Turbo Monte 88 SS Build
Posted By: beatboy77
Turbo Monte 88 SS Build - 12/05/17 02:42 PM
I was lucky enough to find a low mileage (28,000 miles) 1988 SS car from Texas a couple of months a go. No rust, other than just a very small amount on the corner of each door and scale underneath. The car has some very minor dents on the drivers side door, where it looks like someone leaned on the car consistently over the years. That is my guess any way. The paint is thin in a few areas from all of the years of polishing, as such it will need a re-spray. It also looks like one of the previous owners put 85-86 decals on it. I have to say, I actually like how those look better.
So being a child of the 80's, I always loved the look of the Maroon Monte Carlo cars from that time, however always loved the power of the turbo Buick Grand National. With this build I am going to try to combine the best of both of my likes. I am going to remove the 305 in the Monte and replace with a new crate engine 350 with twin turbos. Getting a new radiator and going with a 700R4 trans. Also getting new disc brakes all around and installing some lowering springs to drop the car 1.5" to 2". I am aiming to keep the rest of the car stock. The interior is immaculate and has never been smoked in. The original radio was at one point removed and replaced with a single DIN. I am going to replace that with the original looking RetroSound NEW-264-269-660, only with modern technology like Bluetooth, etc.
Here is how she sits as now
Josh
Posted By: PB86SS/87LS
Re: Turbo Monte 88 SS Build - 12/05/17 04:23 PM
Looks like a great starting point, clean car! Interesting choice to use the 85/86 decals by the PO, looks like it had headlight covers at one point too.
Posted By: Hunter79764
Re: Turbo Monte 88 SS Build - 12/05/17 04:33 PM
Welcome to the board.
Looks good, and sounds like a plan!
Posted By: Travis Jones
Re: Turbo Monte 88 SS Build - 12/05/17 08:56 PM
Nice clean car. Good luck with the build.
Unless you're hellbent on a 350 for nostalgic 80's reasons, I'd strongly suggest you look into a 6.0L LS based motor with a 4L80e.
In the case of forced induction you'll be in a much better starting point cost wise with an LS based motor. 9.4-1 compression, aluminum heads. Fuel Injection from the factory.
Even if you do decide to go with a 350, for the power levels you'd be looking at twin turboed, a 700R4/4L60 is not the trans you want for those power levels.. 2-3 shift will be mush at WOT. even rebuilding the stock 200-4r for power is a better choice.
Re: Turbo Monte 88 SS Build - 12/06/17 01:39 PM
Thank You for the advice. I am using the 350 as I have it on hand and purchased for an amazing price. Also there is a little 80's nostalgia there too, as this car is built in a way I wish GM would have made a Monte to compete with a Grand National back at that time. I chose the 700R4 as I have one on hand and it is being re-built currently. We have a Good shop in town which does this and we are having him re-build using the heavy duty option he offers. I will try it and if over time this trans annoys me, I will try something different.
Josh
Posted By: upflying
Re: Turbo Monte 88 SS Build - 12/06/17 03:00 PM
Don't forget to keep the stock parts, that's a clean survivor and you might want to go back to stock some day. Stock and original is generally worth more when you sell.
BTW, those door dents are from a someone using their body to close a partially shut door. Stubborn door closing is often caused by sagging hinges which causes a misalign at the door striker. Then some fat ash tries to close the door all he way by pushing on the door panel. Shameful abuse by careless people. My car had those dents too.
Posted By: Witness86SS
Re: Turbo Monte 88 SS Build - 12/06/17 06:30 PM
my kids keep trying to make those dents. No you don't need a running start to close the door...
Posted By: tigerss
Re: Turbo Monte 88 SS Build - 12/08/17 12:30 AM
Nice car
I prefer the 86 stripes so I might consider that option when I repaint my 88. It does hurt my brain a little to think of 86 stripes on an 88 though.
I think its more weird he swapped stripes on a sub 30k car more so then that somebody would change them.
