FI fuel tank/non-FI fuel sender wire?
Posted By: 86_SS
FI fuel tank/non-FI fuel sender wire? - 04/20/12 06:38 AM
getting ready to install the fuel tank in my 86. I noticed both tanks I have are for the fuel injected G-bodies. Both tanks have the baffels and both sending units are for the electric fuel pumps.
The sending unit has a 3-wire weather pack
(pump +, ground, fuel gauge) <--i assume
My wiring harness is a single pink wire.
Will it work correctly if I just connect the pink wire to the fuel gauge wire on the sending unit? TIA
Posted By: Duts87SS
Re: FI fuel tank/non-FI fuel sender wire? - 04/20/12 01:27 PM
That will work just fine. I'd still put a matching weather pack on the cars in case you want to go FI later.
Posted By: baaboo
Re: FI fuel tank/non-FI fuel sender wire? - 04/21/12 11:24 PM
Yes.
Posted By: LM7monteSS
Re: FI fuel tank/non-FI fuel sender wire? - 04/25/12 02:01 AM
Would you like to sell the other tank and sending unit you are not using?
Posted By: 86_SS
Re: FI fuel tank/non-FI fuel sender wire? - 04/25/12 03:57 PM
I can't right now.. my brother is looking at putting FI in his Cutlass and might be needing it
Re: FI fuel tank/non-FI fuel sender wire? - 04/26/12 01:09 AM
No problem just thought I'd ask
