Looking for metal strips for pull straps - doors
Posted By: QuikZilver
Looking for metal strips for pull straps - doors - 11/10/15 11:47 PM
I am looking for the metal strips (generally not painted) that attach to the door shell that the pull straps are screwed into. I need both sides. If you have and are willing to part with, hit me up. Shipping would be to 33445. Thanks in advance!!
Posted By: cj84ss
Re: Looking for metal strips for pull straps - doors - 11/11/15 01:23 AM
Your local parts store most likely has them. Usually in the help section. Been a
While since I even looked but they always used to have them.
Posted By: Mick
Re: Looking for metal strips for pull straps - doors - 11/11/15 02:00 PM
I think I have a pair will check tonight
Posted By: LXXXIV SS
Re: Looking for metal strips for pull straps - doors - 11/11/15 02:24 PM
My 84SS pull strap metal pieces attach to the door panel itself, not the door shell. Maybe your car is different, though?
Posted By: 86ttop
Re: Looking for metal strips for pull straps - doors - 11/11/15 11:33 PM
They do pop rivet to the door panel or at least mine did.
Posted By: gmachinz
Re: Looking for metal strips for pull straps - doors - 11/12/15 05:26 AM
78-80 Monte door strap pulls screw threw the ends of the metal strips and into the door shells-not sure exactly what year GM began to rivet the strips to the upper door panel but it was a better idea. The 78-80 cars had no such extra support behind the panels like that.
Posted By: 86ttop
Re: Looking for metal strips for pull straps - doors - 11/12/15 05:57 PM
the screws still go thru the strips and hold the pull straps better to the door. IIRC
Re: Looking for metal strips for pull straps - doors - 11/12/15 07:30 PM
Yep, you're right.
Re: Looking for metal strips for pull straps - doors - 11/12/15 10:48 PM
Just found a set from member: Derrick. Thanks again Derrick!!!
Posted By: gmachinz
Re: Looking for metal strips for pull straps - doors - 11/18/15 02:09 PM
On my 80 Monte, I decided to use a riv-nut gun to press 8mm nuts into my door hardware-so instead of using a big ole coarse machine screw I can use an actual machine bolt. I hate when them damn pull straps get loose-pits for sure....lol