Re: Turbo Monte 88 SS Build - 12/08/17 02:55 AM
As we wait for parts to come in, we started to sand it down and prepare for the re-spray today
Posted By: mmc427ss
Re: Turbo Monte 88 SS Build - 12/08/17 05:07 AM
Very nice pallet to start with.
As you prep the car for paint don't forget it's lacquer originally.
Posted By: gmachinz
Re: Turbo Monte 88 SS Build - 12/09/17 12:02 AM
Umm...wait a minute-how bad was the OE finish? I'm surprised you "getting at it" paintwise when it looked pretty damn good in the pics you posted.
Re: Turbo Monte 88 SS Build - 12/09/17 01:33 PM
Not Great and there we several small dents throughout, especially on the doors. Speaking of the doors, there were some small rust spots on the corners, about the size of nickel as well. I want to fix those properly.
Josh
Re: Turbo Monte 88 SS Build - 12/09/17 01:34 PM
Continued sanding today. Making progress
Posted By: Richie Cat
Re: Turbo Monte 88 SS Build - 12/09/17 03:33 PM
Got to ask. Is that a chopped 49 Merc in the background?
Re: Turbo Monte 88 SS Build - 12/09/17 05:18 PM
It is a 51 with a 49 window
Re: Turbo Monte 88 SS Build - 12/12/17 01:34 PM
And More Sanding.....lol
Re: Turbo Monte 88 SS Build - 12/19/17 01:12 PM
Continuing to sand and prep. Needed just a little filler on pillars at the factory weld seam. Also just a touch in a couple of spots on the lowers doors where some minor rust was repaired. This car is remarkably clean for a 29 year-old car. I guess that makes sense since it is from Texas.
Re: Turbo Monte 88 SS Build - 12/19/17 01:14 PM
Got the engine and trans out. The intercooler also arrived.
Re: Turbo Monte 88 SS Build - 12/19/17 11:02 PM
Making quick work of it! You've done in 2 weeks what I would have done in 2 years smile
Re: Turbo Monte 88 SS Build - 12/22/17 03:01 PM
Finally finished sanding and prep. Then primed.
Re: Turbo Monte 88 SS Build - 12/22/17 03:04 PM
Radiator and Intercooler painted
Re: Turbo Monte 88 SS Build - 12/22/17 03:07 PM
Basic mock up of the Twin Turbo 350 going in the car
Re: Turbo Monte 88 SS Build - 12/22/17 06:29 PM
Can you give us some info on the engine build? Also the exhaust "headers" and turbos? Being it's a mock up is this a dummy engine also?
Posted By: 84ss355*4spd
Re: Turbo Monte 88 SS Build - 12/23/17 10:39 PM
Good job.tjat motor looks like would be fun . Keep the pics coming
Re: Turbo Monte 88 SS Build - 12/24/17 12:47 AM
Time for a "Block Party!". Started to block it today. Found a couple of small areas which will need some attention. Other than that, all is coming along nicely. After blocking, we are going to strip the engine bay and re-paint that. Then install the engine before final paint.
Re: Turbo Monte 88 SS Build - 12/26/17 09:11 PM
Getting the engine bay prepped for new paint, before we drop the engine and trans in
Re: Turbo Monte 88 SS Build - 12/28/17 06:30 PM
The 350 is installed. Test fitting the turbos. The company I purchased the kit from sent the wrong headers. Have to send these ones back. Going to create around a two-week delay in this part of the project to get the correct headers in. We will continue to focus on the new paint and the four wheel disc brake install.
Re: Turbo Monte 88 SS Build - 12/28/17 08:02 PM
You work quick! From only getting the car a couple months ago or so to this.
Posted By: 84 ZZ4
Re: Turbo Monte 88 SS Build - 12/29/17 10:37 PM
Awesome build.
I hope you get out of paint-jail and engine-jail soon.
I'm curious what you have planned for engine bay heat management.
Air vents, etc.
I highly recommend jet-hot coatings on any of the headers, etc, they coat inside and out, I can touch my headers literally minutes after driving.
