Page 1 of 3 1 2 3
#966150 - 03/23/13 04:56 PM pypes exhaust problem
Joe b. Offline
Joe b.  Offline
west haven ct.
has any body had any trouble with the tailpipes sticking out past the frame in the wheel well right before they follow the quarter? mine are past the frame rails and the dam tires are hitting. any help would be great. also if anybody knows a quality exhaust shop that can be trusted to maybe bend these pipes in thanks.
custom paint 383 stroker 450hp 700r4 trans posi rear
#966178 - 03/23/13 07:18 PM Re: pypes exhaust problem [Re: Joe b.]
Ninja85SS Offline
Ninja85SS  Offline
California, MD
I had problems with mine at first as well, but then I finally found a position that worked. But I have to tell ya, it was a lot of trial and error. They for the most part only fit one way and it only takes a very little adjustment either by twising, pulling out, pushing inward, etc. to throw it off and get the tire rub. Stick with it, it should work. I have slightly wider tires and used the 2.5" dia's, but it worked.
1985 Monte Carlo SS 383MT Forced Induction
http://www.cardomain.com/ride/2228046
2004 Dale Earnhardt Jr. Supercharged Monte Carlo SS
#966185 - 03/23/13 08:21 PM Re: pypes exhaust problem [Re: Joe b.]
85lolo Offline
85lolo  Offline
radiator springs
I had same problem, just alot of trial and error it will work out
#966205 - 03/24/13 02:09 AM Re: pypes exhaust problem [Re: Joe b.]
Joe b. Offline
Joe b.  Offline
west haven ct.
thanks, thats good to know. is it just a matter of finding the right spot for the tailpipes? the rest of the system seems to fit fine.
#966452 - 03/26/13 08:42 AM Re: pypes exhaust problem [Re: Joe b.]
84LS1T56SS Offline
84LS1T56SS  Offline
Central, Arkansas
Like they said, it's just trial and error. You should try getting the 3" pypes to line up. Once you get it, they look good, but it takes a while to get them adjusted right.
#966453 - 03/26/13 10:15 AM Re: pypes exhaust problem [Re: Joe b.]
Joe b. Offline
Joe b.  Offline
west haven ct.
OK thanks.
#966620 - 03/28/13 03:26 AM Re: pypes exhaust problem [Re: Joe b.]
Ninja85SS Offline
Ninja85SS  Offline
California, MD
Let us know how it goes...
#966752 - 03/29/13 09:55 AM Re: pypes exhaust problem [Re: Joe b.]
Joe b. Offline
Joe b.  Offline
west haven ct.
Will do waiting to mount new tires and rims see how much there hitting and go from there
#966858 - 03/30/13 01:00 AM Re: pypes exhaust problem [Re: Joe b.]
Ninja85SS Offline
Ninja85SS  Offline
California, MD
There is a lot going on down there with clearancing tires and springs. Trick is to ritate inward, if I recall correctly but not to far and make sure you check not only jacked up, but on ground. I had mine just barely clearing the springs to clear tires and I only ran 2.5's back.
#967160 - 04/01/13 02:44 PM Re: pypes exhaust problem [Re: Ninja85SS]
Clutch_Grabwell Offline
Millbury, MA
Here's my Pypes cat-back laid out on the garage floor ready to go. Except for the right-hand tail pipe pointing in a different direction than the other. The muffler ends of the tail pipes are not bent at the same angle which translates into a big difference at the other end.
The installation probably would have gone badly. Summit Racing is sending another set from which I can mix-and-match to cobble a usable set together.
1986 MCSS, T-tops, TPI 350, T56, 8.5" 3.42:1 Posi, cruise, A/C, ZQ8 brakes
All power: Windows, locks, mirrors, 8-way GTO seats
Concert Sound II, seven speakers, two amps
As seen in Hemmings Muscle Machines Aug. 2010
http://www.hemmings.com/mus/stories/2010/08/01/hmn_feature6.html
#967161 - 04/01/13 03:13 PM Re: pypes exhaust problem [Re: Joe b.]
Wowsers, that is a massive screwup. Glad they are giving you another set. Did, you have to buy it?
