#964919 - 03/13/13 12:22 AM Custom Door Panel Fitment?
THEmean1 Offline
THEmean1  Offline
Memphis,TN
The link below is to a picture of a GSI panel installed..is this a normal amount of gap between door and panel for you guys that have purchased these?
[img]https://picasaweb.google.com/lh/photo/3LNgdt0hnUSD5w-MBZ5pqYgjDAycKw-anpx90v1vuWc?feat=directlink[/img]
85' Monte Carlo SS(Current Project)
Current(402CID-TH350-3.50 9" Detriot Tru-Trac)
Planning(2.5/1.5 drop,502CID,Roll Cage)
69' C10(Current Project)
Current(355CID-TH350-3.08 Peg)
Planning(4/6 drop,Disc Brake Upgrade, Posi)
#964921 - 03/13/13 12:36 AM Re: Custom Door Panel Fitment? [Re: THEmean1]
Bad Co Offline
Bad Co  Offline
Earth
The inside sweep should be touching the glass. Hard to tell from your picture if it is or not.
#964926 - 03/13/13 01:15 AM Re: Custom Door Panel Fitment? [Re: Bad Co]
gmguy3car Offline
Authorized Vendor
gmguy3car  Offline
Authorized Vendor
Silverdale,Wa
There will be a slight gap being the tree clips aren't used because of the thin work area between panel and door our cars have, and the way the glued down logos use the 1/8 paneling, this gap is under 1/4 inch, it's a little deceiving with the black paint/panels.
You can put HD Velcro behind there that's how this one is mounted.
Go ahead and PM me back and we can work for a solution.
#965113 - 03/15/13 12:38 AM Re: Custom Door Panel Fitment? [Re: THEmean1]
THEmean1 Offline
THEmean1  Offline
Memphis,TN
OK thanks for the Velcro tip...
#965629 - 03/19/13 05:52 AM Re: Custom Door Panel Fitment? [Re: THEmean1]
delreyss Offline
delreyss  Offline
del rey,CA
what kind of seats do you have mean1
#965983 - 03/22/13 03:17 AM Re: Custom Door Panel Fitment? [Re: THEmean1]
THEmean1 Offline
THEmean1  Offline
Memphis,TN
Procar Elites..I painted the middle inserts with duplicolor red.
995/thumbs/44.jpg
by knight77
500/thumbs/monte_engine1.jpg
by 85lolo
1126/thumbs/1986_2.jpg
by Rich S
500/thumbs/009.jpg
by mdecker211
