wear uneven?
#985646 - 10/16/13 01:52 AM Re: Moser Differential [Re: Cos86SS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
There is no uneven wear. The tires are 3-4 years old and they look new. I could most certainly have a belt problem. Perhaps rotating the fronts to back as Mike suggested would be the easiest thing to try. The rears are 245s vs. 235s in the front but hopefully they wont rub on the inner fenders.
#985660 - 10/16/13 01:13 PM Re: Moser Differential [Re: Cos86SS]
AkronAero Offline
AkronAero  Offline
even for a trial run of a few hundred miles, just to check the balance.
#985663 - 10/16/13 01:56 PM Re: Moser Differential [Re: Cos86SS]
Slackerzinc Offline
Slackerzinc  Offline
Saint John, New Brunswick
245's will fit up front with out any trouble
989/thumbs/my_monte_34.jpg
by 85montanezcarloss
500/thumbs/17.JPG
by Mark's SS
500/thumbs/20150509_140833.jpg
by MANDS480
500/thumbs/mcss_3.JPG
by easterngwy
500/thumbs/16939234_10154063236221642_4615378538672679921_n.jpg
by WESTWOODSS
