#967817 - 04/06/13 07:13 AM
Re: Trying to get ac working in 83 ss
[Re: Gunnerwar]
carloss
Burnaby, BC
Hopefully its just leaking from the o-rings. When you change the compressor you should change the accumulator, orifice tube and o-rings. Assumimg you do that and have no leaks you'd still need to vacuum the system to get all the moisture out before you charge the system. I bought a vacuum pump and a set of gauges and recharged the system myself. It cost me about what a shop would have charged anyways.
#967824 - 04/06/13 12:01 PM
[Re: Gunnerwar]
Since you have to replace the compressor along with the accumulator and orifice tube, it would be a good time to convert to R134a which means you'll need the proper oil as well. The OEM recommended oil is PAG and the system uses 8 oz of it, if you don't have the proper tools, a shop should probably do the work for you.
#967883 - 04/07/13 12:39 AM
[Re: Gunnerwar]
mikeasis
faimont, wv
You know not real sure I would guess these days the compressor would come with the correct pag oil with r12 being so hard to get....either way compressor is the same just use the correct oil and change the o-rings.
If you were close Id try out the a/c machine I've had and not used......
#967899 - 04/07/13 02:29 AM
[Re: Gunnerwar]
some compressors come filled with oil, some don't, follow the compressors instruction sheet.
#968861 - 04/16/13 04:07 AM
[Re: Gunnerwar]
the system takes a total of 8 ounces, I put 4 in the compressor, in the suction port and rotate it for about 6 revolutions, and the other 4 in the accumulator. hope this helps.
#968904 - 04/16/13 04:32 PM
[Re: Gunnerwar]
I put it in the inlet side, where the pipe comes out of the evaporator.
#969129 - 04/18/13 03:33 PM
[Re: SickSpeedMonte]
Just know, if you take A/C advice from Leo, your glasses will fog up when you get out of the car! True, but very funny Bernie, esp on hot, humid days.
#969370 - 04/21/13 03:09 AM
[Re: Gunnerwar]
#969403 - 04/21/13 03:10 PM
[Re: Gunnerwar]
OK, I see that on my pic, there needs to be a vacuum source, I think it comes from a fitting on the back of the engine.
by Clutch_Grabwell
by markg
by tovann
by Witman69
by RoadWarrior
