4l80e help
Posted By: thess
4l80e help - 05/27/14 05:46 AM
Need to figure how much I need my drive shaft shorten. And if I can a 200r 4 crossmember
Posted By: 2sabeSS
Re: 4l80e help - 05/27/14 03:28 PM
x3!!!
Posted By: blubaldmontess
Re: 4l80e help - 05/27/14 07:32 PM
I don't remember how much to shorten the driveshaft, I know that mine was over the 2" mark with an 8.5 rearend, but I can tell you that the 200r4 crossmember (I had an iceman) worked, but the mounting hole had to be cut and lengthened, and after I did it, the transmission didn't sit quite right, had a really odd angle. Good luck!
Posted By: spacemanspif
Re: 4l80e help - 05/28/14 01:15 AM
Every car will be a little different. I didn't even pay attention to how long my shaft is because every bolt bushing and mount comes into play. Put the engine and trans in and measure it.
Measure twice; cut once.
Posted By: thess
Re: 4l80e help - 06/03/14 04:21 AM
How would you go about measuring to find the proper measurements
Posted By: 86ttop
Re: 4l80e help - 06/03/14 11:41 AM
call a driveshaft shop and ask.
Re: 4l80e help - 06/03/14 03:38 PM
http://www.dennysdriveshaft.com/how_to_measure.html
HTH