#967169 - 04/01/13 04:20 PM Re: pypes exhaust problem [Re: Joe b.]
Millbury, MA
No, they're sending a pick-up ticket for the unused set.
#967170 - 04/01/13 04:22 PM Re: pypes exhaust problem [Re: Joe b.]
Thats not good news, I was thinking about doing the pypes exhaust on my car. let us know how the new kit works out.
#967273 - 04/02/13 01:46 AM Re: pypes exhaust problem [Re: Joe b.]
Aeroaddict Offline
Aeroaddict  Offline
Fairfield County ,CT
Torque Tech's the way to go..
#967296 - 04/02/13 10:04 AM Re: pypes exhaust problem [Re: Aeroaddict]
Joe b. Offline
Joe b.  Offline
west haven ct.
please explain
#967298 - 04/02/13 10:31 AM Re: pypes exhaust problem [Re: Joe b.]
MY FYN 79 Offline
MY FYN 79  Offline
N/E WI
I cant speak for every setup out there, but the two Torque Tech systems I've had fit a lot nicer than the Pypes setup a friend of mine put on his 78 Monte.
#967302 - 04/02/13 12:09 PM Re: pypes exhaust problem [Re: Joe b.]
Millbury, MA
Torque Tech has discontinued the single-cat duals. I'll give the second set of Pypes another chance this weekend.
#967394 - 04/03/13 12:23 AM Re: pypes exhaust problem [Re: Joe b.]
Aeroaddict Offline
Aeroaddict  Offline
I have the 3" Torque Tech X pipe setup with no tail pipes (yet), Fit was perfect.
#967437 - 04/03/13 10:06 AM Re: pypes exhaust problem [Re: Aeroaddict]
Joe b. Offline
Joe b.  Offline
west haven ct.
Never heard of them allthough i wish i did before i bought this crappy pypes system.
#967518 - 04/03/13 09:39 PM Re: pypes exhaust problem [Re: Joe b.]
Aeroaddict Offline
Aeroaddict  Offline
Joe,
I dont know if you remember what my exhaust looked like. I beleive this is the kit I used.
http://www.torquetechexh.com/xpipe.htm
#967626 - 04/04/13 07:44 PM Re: pypes exhaust problem [Re: Joe b.]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. Pypes is available in permanent stainless steel, don't know if Torque Tech is...
#968209 - 04/09/13 11:05 PM Re: pypes exhaust problem [Re: Joe b.]
Hey clutch, how did the second pypes exhaust kit work out?
#968222 - 04/10/13 01:12 AM Re: pypes exhaust problem [Re: BuzzLOL]
Ninja85SS Offline
Ninja85SS  Offline
California, MD
Yea, I think they discontinued their Temporary Stainless Version a while back!
#968231 - 04/10/13 01:42 AM Re: pypes exhaust problem [Re: Joe b.]
Millbury, MA
It didn't go well. On one hand, the second set wasn't bent any better than the first. I brought the tail pipes to a local custom exhaust shop for an opinion. The proprietor thought the bending error was behind the axle and that I should go ahead with the installation and cut off the section that was pointing in the wrong direction and he would weld it back on correctly. I'm not completely on board with his assessment.
Another disappointment was the universal hangers that require holes in the frame behind the mufflers and visible clamps under the bumper. I'd prefer to have brackets welded on to reuse the factory muffler hangers and to eliminate the clamps out back.
On the other hand, it's official: I'm too old for this crap. I couldn't raise my arms overhead for a couple of days after the installation. Maybe I'll get a lift for my birthday this summer.
But it sounds great! The subtle rumble has been replaced with a snarl. My 6 AM departure for work will no longer go unnoticed. whistle
#968241 - 04/10/13 03:51 AM Re: pypes exhaust problem [Re: Joe b.]
What mufflers did you go with? any final pics? I wonder if the gn style exit would fit better?
Page 1 of 3 1 2 3
500/thumbs/IMG_0697.JPG
by 565bbchevy
1083/thumbs/0221111610.jpg
by PIMPC3692
500/thumbs/seat_001.JPG
by montec_ss85
650/thumbs/DSC01290.JPG
by monte_kev
