#974661 - 06/12/13 12:54 AM ls1 brakes wheel size
robert87ss Offline
robert87ss  Offline
Lakeland,FL
I think I got a good deal. complete rear end brakes and all out of 01 firebird and both front rotors calipers brackets and hoses for $150. just wondering, before I modify the spindles, if 15" wheels will fit the front. I seen a pic of a lt1 Camaro with 15" wheels on the front.
1987 Monte Carlo SS Pontiac powered project
too much time not enough money
#974671 - 06/12/13 01:24 AM Re: ls1 brakes wheel size [Re: robert87ss]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
Lt1 brakes are not the same as the ls1. But I've seen them grind down the cooling fins on the caliper and fit a 15, only certain 15's though. But the minimum is 16 for the front brakes and I know for a fact the stock ss rims fit over ls1 rears.
2015 GMC Sierra Denali
#974672 - 06/12/13 01:27 AM Re: ls1 brakes wheel size [Re: robert87ss]
robert87ss Offline
robert87ss  Offline
Lakeland,FL
so I might clear 15" on the front if I grind the cooling fins off the top of the caliper.
#974678 - 06/12/13 01:52 AM Re: ls1 brakes wheel size [Re: robert87ss]
Monte_ExpreSS Offline
Oshawa, Ont. Canada
This guy says his 15" Monte wheels cleared. He's a member on this board also.
http://www.turbobuick.com/forums/threads...o.390739/page-2
#974679 - 06/12/13 02:07 AM Re: ls1 brakes wheel size [Re: robert87ss]
robert87ss Offline
robert87ss  Offline
Lakeland,FL
very helpful link saved to my favorites thanks.
#974787 - 06/13/13 02:13 AM Re: ls1 brakes wheel size [Re: robert87ss]
robert87ss Offline
robert87ss  Offline
Lakeland,FL
little off topic but i was wondering if i need to change master cylinder when i do this swap. when i did my brakes the first time i used howe calipers with the bigger pistons and i noticed the pedal was a little lower. i like the pedal towards the top.
#974857 - 06/13/13 07:40 PM Re: ls1 brakes wheel size [Re: robert87ss]
87ChooChoo Offline
87ChooChoo  Offline
las Vegas, NV
Robert, I just changed to the Blazer front and LS1 rears. No change to the MC, booster or prop/combo valve. I thought the valve might need changing, but thought I would try it first. So far no issues.
#974885 - 06/14/13 02:07 AM Re: ls1 brakes wheel size [Re: robert87ss]
robert87ss Offline
robert87ss  Offline
Lakeland,FL
the ls1 rear has the calipers mounted on front side. ive read that you have to move rear shocks to clear the calipers. the shocks are mounted to the rear side. so whats the advantage of mounting calipers to rear instead of just leaving them on the front. ive seen lowered cars with them on the front and back side.
#974890 - 06/14/13 02:43 AM Re: ls1 brakes wheel size [Re: robert87ss]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
The calipers are suppose to be front mounted, but frame to caliper are the clearance issue. Not a problem with the shocks, mounted in the front. In the rear yes you have to move the shocks inboard but its not hard, I used a 3/16 flat plate I bolted to the rear and welded it so it didn't move and moved my shocks inboard a inch n half.
#974892 - 06/14/13 03:06 AM Re: ls1 brakes wheel size [Re: robert87ss]
robert87ss Offline
robert87ss  Offline
Lakeland,FL
I guess all I have to do is make the LR ls1 setup my RR. I was also reading something about a spacer so the caliper is centered over the rotor. but I only read about that on one car that I can recall.
#974902 - 06/14/13 04:01 AM Re: ls1 brakes wheel size [Re: robert87ss]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
If you go into my build thread it shows my install. There was no spacer needed.
#974903 - 06/14/13 04:04 AM Re: ls1 brakes wheel size [Re: robert87ss]
87ChooChoo Offline
87ChooChoo  Offline
las Vegas, NV
Another reason to swap sides is so the emergency brake cables will pull in the stock direction. The spacer will be needed to center the caliper on the rotor. You'll also need to use longer studs. Here's a drawing I did for a couple of brackets, including the shock relocation brackets. These brackets will allow you to use the stock G-body emergency brake cables.
More pictures here on the brackets if you need more detail.
http://s300.photobucket.com/user/darbysan/library/Big%20Brakes?sort=3&page=1
#975461 - 06/20/13 09:06 AM Re: ls1 brakes wheel size [Re: Monte_ExpreSS]
novaderrik Offline
novaderrik  Offline
Ashby, MN
hey... that's me..
yes, the Monte SS aluminum wheels clear the calipers with only a little massaging of the fins on the calipers... actually started driving the car (86 Camaro) the other day, and after 120 or so miles i can report that i haven't died yet and the car stops amazing.. just might put the same setup on my 84 T Type...
74 Monte Carlo cruiser
#1007835 - 07/18/14 11:35 AM Re: ls1 brakes wheel size [Re: 87ChooChoo]
twfurst Offline
twfurst  Offline
Norwich, CT
I have been looking at your bracket drawing would like to use it to make some brackets of my own. I was hoping you may be able to provide a few dimensions not shown on the drawing:
* What is the width of the shock bracket? Is that also 1.5"?
* What is the distance from the edge for the shock bolt as well as the bolt to the diff housing?
* On the e-brake adapter to use on the LS1 bracket I see the "short" leg is 1" tall, what is the length of the "long" leg with the 3/8 x 5/8 slot?
* On the cable bracket that mounts to the control arm bolt, are both holes 9/16" diameter?
I realize this post is over a year old, but hoping you may have some answers.
Thank you,
Tom Furst
Tom Furst
1980 Malibu (work in progress)
SBC 355, 4 speed retro-fit
#1007843 - 07/18/14 02:33 PM Re: ls1 brakes wheel size [Re: twfurst]
87ChooChoo Offline
87ChooChoo  Offline
las Vegas, NV
Yes- it's a 1.5x1.5 angle iron.
Not really important- just give good clearance for the hole- say 3/4" in from the edge to center of hole. Hint: you can buy a bracket that is nearly perfect for this on Amazon ( maybe available other places). The Unistrut PN is P1026. I think you could also use A1026 ( holes are slightly smaller). My preference would be to use the A1026, and drill out the holes if needed. The P1026 holes are 9/16", while the A1026 holes are 13/32" (10mm). You will need to add the small hole to prevent rotation.
It's the stock length of the 1.5 angle iron.
No- the one at the end where it bolts to the lower control arm is a 1" long slot, 9/16" wide. When I get the chance to re-make this bracket, I will be using angle iron for more stability. So far it's worked OK, but I think the angle iron would be better
Thank you,
Tom Furst
#1007845 - 07/18/14 03:15 PM Re: ls1 brakes wheel size [Re: 87ChooChoo]
twfurst Offline
twfurst  Offline
Norwich, CT
Thanks for getting back to me. Will be working on this over the weekend (hopefully).
Tom Furst
500/thumbs/stein07_01.jpg
by GregK
500/thumbs/indo_black_006.jpg
by Hailhorror77
by Monster
500/thumbs/0711111820.jpg
by tetamcssmokin
500/thumbs/DSCN3990.JPG
by Aeroaddict
