#979913 - 08/07/13 10:31 PM Need help with Ford 9inch wheel dimensions
Merza65 Offline
Merza65  Offline
northborough massachusetts
Hey guys. Been off the forum for quite sometime but im back. I did a frame restoration and put together a 468 big block with a monster 200 4r transmission as well as a ford 9 inch rear with a detroitlocker. I also will be finishing up the 10point cage sometime this week. I upgraded to disk brakes in the rear. The axles are moser and the hub measures 3.054 inches in diameter which is too large of a diameter for the stock ss wheels.
My question is what back spacing and offset do I need to replace these wheels with just other 15s possibly cragar centerline or weld rims? The axles are the gm 5x4.75 so thats still the same.
If yall would like I could post pictures of my ongoing project. Thank you.
#979915 - 08/07/13 10:44 PM Re: Need help with Ford 9inch wheel dimensions [Re: Merza65]
SSLance Online content
SSLance  Online Content
How close are the hubs to fitting in the wheels?
I had to hog out the centers of my ZQ8 wheels just a tad to get them to go on my hubs, is that an option for you?
And yes... Pics please!!
#979917 - 08/07/13 11:37 PM Re: Need help with Ford 9inch wheel dimensions [Re: Merza65]
Merza65 Offline
Merza65  Offline
Well I used my caliper to measure the hub of the axle and got 3.054. I couldnt get it inside the rim to measure exactly but from using a tape measure to ball park it and put it up against the caliper id say at least 1/8th needs to be bored out. Did you have a machine shop hog it out? Also what dimensions are you using for your wheels? With the stock 15x7 rims and 265/60 tires they stick out a hair outside the quarter panel. My biggest concern is the backspacing and offset that I would need. Any recomendation?id like to stick to 15x7x60.
#979939 - 08/08/13 03:05 AM Re: Need help with Ford 9inch wheel dimensions [Re: Merza65]
Merza65 Offline
Merza65  Offline
Bump?
#980235 - 08/12/13 12:39 AM Re: Need help with Ford 9inch wheel dimensions [Re: Merza65]
86SSLS1 Offline
86SSLS1  Offline
Mechanicsville, VA
I just put a 9" rear in mine. I went with speed performance axles since I got rear there. My stock wheels fit fine and I have 255 x 60 x 15 BFG's and they don't stick out from fender wells. What disk brake setup are you using?
86 Monte SS LS1 A4. Z06 Intake, MTI B1 cam, Manley springs and retainers,Grannetelli 85mm Mass Air, stock TB, Hooker LT headers, Dynomax mufflers, Dual exhaust. Cats & H-pipe. 12.64@112
#980236 - 08/12/13 01:11 AM Re: Need help with Ford 9inch wheel dimensions [Re: Merza65]
pazzo1969 Offline
pazzo1969  Offline
Mableton, GA
I have used mosier axles in several gm apps. And the stock cast wheels have always needed a little hogging out. If i kept stock wheels on the car i would send them out to be machined to match said axle. I guess mosier beefs up that area more. I have never used their " stock" axles either. Hope this helps. Pazz
#981197 - 08/24/13 01:03 PM Re: Need help with Ford 9inch wheel dimensions [Re: Merza65]
Capitalsfan Offline
Capitalsfan  Offline
Fredericksburg, VA
What did the 9" come out of or was it a rear modified to fit the stock gbody? I have a Quick Performance 9" in my 85 and have had no wheel fitment issue. I also have moser axles with the gm bolt pattern.
1985 SS white, 357 CI, Crane Cam, Edelbrock alum heads and intake, Holley Street Avenger 670, MSD billet dist, MSD 6a, MSD 8975 box, Hooker Ceramic Coated full length headers, Flex-a-lite fans, March Serpentine pulleys and mounts, Flomaster 50's, TCI TC and Street-fighter trans kit, Quick Performance 9" 4.10 Tru-Trac, Edelbrock plate system
#981265 - 08/25/13 05:43 AM Re: Need help with Ford 9inch wheel dimensions [Re: Merza65]
WFO_SS Offline
WFO_SS  Offline
dallas, tx
my stock wheels fit my moser axles perfectly fine.
completely stock except for engine, tranny, exhaust & rearend.
by Monster
523/thumbs/DSC_0656.jpg
by Dad's SS
1164/thumbs/IMGP6649small.jpg
by Witman69
523/thumbs/DSC_0633.jpg
