#981413 - 08/26/13 07:03 PM Major oil leak
Dgriffin29 Offline
Dgriffin29  Offline
Concord,NC
For some reason when I add oil through the driver side valve cover, most of all of the oil that I add runs out below the exhaust manifold. I have changed the valve cover gaskets 2 times now and this hasn't fixed it. When ever it runs out, it comes out and drips down the motor mount on the driver side. It is only leaking on the driver side, the passenger side is fine. Its a 1984 Monte Carlo SS with the stock 305 still in it.Please help!
#981441 - 08/26/13 10:24 PM Re: Major oil leak [Re: Dgriffin29]
pazzo1969 Offline
pazzo1969  Offline
Mableton, GA
I would pull the cover off and check that the oil return passages are not gunked up keeping to much oil up top.
#981448 - 08/26/13 11:41 PM Re: Major oil leak [Re: Dgriffin29]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Sounds to me as if your vc siderail is warped....it must be perfectly flat to seal properly. And, I would suggest using longer load bars to distribute the clamping.
gbodyparts1234@yahoo.com
HARNESSWORX
#981450 - 08/26/13 11:57 PM Re: Major oil leak [Re: Dgriffin29]
LXXXIV SS Offline
LXXXIV SS  Offline
Lower Peninsula, Michigan
I agree with gmachinz, especially since you said you've already changed gaskets twice already.
Many times, guys find the valve cover leaking and start tightening down on the screws in an effort to seal the leak. They don't realize that this only makes matters worse because it warps the cover. Then when that doesn't stop the leak, they apply even more torque, making matters even worse. The more you tighten, the more it leaks. Take the cover off, clean it up real good, then lay it on something really flat, like a piece of glass. Make sure it's dead straight.
#981451 - 08/26/13 11:58 PM Re: Major oil leak [Re: Dgriffin29]
X2 on the bent valve cover. Also with mine the stock exhaust manifolds would cook the gaskets. I used a can of "the right stuff" and it fixed the leak. Follow the directions on the can. Fixed the issue I had and dealt with the same thing as you but mine was both sides.
#981463 - 08/27/13 01:27 AM Re: Major oil leak [Re: Dgriffin29]
Dgriffin29 Offline
Dgriffin29  Offline
Concord,NC
So if I take it off and the valve cover is bent should I replace it or should I add some of the longer load bars, and some put some of "the right stuff" on it??
#981469 - 08/27/13 01:55 AM Re: Major oil leak [Re: Dgriffin29]
32v_dohc Offline
32v_dohc  Offline
my garage
Just flatten the cover to be flat using a straight edge as a guide. Also check the drain back holes. The valve cover rail is tall enough tht properly draining heads won't just gush out.
#981470 - 08/27/13 02:03 AM Re: Major oil leak [Re: Dgriffin29]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Number one is to make certain the side rails are flat...use a deadblow to knock them flat on a piece of 2x4 then clean with brakleen and once dry, use a thin bead of RTV Ultra Black between the bc and gasket, then lightly bolt them back down on your heads.
If the vc's are chrome, do the above but once clean, use a wirebrush on a wheel to remove the chrome finish off the gasket surface....chrome does not seal well where heat is concerned. The RTV will conform to irregularities on the valve cover and the cork by itself will seal well against the head. Oh yeah...and stay away from the rubber ones...use only cork/rubber such as Fel-Pro VS12869AC - those are thicker for a better seal.
HARNESSWORX
#981471 - 08/27/13 02:07 AM Re: Major oil leak [Re: Dgriffin29]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
I think the guys have hit it on the nose with the warped cover,I don't think 'drain back holes are plugged as a valve cover should seal with oil pooled right against it.
I like to use silicon gaskets (not cork) and glue them to the cover with high temp RTV, when still tacky set them on the gasket side so the weight of the cover will keep the gasket flat while the RTV sets up. When re-installing it use a little motor oil on the exposed gasket and you should be good to go. If you can afford it, springing for some cast aluminum valve covers, they won't warp, this leaking has been a problem with small block chevies since 1955, that is why they FINALLY went to center bolts in the 1987 to seal them up!
1090/thumbs/28398_455414503661_7962178_n.jpg
by UNOH_MONTE
500/thumbs/84_SS.JPG
by 84SS84
500/thumbs/Picture_075.JPG
by Intmdatr3
500/thumbs/IMG_1454.jpg
by Billdo38
500/thumbs/HPIM1900.JPG
by LT1SSJC
