#975086 - 06/16/13 05:36 PM body mounts
msh1987 Offline
msh1987  Offline
Hamilton, Ontario
Looking for number of points and where located other than the rad support bushings...and on repairing frame mounts are there any referenses used to make sure the fix and hole is in the right place...haven't pulked body yet but need to.
Thanks for all your help.
#975100 - 06/16/13 07:36 PM Re: body mounts [Re: msh1987]
pazzo1969 Offline
pazzo1969  Offline
Mableton, GA
#975561 - 06/21/13 11:46 AM Re: body mounts [Re: msh1987]
msh1987 Offline
msh1987  Offline
Hamilton, Ontario
That is cool but how do you orient the eashers so they line up?
#975562 - 06/21/13 11:47 AM Re: body mounts [Re: msh1987]
msh1987 Offline
msh1987  Offline
Hamilton, Ontario
#975620 - 06/21/13 11:20 PM Re: body mounts [Re: pazzo1969]
msh1987 Offline
msh1987  Offline
Hamilton, Ontario
They are cool pics.....how do you orientate the washer so it lines up with the body?
#975864 - 06/24/13 04:55 PM Re: body mounts [Re: msh1987]
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=865745&page=17
That's my frame off project ^
There is an alignment hole next to the #2 body bushing on the driver's side that I got lined up first, and then I just tried to center the frame under the body at the rear. I also double-checked my alignment with a few of the mounts that were not deteriorated.
I used a plumb-bob on the ones that were too rotted out to tell where the hole used to be. I took one of the big frame repair washers and put duck tape over it and then marked the center with a sharpie. Then I held the plumb bob to the body mount so that it pointed down at the frame and aligned the washer center under the plumb bob. Then you can trace around the washer. After that, I placed another washer in the traced outline and spray painted over it to get a more exact outline of where I needed to cut to weld in the new washer.
#976058 - 06/26/13 03:06 PM Re: body mounts [Re: SickSpeedMonte]
msh1987 Offline
msh1987  Offline
Hamilton, Ontario
Very nice that's what I was looking for that's a good inexpensive way to get it lined up.....on that note I actually need to fix the same 4 mounts on the body too....so I can plumb it to the 4 that are not rotted away
#976173 - 06/27/13 04:41 PM Re: body mounts [Re: msh1987]
Google Conrad Lozier. He shipped me the new body mount pockets. Make marks which locate where the centers of the body mounts are before you cut them out so that you can line up the new ones as you fit them in.
by Monster
523/thumbs/DSC_0656.jpg
by Dad's SS
1164/thumbs/IMGP6649small.jpg
by Witman69
523/thumbs/DSC_0633.jpg
