#976286 - 06/28/13 09:11 PM Let's say my rear end is bad....
Bad86SS Offline
Bad86SS  Offline
Kentucky
Mild 350, built 200-4, soon to be big block. Keep that in mind....
My rear end is making a loud noise, and I feel it's getting ready to go. Is there a strong, disk brake rear end that's a good junkyard swap for these cars?
#976293 - 06/28/13 09:51 PM Re: Let's say my rear end is bad.... [Re: Bad86SS]
rons87mcss Offline
rons87mcss  Offline
PA
Unfortunatey, the only bolt-in rear for our cars that is any better than the 7.5"/7.625" is the 8.5" from a Buick GN or Olds 442(85-87) or Hurst Olds(84) but they also came with drum rear brakes.
#976296 - 06/28/13 10:34 PM Re: Let's say my rear end is bad.... [Re: Bad86SS]
Bad86SS Offline
Bad86SS  Offline
Kentucky
I was wondering about the 90' fbodys
#976300 - 06/28/13 10:57 PM Re: Let's say my rear end is bad.... [Re: Bad86SS]
Wisconsin Offline
Wisconsin  Offline
Catawba, Wisconsin
short answer is they don't fit. They use a torque arm suspension.
Your options are the 8.5 mentioned above or buy a 9 in. or 12 bolt or an S60 from a place like Quick Performance,Currie, etc. There is no inexpensive upgrade for the rear end.
#976444 - 06/30/13 04:01 AM Re: Let's say my rear end is bad.... [Re: Wisconsin]
werd Unfortunately he's right. Sucks, huh?
#976632 - 07/01/13 11:45 PM Re: Let's say my rear end is bad.... [Re: Bad86SS]
Bad86SS Offline
Bad86SS  Offline
Kentucky
yep
#976854 - 07/04/13 12:34 AM Re: Let's say my rear end is bad.... [Re: Bad86SS]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
The old Chevelle 12 bolts 'almost fits' but no disk brakes you would have to add that.
Here is the info I found:
the lowers bolt right in , the uppers need to be off set look on ebay do a "g body" search and look for 12 bolt conversion upper they are around $145 or go to malibu racing.com and check site sponsor iceman he has them, you will need to move the coil spring holder from infront of the axle tubes to the top of the tube and then you need to run a different backspace wheel you need 5 1/2 back space instead of the regular 4 1/2 back space.
#976868 - 07/04/13 02:26 AM Re: Let's say my rear end is bad.... [Re: Bad86SS]
FatBoyFresh Offline
FatBoyFresh  Offline
Frederick, MD
wasn't there el caminos that came with 12 bolts in them?
#976873 - 07/04/13 02:56 AM Re: Let's say my rear end is bad.... [Re: FatBoyFresh]
Wisconsin Offline
Wisconsin  Offline
Catawba, Wisconsin
I believe when they were A bodies (based on Chevelle)
#976884 - 07/04/13 06:43 AM Re: Let's say my rear end is bad.... [Re: FatBoyFresh]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
Yes, these were the same as the Chevelles and is an A-body like I wrote about. Same thing, you can use it with some modifications.
#976913 - 07/04/13 05:42 PM Re: Let's say my rear end is bad.... [Re: Bad86SS]
What years for the Chevelle rear?
#976925 - 07/04/13 08:42 PM Re: Let's say my rear end is bad.... [Re: Hunter79764]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
It was used in GM cars like Chevelles from 1965 to 1972 when the corporate 10 bolt was used. They continued to be used in trucks up until 1982.
The El Camino's were the same, they got the 10 bolt in 1972.
#977660 - 07/12/13 03:36 PM Re: Let's say my rear end is bad.... [Re: Bad86SS]
Retro Offline
Retro  Offline
Macon,Ga.
The Corporate 8.5" 10-Bolt started to be used in 70, before that the 8.2" 10-Bolt was used Chevelles. 12-Bolt = 65-72.
