GloveBox Lock Removal: The Easy Way
Posted By: Witman69
GloveBox Lock Removal: The Easy Way - 05/05/15 05:33 PM
I needed to remove my glovebox lock to paint the dash, but the info on how to do that is pretty thin. Heres what you'll need:
The Easy Way:
1. Glovebox Key
2. Tiny Screwdriver
3. 9/32 or 7mm socket
First, Open your glovebox, insert the key , and turn it counterclockwise to lock it. Remove the Key
[img]http://1drv.ms/1KdKBkR[/img]
The slot will be vertical
Next, remove the two screws holding the lock
http://1drv.ms/1KJX68F
This will give you a little space to work with.
[img]http://1drv.ms/1zKtuHn[/img]
Finally, Insert your screwdriver into the visible top slot, while you pull out on the knob slightly . You will feel the spring in the tumbler, and the knob come out slightly as the 1st tumbler releases. Repeat, and press on the remaining 4 tumblers to get them to release.
[img]http://1drv.ms/1F4dbr9[/img]
Pull the knob completely out, and you're done!
When you want to reinsert the knob, press on the tumbler closest to the lock, and it will slide past the gate.
Note. The easy way requires a key. Next post is the hard way, which does NOT require a key, but does require the glovebox to be open...
Posted By: LXXXIV SS
Re: GloveBox Lock Removal: The Easy Way - 05/06/15 10:49 AM
Excellent. Nice pics and a great explanation!
Posted By: Witman69
Re: GloveBox Lock Removal: The Easy Way - 05/07/15 03:28 AM
Lets see if the pics show up now...
I needed to remove my glovebox lock to paint the dash, but the info on how to do that is pretty thin. Here's what you'll need:
The Easy Way:
1. Glovebox Key
2. Tiny Screwdriver
[/url[/img]
[img]http://imgur.com/WFAjdVw][img]http://i.imgur.com/WFAjdVw.jpg[/img][/url[/img]
[/url[/img]
[/url[/img]
Posted By: Richie Cat
Re: GloveBox Lock Removal: The Easy Way - 05/09/15 10:14 PM
How come you don't use the coin holder? lol.
Posted By: T-Top Tom
Re: GloveBox Lock Removal: The Easy Way - 09/07/17 01:42 PM
Thanks.
