#967494 - 04/03/13 07:39 PM rear axle id
kenw Offline
kenw  Offline
Coatesville, Pa
I bought a rear axle and can't find the code listed anywhere. It's 9TZ C085 2. Anyone know what this is? It's supposed to be out of a 1986 SS.
#967522 - 04/03/13 10:08 PM Re: rear axle id [Re: kenw]
kenw Offline
kenw  Offline
Coatesville, Pa
I spun the pinion and it goes around approximately 3.75 times to the 1 time the axle turns. Both axles spin.
#967553 - 04/04/13 12:47 AM Re: rear axle id [Re: kenw]
Clutch_Grabwell Offline
Millbury, MA
Sounds like a 3.73:1 Posi. The ratio is stock for an '86 SS and the Posi was an option. I can't help with the codes but your info is fairly conclusive.
1986 MCSS, T-tops, TPI 350, T56, 8.5" 3.42:1 Posi, cruise, A/C, ZQ8 brakes
All power: Windows, locks, mirrors, 8-way GTO seats
Concert Sound II, seven speakers, two amps
As seen in Hemmings Muscle Machines Aug. 2010
http://www.hemmings.com/mus/stories/2010/08/01/hmn_feature6.html
#967569 - 04/04/13 03:09 AM Re: rear axle id [Re: kenw]
richan Offline
richan  Offline
little rock,ar
Can you tell if it's a 7.5 or 8.5 dia. and my chart doesn't show that code for any Gbody. Where did that code come from?
87 MCSS Aerocoupe, 2 84 Elco V6 & V8, 87 Elco V8
#967584 - 04/04/13 08:15 AM Re: rear axle id [Re: richan]
kenw Offline
kenw  Offline
Coatesville, Pa
Passenger side axle tube.
#967621 - 04/04/13 06:55 PM Re: rear axle id [Re: kenw]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. 1980's Montes were all 7 1/2" rears... some 1980's Hurst Olds, 442's, and GN's came with stronger 8 1/2" rears of 3.42 and rarer 3.73 ratios...
.. Click on 'drivetrain' and set your 'Display Options' to go back a few years instead of just the default one week and there should be postings with pictures showing the differences in external apprearance between 7 1/2" and 8 1/2" rears...
#967654 - 04/04/13 09:56 PM Re: rear axle id [Re: kenw]
richan Offline
richan  Offline
little rock,ar
[1980's Hurst Olds, 442's, and GN's came with stronger 8 1/2" rears of 3.42 and rarer 3.73 ratios.] quote
Yes I have one of each from a 84 Hurst Olds and the other from a T-Type Regal in the 8.5. I think one has aluminum drums but both are non-posi and hard to find.
#967663 - 04/04/13 10:40 PM Re: rear axle id [Re: BuzzLOL]
Gruvin Offline
Gruvin  Offline
Texas
only G-body 8.5's: 1984 to 1987 GN's(3.42 gears), 1985 to 1988 Olds 442(3.73 gears), & the 84 Hurst Olds(3.73 gears)
#967721 - 04/05/13 09:13 AM Re: rear axle id [Re: BuzzLOL]
kenw Offline
kenw  Offline
Coatesville, Pa
.. Click on 'drivetrain' and set your 'Display Options' to go back a few years instead of just the default one week and there should be postings with pictures showing the differences in external apprearance between 7 1/2" and 8 1/2" rears... [/quote]
Thanks for the suggestion. I found an old posting and the guy had a 9TY. It's a non posi 3.73.
#967745 - 04/05/13 04:16 PM Re: rear axle id [Re: kenw]
kenw Offline
kenw  Offline
Coatesville, Pa
I took the cover off and it is definitly a 7.5" 3.73. Not sure if this is an open rear or limited slip.
#967757 - 04/05/13 06:15 PM Re: rear axle id [Re: kenw]
kenw Offline
kenw  Offline
Coatesville, Pa
Found a picture online, it's a limited slip.
500/thumbs/IMG_20121207_130339.jpg
by atorres5
500/thumbs/the_monte_now1.jpg
by montesleeper83
961/thumbs/shifter_console_cutout.jpg
by jrz126
560/thumbs/MM_04_19.jpg
by NYmonteSS
500/thumbs/67.JPG
by juangomez22