A-body Rear Info:
http://www.oldsmobility.com/old/10bolt-tech.htm
Chevy 10-Bolt Rear ID Pics:
http://www.novaresource.org/axle.htm
A-Body Rear widths:
64-67 = 60" WMS to WMS.
68-72 = 61" """""" "" """""".
G-Body Rear width:
78-88 = 58" WMS to WMS.
WMS = outer Wheel Mounting Surface or Drum to Drum.
#977675 - 07/12/13 06:11 PM Re: Let's say my rear end is bad.... [Re: Bad86SS]
I got my 12 bolt out of a 69 Chevelle. I used the UMI 12 bolt swap kit for the install. I also already had their adjustable lower control arms already. But, you can use the Chevelle control arms in the Monte. The brake lines will bolt right up to the wheel cylinders of the ones in the 12 bolt. YOu just might want to add a bit of extra line to the rear cause it is a little tight. You will need the extra backspaced wheels for it as well. I have seen people that install it and never moved the spring perches from the 12 bolt location to be centered over the axle. I guess that is up to you on that front. You can use any of the rears out of the Chevelle from 66-72. Other than that it's pretty simple swap.
#977845 - 07/14/13 07:38 PM Re: Let's say my rear end is bad.... [Re: Bad86SS]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. Some Ford 8.8" (Versailles, T-Birds?)) and 9" (Lincoln) rears came with disc brakes and posis, but would need redrilled wheel bolt pattern, maybe narrowed axle housings and axles, remounted or added suspension mounts... or Strange and Moser can supply everything ready to bolt in...
.. Prolly should identify exactly what's making the noise in your current rear end/suspension and exactly what rear end it is... some rear ends are supposed to make obnoxious noises!
#977943 - 07/15/13 09:17 PM Re: Let's say my rear end is bad.... [Re: Bad86SS]
84supersport Offline
Louisville, KY
Clunking or whining? My original rear end started whining at certain speeds as the miles got up there. Then when the pinion seal was leaking after it sat for two years it made more noise when the fluid got low. The 7.5 7-5/8 rears can handle some power as long as you never put slicks on it, or let it wheel hop.
For what some people want for a stock 8.5 I'd invest that money in an aftermarket rear end or having a 9" or 12-bolt modified to fit. There's Gears R Us on Dixie, Wayne Grubb might even have something laying around.
#979117 - 07/29/13 07:59 AM Re: Let's say my rear end is bad.... [Re: Bad86SS]
Bad86SS Offline
Bad86SS  Offline
Kentucky
Its not a clunk.....its a whine
#979118 - 07/29/13 08:03 AM Re: Let's say my rear end is bad.... [Re: Bad86SS]
Bad86SS Offline
Bad86SS  Offline
Kentucky
this guy on a gbody facebook group posted that he took z28 gears and made his posi. Maybe I should do that and top her off with new fluid in the rear
#979225 - 07/30/13 11:12 AM Re: Let's say my rear end is bad.... [Re: Bad86SS]
Louisville, KY
My original rear would wine. Could be wear or low on fluid or just old fluid. Anything you find with a 7-5/8 with 26 spline axles the gears and carrier will fit in yours. You may have to re-shim everything for your housing or it may just drop in. I think all the Camaros and S-10s had 26-spline axles like the G-bodies. I've never done gears but I already know my s-10 will need a limited slip cause even with the 4.3 it's a tire fryer.
#979309 - 07/31/13 02:49 PM Re: Let's say my rear end is bad.... [Re: Bad86SS]
Retro Offline
Retro  Offline
Macon,Ga.
Around 88 most all 7.5"/7.625" 10-bolts switched from 26-spline to 28-spline axles so, check first.
500/thumbs/306537_10151142014953465_994827867_n.jpg
by adi
500/thumbs/CH220175compressed.JPG
by John S
500/thumbs/SS_on_22_inch.jpg
by G-bodySS
1130/thumbs/ResizedImage_1390834191345.jpg
by O.G.
500/thumbs/IMG_0552.JPG
by montesleeper83