HTH
Re: Turbo Monte 88 SS Build - 01/17/18 02:09 AM
Car got painted a couple of weeks a go. Now starting on the wet sanding and buffing. Waiting for correct headers to come in
Posted By: mmc427ss
Re: Turbo Monte 88 SS Build - 01/17/18 03:46 AM
That's a very nice shop you have there, all those cars/bikes in process must keep you busy. Is the SS a keeper?
Re: Turbo Monte 88 SS Build - 01/18/18 02:42 AM
I am planning to keep it for a few months, however I do plan to sell after
Josh
Re: Turbo Monte 88 SS Build - 01/21/18 04:23 PM
Also, this is not my shop. This is at a custom car shop called Pot O'Gold Kustoms. They do excellent work and have been featured on Velocity Channel. Great place and Great people!
Josh
Re: Turbo Monte 88 SS Build - 02/16/18 03:23 PM
Fired up the engine yesterday and it flat out sounds EVIL! Also decided to add a FiTech fuel injection system to it. Getting closing to finishing it. Getting the inter-cooler plumbing work done next week
Posted By: ratbuddy
Re: Turbo Monte 88 SS Build - 02/16/18 11:15 PM
Very nice! Is it this system? http://fitechefi.com/products/30004/
Re: Turbo Monte 88 SS Build - 02/17/18 12:44 AM
how much are you planning on selling it for?
Re: Turbo Monte 88 SS Build - 02/17/18 03:39 PM
I believe it is. I will check next week when I am at the shop.
Josh
Re: Turbo Monte 88 SS Build - 02/17/18 03:40 PM
Not sure yet Justin. Once the project is complete and all bugs ironed out, I will take a look at my total investment in it and come up with a sales price
Josh
Re: Turbo Monte 88 SS Build - 03/02/18 11:36 PM
Engine is fully installed as are the dual turbos and inter-cooler. Still some tuning to do. Wow, Does this thing haul xxxx !
Re: Turbo Monte 88 SS Build - 03/06/18 12:10 AM
Looks sly .i bet it shreds the tires . I am debating some turbos on my 84 when its drivetrain time
Re: Turbo Monte 88 SS Build - 04/18/18 04:02 PM
We are nearing completion on the project. I will post some updated pictures soon
Josh
Re: Turbo Monte 88 SS Build - 04/19/18 07:02 PM
how are you controlling spark with a big cap distributor like that?
Re: Turbo Monte 88 SS Build - 04/20/18 03:34 PM
It is an HEI. Works well with the FiTech
Josh
Posted By: mvp
Re: Turbo Monte 88 SS Build - 04/21/18 04:35 AM
Well done no time was wasted on this one. the 350 with twin turbos is something I wasn't expecting. Great work!
Re: Turbo Monte 88 SS Build - 04/24/18 10:23 PM
Some people have asked if I plan to sell this car once complete. After some thought, I actually would entertain trades for it. If you are interested, please email me at
beatboy77@yahoo.com
Thank You,
Josh
Re: Turbo Monte 88 SS Build - 06/16/18 12:54 PM
Just about done with this build. Just some tuning and we should be Good. Have taken it to a couple of car shows already and the response has been Amazing smile
Josh
Re: Turbo Monte 88 SS Build - 06/17/18 02:02 PM
Is the motor beefed up to handle the turbos. I bet the reactions were great at the car show. Should post more pics of the car and a vid of it running lol.
Re: Turbo Monte 88 SS Build - 06/17/18 03:30 PM
Well this isn't Sponge Bob building it. LOL.
Re: Turbo Monte 88 SS Build - 06/18/18 01:02 PM
I should of said what was done to beef it up.u dont need to be a dick ritchie cat.how do you know who sponge bob is lmao .
Re: Turbo Monte 88 SS Build - 06/18/18 04:35 PM
Sorry to get under your skin. My comment was meant to be a joke.
Re: Turbo Monte 88 SS Build - 06/19/18 12:56 PM
Ya no worries . I deserved it lol .sounded like a noob
